查看: 6497|回复: 0
利用Eclipse IDE for C/C++ Developers和GNU Tools ARM Embedded编译器
工作环境说明:
1.硬件平台: DX开发板主板 + DX103核心板
2.硬件平台: Eclipse IDE for C/C++ Developers + GNU Tools ARM Embedded
  (1) IDE:    Eclipse IDE for C/C++ Developers
  (2) 编译器: GNU Tools ARM Embedded编译器,支持STM32F407最新的HAL驱动库
用Eclipse IDE for C/C++ Developers新建一个C工程模板,主函数代码如下:
// This file is part of the GNU ARM Eclipse distribution.
// Copyright (c) 2014 Liviu Ionescu.
#include <stdio.h>
#include "diag/Trace.h"
#include "Timer.h"
#include "BlinkLed.h"
// STM32F4 led blink sample (trace via ITM).
// In debug configurations, demonstrate how to print a greeting message
// on the trace device. In release configurations the message is
// simply discarded.
// To demonstrate POSIX retargetting, reroute the STDOUT a.n.d STDERR to the
// trace device a.n.d display messages on both of them.
// Then demonstrates how to blink a led with 1Hz, using a
// continuous loop a.n.d SysTick delays.
// On DEBUG, the uptime in seconds is also displayed on the trace device.
// Trace support is enabled by adding the TRACE macro definition.
// By default the trace messages are forwarded to the ITM output,
// but can be rerouted to any device o.r completely suppressed, by
// changing the definitions required in system/src/diag/trace_impl.c
// (currently OS_USE_TRACE_ITM, OS_USE_TRACE_SEMIHOSTING_DEBUG/_STDOUT).
// ----- Timing definitions -------------------------------------------------
// Keep the LED on for 2/3 of a second.
#define BLINK_ON_TICKS  (TIMER_FREQUENCY_HZ * 2 / 3)
#define BLINK_OFF_TICKS (TIMER_FREQUENCY_HZ - BLINK_ON_TICKS)
// ----- main() ---------------------------------------------------------------
// Sample pragmas to cope with warnings. Please note the related line at
// the end of this function, used to pop the compiler diagnostics status.
#pragma GCC diagnostic push
#pragma GCC diagnostic ignored "-Wunused-parameter"
#pragma GCC diagnostic ignored "-Wmissing-declarations"
#pragma GCC diagnostic ignored "-Wreturn-type"
* 大虾开发板的5个LED指示灯对应的GPIO
* PA0:  LED1
* PB0:  LED2
* PB14: LED3
* PD13: LED4
* PD12: LED5
* 大虾开发板的按键对应的GPIO
* PB10: K1
* PC2:  K2
int main(int argc, char* argv[])
  // By customising __initialize_args() it is possible to pass arguments,
  // for example when running tests with semihosting you can pass various
  // options to the test.
  // trace_dump_args(argc, argv);
  // Send a greeting to the trace device (skipped on Release).
  trace_puts("Hello ARM World!");
  // The standard output a.n.d the standard error should be forwarded to
  // the trace device. For this to work, a redirection in _write.c is
  // required.
  puts("Standard output message.");
  fprintf(stderr, "Standard error message.");
  // At this stage the system clock should have already been configured
  // at high speed.
  trace_printf("System clock: %uHz", SystemCoreClock);
  timer_start();
  blink_led_init();
  uint32_t seconds = 0;
  while (1)
//      blink_led_on();
      timer_sleep(BLINK_ON_TICKS);
//      blink_led_off();
      timer_sleep(BLINK_OFF_TICKS);
      ++seconds;
      HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_0);
      HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_0);
      HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_14);
      HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_13);
      HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_12);
      // Count seconds on the trace device.
      trace_printf("Second %u", seconds);
#pragma GCC diagnostic pop
// 在BlinkLed.c中初始化DX开发板的5个LED指示灯,以及K1、K2键对应的GPIO
// 用STM32CubeMX生成的两个中断函数整个拷贝过来
void blink_led_init()
  // Enable GPIO Peripheral clock
  RCC->AHB1ENR |= RCC_AHB1ENR_GPIOAEN;
  RCC->AHB1ENR |= RCC_AHB1ENR_GPIOBEN;
  RCC->AHB1ENR |= RCC_AHB1ENR_GPIODEN;
  GPIO_InitTypeDef GPIO_InitStructure;
  // Configure pin in output push/pull mode
  GPIO_InitStructure.Pin  = GPIO_PIN_0;
  GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStructure.Speed = GPIO_SPEED_FAST;
  GPIO_InitStructure.Pull = GPIO_PULLUP;
  HAL_GPIO_Init(GPIOA, &GPIO_InitStructure);
  HAL_GPIO_Init(GPIOB, &GPIO_InitStructure);
  GPIO_InitStructure.Pin  = GPIO_PIN_14;
  GPIO_InitStructure.Pin  = GPIO_PIN_13 | GPIO_PIN_12;
  HAL_GPIO_Init(GPIOD, &GPIO_InitStructure);
  /*Configure GPIO pin : PB10 */
  GPIO_InitStructure.Pin = GPIO_PIN_10;
  GPIO_InitStructure.Mode = GPIO_MODE_IT_FALLING; /* 下降沿中断 */
  /* EXTI interrupt init */
  HAL_NVIC_SetPriority(EXTI15_10_IRQn, 0, 0);
  HAL_NVIC_EnableIRQ(EXTI15_10_IRQn);
// 以下两个中断函数由stm32cubemx软件自动生成,很方便
* @brief This function handles EXTI Line[15:10] interrupts.
void EXTI15_10_IRQHandler(void)
  /* USER CODE BEGIN EXTI15_10_IRQn 0 */
  /* USER CODE END EXTI15_10_IRQn 0 */
  HAL_GPIO_EXTI_IRQHandler(GPIO_PIN_10); /* 此处设置断点,全速运行,然后按下K1,就能到达这里 */
  /* USER CODE BEGIN EXTI15_10_IRQn 1 */
  /* USER CODE END EXTI15_10_IRQn 1 */
* @brief This function handles EXTI Line2 interrupt.
void EXTI2_IRQHandler(void)
  /* USER CODE BEGIN EXTI2_IRQn 0 */
  /* USER CODE END EXTI2_IRQn 0 */
  HAL_GPIO_EXTI_IRQHandler(GPIO_PIN_2); /* 此处设置断点,全速运行,然后按下K2,就能到达这里 */
  /* USER CODE BEGIN EXTI2_IRQn 1 */
  /* USER CODE END EXTI2_IRQn 1 */
【图片】进入KEY1按键中断(PB10).jpg,在中断函数中设置断点,全速运行,然后按开发板的K1键
