查看: 3552|回复: 5
单片机独立按键检测的现象小疑问
ID:437990 发表于 2019-3-2 12:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
板子是郭天祥的TX-1C板子 程序实现的是四个独立按键分别实现不同的功能 有疑问的地方不是程序和现象有问题,都正常,但是在按下S5独立按键的时候 发现LED亮了好几个 感觉很奇怪 以下是单片机代码
  1. /*
  2.         KEY1:秒表加一;
  3.         KEY2:秒表减一;
  4.         KEY3:清零;
  5.         KEY4:开启秒表;
  6. */
  7. #include <reg52.h>
  8. #define uint  unsigned int
  9. #define uchar unsigned char
  10. #define digTube P0
  11. sbit KEY1 = P3^4;
  12. sbit KEY2 = P3^5;
  13. sbit KEY3 = P3^6;
  14. sbit KEY4 = P3^7;
  15. sbit DULA = P2^6;
  16. sbit WELA = P2^7;
  17. unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  18. uint tube = 0;
  19. uint time = 0;
  20. void DelayMs(uint ms);
  21. void Display(uint num);
  22. void KeyScan();
  23. void Init();
  24. void main()
  25. {
  26.         Init();
  27.
  28.         while (1)
  29.         {
  30.                 KeyScan();
  31.                 Display(tube);
  32.         }
  33. }
  34. void T0time() interrupt 1
  35. {
  36.         TH0=(65536-922)/256;
  37.         TL0=(65536-922)%256;
  38.
  39.         time++;
  40.         if (time == 1000)
  41.         {
  42.                 time = 0;
  43.                 if (tube >= 999)
  44.                 {
  45.                         tube = 0;
  46.                 }
  47.                 else
  48.                 {
  49.                         tube++;
  50.                 }
  51.         }
  52. }
  53. void KeyScan()
  54. {
  55.         if (KEY1 == 0)
  56.         {
  57.                 DelayMs(10);
  58.
  59.                 if(KEY1 == 0)
  60.                 {
  61.                         if (tube >= 999)
  62.                         {
  63.                                 tube = 0;
  64.                         }
  65.                         else
  66.                         {
  67.                                 tube++;
  68.                         }
  69.                         while (KEY1 == 0);
  70.                 }
  71.         }
  72.
  73.         if (KEY2 == 0)
  74.         {
  75.                 DelayMs(10);
  76.
  77.                 if(KEY2 == 0)
  78.                 {
  79.                         if (tube <= 0)
  80.                         {
  81.                                 tube = 999;
  82.                         }
  83.                         else
  84.                         {
  85.                                 tube--;
  86.                         }
  87.                         while (KEY2 == 0);
  88.                 }
  89.         }
  90.
  91.         if (KEY4 == 0)
  92.         {
  93.                 DelayMs(10);
  94.
  95.                 if (KEY4 == 0)
  96.                 {
  97.                         TR0 = ~TR0;
  98.                         while (KEY4 == 0);
  99.                 }
  100.         }
  101.
  102.         if (KEY3 == 0)
  103.         {
  104.                 DelayMs(10);
  105.
  106.                 if (KEY3 == 0)
  107.                 {
  108.                         tube = 0;
  109.                         while (KEY3 == 0);
  110.                 }
  111.         }
  112. }
  113. void Display(uint num)
  114. {
  115.         uint bai, shi, ge;
  116.
  117.         bai = num/100;
  118.         shi = num%100/10;
  119.         ge = num%10;
  120.
  121.         DULA = 1;
  122.         digTube = table[bai];
  123.         DULA = 0;
  124.         digTube = 0xff;
  125.         WELA = 1;
  126.         digTube = 0x7e;
  127.         WELA = 0;
  128.         DelayMs(5);
  129.
  130.         DULA = 1;
  131.         digTube = table[shi];
  132.         DULA = 0;
  133.         digTube = 0xff;
  134.         WELA = 1;
  135.         digTube = 0x7d;
  136.         WELA = 0;
  137.         DelayMs(5);
  138.
  139.         DULA = 1;
  140.         digTube = table[ge];
  141.         DULA = 0;
  142.         digTube = 0xff;
  143.         WELA = 1;
  144.         digTube = 0x7b;
  145.         WELA = 0;
  146.         DelayMs(5);
  147. }
  148. void Init()
  149. {
  150.         TMOD=0x01;
  151.         TH0=(65536-922)/256;
  152.         TL0=(65536-922)%256;
  153.         TR0=0;
  154.         ET0=1;
  155.         EA=1;
  156. }
  157. void DelayMs(uint xms)
  158. {
  159.         uint i,j;
  160.         for(i=xms;i>0;i--)
  161.                 for(j=114;j>0;j--);
  162. }
然后我KEY4的功能分别换了 发现不是程序功能的问题,好像按下S5就会亮LED 对此很好奇 希望有前辈可以指导一下
ID:213173 发表于 2019-3-2 18:57 | 只看该作者
TX-1C板子基本没有用跳线帽切换外部硬件模块,好多模块都是共用IO口,其好处是不用频繁切换外部硬件模块,缺点是有时会发生互相干扰。你遇到的情况是操作S5时P1受到干扰。S5是接在P3.7,此脚还挂有AD0804的RD端,造成AD0804干扰P1外接的74HC573,使部分LED点亮。解决这个问题很简单,程序初始化时设置P2.5低电平,关闭U3即可。
ID:478073 发表于 2019-3-2 19:47 | 只看该作者
看来楼主是没有好好看原理图了。
参与人数 1黑币 +10 收起 理由
微小苛 + 10
ID:478236 发表于 2019-3-4 10:28 | 只看该作者
这个s5是啥?
ID:437990 发表于 2019-3-4 20:29 | 只看该作者
wulin 发表于 2019-3-2 18:57
TX-1C板子基本没有用跳线帽切换外部硬件模块,好多模块都是共用IO口,其好处是不用频繁切换外部硬件模块, ...
谢谢前辈 怪不得 要好好看原理图了
