查看: 7343|回复: 3
高保真音量控制芯片WM8816引脚图与pdf资料手册下载
高保真 音量控制芯片 WM8816 技术资料
WM8816引脚图:
WM8816管脚功能定义:
DESCRIPTION
The WM8816 is a highly linear stereo volume control for
audio systems. The design is based on resistor chains with
external op-amps, which provides flexibility for the supply
voltage, signal swing, noise floor and cost optimisation. The
gain of each channel can be independently programmed
from -111.5dB to +15.5dB through a digital serial control
interface.
Audible clicks on gain changes are eliminated by changing
gains only when a zero crossing has been detected in the
signal. The device also features peak level detection, which
can be used for Automatic Gain Control. The WM8816
operates from a single +5V supply and accepts signal input
levels up to ±18V.
The WM8816 is available in a 16-pin SOIC package. It is
guaranteed over a temperature range of -40° to 85°C.
完整的pdf格式文档51黑下载地址:
WM8816技术资料.pdf (369.77 KB, 下载次数: 31)
ID:378745 发表于 2018-7-25 11:01 | 只看该作者
此帖仅作者可见
ID:400570 发表于 2018-10-30 10:48 | 只看该作者
此帖仅作者可见
ID:77238 发表于 2019-2-10 23:02 | 只看该作者
此帖仅作者可见
