查看: 3530|回复: 3
温控系统的程序有错误一个,实在是找不出在哪了,跪求大神!!!
ID:70508 发表于 2014-12-16 09:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<stdio.h>
sbit ds=P2^6;    //ζè′«¸DÆ÷DÅoÅÏß
sbit smg=P0;     //êyÂë1üÏÔê¾
sbit smg1=P2;
sbit jdq=P1^7;    //¼ìμçÆ÷′®¿ú
uint temp;       //¶¨òåÕûDÎμÄζèêy¾Y
float f_temp;     //¶¨ò帡μãDíμÄζèêy¾Y
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x6d,0x7d,0x07,0x7f,0x6f,  //′øD¡êyμãμÄ12òõ0~9±àÂë
                            0xbf,0x86,0xdb,0xcf,0xe6,0xfd,0x87,0xff,0xef,};//2»′øD¡êyμãμÄ
void delay(uint z)
        uint x,y;
        for (x=z;x>0;x--)
             for(y=110;y>0;y--);
void dsreset()   //DS18B20μĸ′룬3õê¼»ˉoˉêy
        uint i;
        ds=0;
        i=103;
        while(i>0)
                i--;
        ds=1;
   i=4;
while(i>0)
    i--;
bit tempreadbit()   //¶á1λêy¾Yoˉêy
        uint i;
        bit dat;
        ds=0;i++;        //Ñóê±×÷óÃ
        dat=ds;
        i=8;
        while(i>0)
                i--;
                return(dat);
uchar tempreda()   //¶áò»¸ö×Ö½úêy¾Yoˉêy
        uchar i,j,dat;
        dat=0;
        for(i=1;i<=8;i++)
                j=tempreadbit();
                dat=(j<<7)|(dat>>1);   //¶á3öμÄêy¾Y×îμíλÔú×îÇ°Ãæ£¬ÕaÑù¸ÕoÃò»¸ö×Ö½úÔúdatàïÃæ
        return(dat);
void tempwritebyte(uchar dat)    //ÏòDS18B20D′ò»¸ö×Ö½úêy¾Yoˉêy
        uint i;
        uchar j;
        bit testb;
        for(j=1;j<=8;j++)
                testb=dat&0x01;
                dat=dat>>1;
                if(testb)
                        ds=0;
                        i++;
                        i++;
                        ds=1;
                        i=8;
                        while(i>0)i--;
                                ds=0;
                                i=8;
                                while(i>0)i--;
                                ds=1;
                                i++;i++;
void tempchange(void)      //DS18B20¿aê¼»ñè¡Î¶è2¢×a»»
        dsreset();
        delay(1);
         void tempwritebyte(0xcc);
         tempwritebyte(0x44);
uint get_temp()
        uchar a,b;
        dsreset();
        delay(1);
        tempwritebyte(0xbe);
        a=tempread();
        b=tempread();
        temp=b;
        temp<<=8;
        temp=temp|a;
        f_temp=temp*0.0625;
        temp=_f_temp*10+0.5;
        f_temp=f_temp+0.05;
        return temp;
void display(uchar num,uchar dat)
        uchar i;
        P0=0;
        P0=table[dat];
        P2=0;
        i=0xff;
        i=i&(~((0x01)<<(num)));
        P0=i;
        P2=0;
        delay(1);
void dis_temp(uint i)
        uchar i;
        i=1/100;
        display(0,1);
        i=t%100/10;
        display(1,i+10);
        i=t%100%10;
        display(2,i);
void deal(uint t)
        if(t<=11)
                P1^7=1;
        uchar buff[4],i;
                tempchange();
                for(i=10;i>0i--);
                        dis_temp(get_temp());
                deal(temp);
                sprintf(buff,"%f",f_temp);
                for(i=10;i>0;i--)
                        distemp(get_temp());
错误是
compiling wgkzxt.c...
WGKZXT.C(87): error C141: syntax error near 'void'
wgkzxt.c - 1 Error(s), 0 Warning(s).
ID:66032 发表于 2014-12-16 14:19 | 只看该作者
        dsreset();
        delay(1);
参与人数 1黑币 +7 收起 理由
xiaoyao + 7 回帖助人的奖励!
ID:66032 发表于 2014-12-16 14:21 | 只看该作者
                                          0xbf,0x86,0xdb,0xcf,0xe6,0xfd,0x87,0xff,0xef};
ID:70508 发表于 2014-12-16 15:40 | 只看该作者
谢谢你,问题已解决。
