查看: 5917|回复: 11
51单片机郭天祥的I2C总线程序proteus仿真为什么总是一闪一闪的。
ID:85124 发表于 2015-7-9 10:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1.         #include<reg51.h>
  2.         #define uchar unsigned char
  3.         #define uint unsigned int
  4.         bit write=0;
  5.         sbit sda=P2^0;
  6.         sbit scl=P2^1;
  7.         sbit dula=P2^6;
  8.         sbit wela=P2^7;
  9.         uchar sec,tcnt;
  10.         uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x7c,0x39,0x5e,0x79,0x71};
  11.         void delay()
  12.         {  ; ;}
  13.         void delay1ms(uint z)
  14.         {
  15.         uint x,y;
  16.         for(x=z;x>0;x--)
  17.         for(y=110;y>0;y--);
  18.         }
  19.         void start()
  20.         {
  21.         sda=1;
  22.         delay();
  23.         scl=1;
  24.         delay();
  25.         sda=0;
  26.         delay();
  27.         }
  28.         void stop()
  29.         {
  30.         sda=0;
  31.         delay();
  32.         scl=1;
  33.         delay();
  34.         sda=1;
  35.         delay();
  36.         }
  37.         void respons()
  38.         {
  39.         uchar i;
  40.         scl=1;
  41.         delay();
  42.         while((sda==1)&&i<250)
  43.         i++;
  44.         scl=0;
  45.         delay();
  46.         }
  47.         void init()
  48.         {
  49.         sda=1;
  50.         delay();
  51.         scl=1;
  52.         delay();
  53.         }
  54.         void write_byte(uchar date)
  55.         {
  56.         uchar i,temp;
  57.         temp=date;
  58.         for(i=0;i<8;i++)
  59.         {
  60.         temp=temp<<1;
  61.         scl=0;
  62.         delay();
  63.         sda=CY;
  64.         delay();
  65.         scl=1;
  66.         delay();
  67.         }
  68.         scl=0;
  69.         delay();
  70.         sda=1;
  71.         delay();
  72.         }
  73.     uchar read_byte()
  74.         {
  75.         uchar i,k;
  76.
  77.         scl=0;
  78.         delay();
  79.         sda=1;
  80.         delay();
  81.         for(i=0;i<8;i++)
  82.         {
  83.         scl=1;
  84.         delay();
  85.         k=(k<<1)|sda;
  86.         scl=0;
  87.          delay();
  88.          }
  89.          return k;
  90.          }
  91.          void write_add(uchar address,uchar date)
  92.          {
  93.       start();
  94.           write_byte(0xa0);
  95.           respons();
  96.           write_byte(address);
  97.           respons();
  98.           write_byte(date);
  99.           respons();
  100.           stop();
  101.           }
  102.           uchar read_add(uchar address)
  103.           {
  104.           uchar date;
  105.           start();
  106.           write_byte(0xa0);
  107.           respons();
  108.           write_byte(address);
  109.           respons();
  110.           start();
  111.           write_byte(0xa1);
  112.           respons();
  113.           date=read_byte();
  114.           stop();
  115.           return date;
  116.           }
  117.           void display(uchar bai_c,uchar sh_c)
  118.           {
  119.           dula=0;
  120.           P0=table[bai_c];
  121.           dula=1;
  122.           dula=0;
  123.           wela=0;
  124.           P0=0x7e;
  125.           wela=1;
  126.           wela=0;
  127.           delay1ms(5);
  128.           dula=0;
  129.           P0=table[sh_c];
  130.            dula=1;
  131.           dula=0;
  132.           wela=0;
  133.           P0=0x7d;
  134.           wela=1;
  135.           wela=0;
  136.           delay1ms(5);
  137.           }
  138.           void main()
  139.           {
  140.           init();
  141.           sec=read_add(2);
  142.           if(sec>100)
  143.           sec=0;
  144.           TMOD=0x01;
  145.           ET0=1;
  146.           EA=1;
  147.           TH0=(65536-50000)/256;
  148.           TL0=(65536-50000)%256;
  149.           TR0=1;
  150.           while(1)
  151.           {
  152.          display(sec/10,sec%10);
  153.           if(write==1)
  154.           {
  155.           write=0;
  156.           write_add(2,sec);
  157.           }
  158.           }
  159.           }
  160.           void t0() interrupt 1
  161.           {
  162.                 TH0=(65536-50000)/256;
  163.           TL0=(65536-50000)%256;
  164.           tcnt++;
  165.           if(tcnt==20)
  166.           {
  167.           tcnt=0;
  168.           sec++;
  169.           write=1;
  170.           if(sec==100)
  171.           sec=0;
  172.           }
  173.           }
实现断电保护功能的程序.zip
54.23 KB, 下载次数: 11
收藏收藏2 分享淘帖 顶 踩
ID:535242 发表于 2020-2-22 11:28 | 只看该作者
我也是仿真这个 数据根本无法保存啊。
ID:535242 发表于 2020-2-22 11:29 | 只看该作者
你找到问题所在了吗 求解答
ID:535242 发表于 2020-2-22 11:50 | 只看该作者
把数码管显示子函数改成这样
                P0=0x00;
                dula=1;
                P0=table[bai_c];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfe;
                wela=0;
                delay1ms(5);
                P0=0x00;
                dula=1;
                P0=table[sh_c];
                dula=0;
                P0=0xff;
                wela=1;
                P0=0xfd;
                wela=0;
                delay1ms(5);
ID:94031 发表于 2020-2-22 15:07 | 只看该作者
不要去追求仿真与实物现象一致,仿真只是方便实物前的测试,不一定完全接近实物,最终应以实物为准。
ID:679425 发表于 2020-2-22 16:39 | 只看该作者
仿真只是理论上的测试,不一定完全接近实物
ID:696129 发表于 2020-3-3 15:26 | 只看该作者
因为CPU的负荷,proteus仿真的时间和现实要慢,所以你在实验板上面不闪在proteus上看到会闪
ID:701939 发表于 2020-3-4 00:07 | 只看该作者
估计是仿真软件的BUG吧,发现好像好多仿真出现的现象都不太一致
ID:702173 发表于 2020-3-4 11:03 | 只看该作者
最近也出现老是报错,不知道如何解决
ID:332444 发表于 2020-3-4 17:50 | 只看该作者
只有段的数组,缺少控制位数组。
ID:716711 发表于 2020-4-5 16:10 | 只看该作者
unsigned char write_byte(uchar date)
        uchar i,b,temp;
        temp=date;
        for(i=0;i<8;i++)
                sda=temp>>7;        //起始信号 已经将scl=0,
                Delay10us();
                temp=temp<<1;
                scl=1;       // scl=1 ,sda数据 被对方接收。
                Delay10us();
    scl=0;
                Delay10us();
                sda=1;  //写完数据 将sda 拉为高电平
          Delay10us();
                scl=1;  //写完数据 将SDA和SCL 都为1表示总线 空闲
                while(sda) //等待应答,也就是等待从设备把SDA拉低
     {         // 设备一旦回应,sda=0,结束循环。
                         b++;
                         if(b>200) // 设备2000us 没有回应,或者为非应答,表示接收结束
                                 scl=0;
                                 Delay10us();
                                 return 0;
                        scl=0;
                  Delay10us();
                  return 1;
ID:716711 发表于 2020-4-5 16:12 | 只看该作者
借鉴其他人的程序,修改了写这部分,用CY位 怎么也无法写入数据,但是这种右移读取一位的方式 在开发板上实现了写和读。
