查看: 7783|回复: 0
基于VB实现单片机控制步进电机有了单片机的程序,谁会VB的编程
ID:75795 发表于 2015-5-6 10:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "reg52.h"
#include "INTRINS.H"
#include <absacc.h>
#include <math.h>
void check_addr(void); /*地址核对*/
uchar code slave_addr[4]={00, 01, 02, 255};      /*从机地址*/
uchar idata T0low, T0high,common_count,input_order,cmd_in_permit,interval; uchar sent_ok,speed_change,start_up,start_end,address_true,i;
uint y1;
uint code add[100]={60006,62771,63693,64154,64430,64614,64746,64845,64922,64983,65033,65075,65111,65141,65167,65190,65211,65229,65245,65260,65273,65285,65296,65306,65315,65323,65331,65339,65345,65352,65358,65363,65368,65373,65378,65382,65387,65390,65394,65398,65401,65404,65407,65410,65413,65416,65418,65421,65423,65425,65428,65430,65432,65434,65435,65437,65439,65441,65442,65444,65445,65447,65448,65450,65451,65452,65453,65455,65456,65457,65458,65459,65460,65461,65462,65463,65464,65465,65466,65467,65468,65469,65469,65470,65471,65472,65472,65473,65474,65475,65475,65476,65477,65477,65478,65478,65479,65480,65480,65481};
sbit P2_0=P2^0;  /*作输入步进电机的脉冲信号发送口*/
sbit P2_2=P2^2;  /*作输入步进电机的旋转方向信号发送口*/
sbit P1_0=P1^0;  /*作串口输出信号的使能口, P1_0=0时接通串口,输出信号*/
sbit WD=P1^7;   /*看门狗*/
main()
{   P2_0=0;
P2_2=0;  /*步进电机的旋转方向待试验后确定*/
P1_0=1; /*开机时需要关断,串口发送功能,需要时再接通*/
WD=1;           /*看门狗先为1,电平翻转为喂狗*/
i=0;
common_count=0;
cmd_in_permit=0;
input_order=0;
interval=0;
address_true=1;
speed_change=0;
start_up=0;
start_end=0;  sent_ok=0;      //允许发送
EA=1; /*开放总中断*/
TMOD=0x21;
TH1 = 0xFD;   // 波特率9600
TL1 = 0xFD;
SCON = 0xd0;   // 设定串行口工作方式
PCON &= 0x00;   // 波特率不倍增
SM2=1;
TR1 = 1;
ES=1;           // 启动定时器1
T2MOD=00;
T2CON=0x00;
RCAP2H =0xEE;                //赋T2的预置值0xA600,25MS,0xB800,20MS,0xCA00,15MS,0xDC00,10MS,0xEE00,5MS  RCAP2L =0x00;
        TR2=1;                       //启动定时器
        ET2=1;                       //打开定时器2中断
do {
         if(address_true==1)
address_true=0;    check_addr();
         if(start_up==1&&start_end==0)           //第一次启动
        y1=add[common_count];
T0high = (uchar)(y1>>8) ;  /*取y1的高8位*/
T0low = (uchar)(y1&0x00ff);  /*取y1的低8位*/
TR0 = 1;  ET0=1; /*允许T/C0中断*/
start_end=1;
if(speed_change==1)
if(interval>=0&&interval<=0x63)
if(interval>common_count)
common_count=common_count+1;
if(interval<common_count)
common_count=common_count-1;
speed_change=0;
if(sent_ok==1)
sent_ok=0;
P1_0=0;
for(i=0;i<=20;i++) {_nop_();}
TI=0; SBUF=T0high;
while(TI==0);TI=0;
TI=0; SBUF=T0low;
while(TI==0);TI=0;
P1_0=1;
SM2=1;
while(1);
void timer0(void) interrupt 1 using 3
P2_0=~P2_0;
T0high = (uchar)(y1>>8);   /*取y1的高8位*/
TH0=T0high; /*高8位T0high送定时器0的TH0*/
TL0=T0low; /*低8位T0low送定时器0的TL0*/  }
void timer2(void) interrupt 5 using 2   {
    TF2=0; /*T2溢出中断需软件清0*/
speed_change=1;    //速度可以改变标示,以便主程序处理
WD=!WD; /*MAX813喂狗*/
void inte_SERIAL() interrupt 4 using 1  /*串口0中断服务子程序*/
uchar key_in   key_in=0;
if(RI)
key_in=SBUF;
RI=0;
if (SM2==1)
  if(key_in==slave_addr[2])
SM2=0;
address_true=1;
if ((SM2==0)&& (RB8==0))
  if(key_in==0xff){SM2=1;
if(key_in==0xfe)
{ /*接收主机命令引导字节,准备接收主机命令*/
cmd_in_permit=1;
if(cmd_in_permit==1)
  {    input_order=input_order+1;     }
  if (input_order==2)     { /*接收主机命令,使从机开始调节电机*/
cmd_in_permit=0;
  input_order=0;     /*interval代表控制器发给电机的转速期望值*/
  interval= key_in;
sent_ok=1;
if(start_up==0){start_up=1;
{ /*地址核对成功,发送从机地址给主机*/
TB8=1;
RB8=0;
P1_0=0;
for(i=0;i<=25;i++) {_nop_();}
SBUF=slave_addr[2]; /*发送地址核对成功,发送从机地址给主机*/
do{} while(TI==0); TI=0;
P1_0=1;
TB8=0;
