查看: 4975|回复: 0
单片机数码管静态显示实验
ID:72519 发表于 2015-1-21 23:31 | 显示全部楼层 |阅读模式
是用51hei单片机开发板 电路图详见:http://www.51hei.com/f/51hei-5.pdf  的数码管部分, 用2个74hc573 锁存,p0口作为数据口 ,注意图中要改一下p3.6和p3.7分别是段和位的锁存端口.P2口上面是按键 p1口上面是8个led灯.
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. uchar code DIS_SEG7[16]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  5. uchar code DIS_BIT[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
  6. sbit D=P3^6;
  7. sbit V=P3^7;
  8. //==============
  9. void delay(uint k)
  10. {
  11. uint data i,j;
  12. for(i=0;i<k;i++){
  13. for(j=0;j<121;j++)
  14. {;}}
  15. }
  16. //=================
  17. void main(void)
  18. {
  19. D=1;P0=DIS_SEG7[8];D=0;P0=0xff;V=1;P0=DIS_BIT[0];V=0;
  20. while(1)
  21. {
  22. P1=~P1;
  23. delay(500);
  24.       }
  25. }
