查看: 3222|回复: 0
移动显示C语言程序
ID:70976 发表于 2014-12-26 23:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
      24MHZ的晶振,点线扫描地址为:0xFFFF
#include <reg51.h>
#include <stdio.h>
#include <intrins.h>
#include <ABSACC.h>
#define  uchar  unsigned char
#define  uint  unsigned int
#define  SPEED  6
uchar col, disrow;
uint  word;
uchar code HZ[];
uchar BUFF[6];
void  loadoneline(void);  //装载某行一线点阵数据
void  sendoneline(void);  //串行发送一行线点阵数据
/****************************主函数***************************/
void main(void)
        uchar i;
        col  = 0;
        word = 0;
        while(col <16)                          // 循环16次,点亮并移动一个汉字
        for(i=0; i <SPEED; i++)          //汉字在屏幕上的停留时间(即移动速度快慢)
        for(disrow=0;disrow <16;disrow++)//扫描16行
              loadoneline();            //装载一线点阵数据
              sendoneline();            //发送一线点阵数据
              XBYTE[0xFFFF]= 0x10 + disrow;      // 点亮屏幕
              XBYTE[0xFFFF] = 0x20 + disrow;      //锁住74LS595
                col++;         //列指针递增
                col = 0;
                word= word + 32;      // 一个汉字移动后,指向下一个汉字
                if(word >= 1600)
                        word = 0;      // 移动50个汉字后,重新开始
/****************用"字模"等软件提出要显示的字符汉字点阵码*************************/
uchar code HZ[]=
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
//0x08,0x20,0x06,0x30,0x04,0x40,0x3F,0xF8,0x21,0x08,0x3F,0xF8,0x21,0x08,0x21,0x08,
0x3F,0xF8,0x21,0x08,0x01,0x00,0xFF,0xFE,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,/*"
0x00,0x40,0x10,0x40,0x10,0x40,0x10,0x44,0x1F,0xFE,0x10,0x00,0x10,0x00,0x10,0x00,
0x1F,0xF0,0x10,0x10,0x10,0x10,0x10,0x10,0x20,0x10,0x20,0x10,0x40,0x10,0x80,0x10,/*"
0x10,0x00,0x10,0xF8,0x10,0x88,0xFE,0x88,0x10,0x88,0x10,0x88,0x38,0x88,0x34,0x88,
0x54,0x88,0x50,0x88,0x91,0x08,0x11,0x0A,0x12,0x0A,0x12,0x0A,0x14,0x06,0x10,0x00,/*"
0x00,0x00,0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x08,0x10,0x0F,0xF0,0x08,0x10,0x0F,0xF0,
0x
