查看: 4287|回复: 1
分享制作摇摇棒的资料!做了一个,很好看!
#include <STC11F60XE.h>
/*********外部接口定义**********/
#define uint unsigned int    //宏定义
#define out P1 //数据输出端口
sbit led1=P3^0; //第1组LED
sbit led2=P3^1; //第2组LED
sbit led3=P3^3; //第3组LED
sbit led4=P3^4; //第4组LED
sbit key1=P3^5;  //按键输入
sbit p3_2=P3^2;
uchar KY;      //KY作用在后面说明
uchar BUFF;              //缓存
/*********全局变量定义**********/
unsigned long int TimeCount=0;
unsigned int  DelayN=80,  //延时临时计数
    DelayTime=80; //每次延时的周期个数
unsigned char key;
void delay(unsigned char n);
void DelayMs(void);
unsigned char code text1[] = {
0xEF,0x7F,0xEF,0xBC,0x0F,0xDD,0xE0,0xEB,0xEF,0xF3,0x0F,0x8C,0x7F,0xDF,0x7D,0xFF,0x7D,0xBF,0x7D,0x7F,0x0D,0x80,0x75,0xFF,0x79,0xFF,0x7D,0xFF,0x7F,0xFF,0xFF,0xFF,/*"好",0*/
0xEF,0x7F,0xEF,0xBC,0x0F,0xDD,0xE0,0xEB,0xEF,0xF3,0x0F,0x8C,0x7F,0xDF,0x7D,0xFF,0x7D,0xBF,0x7D,0x7F,0x0D,0x80,0x75,0xFF,0x79,0xFF,0x7D,0xFF,0x7F,0xFF,0xFF,0xFF,/*"好",1*/
0xBF,0xFF,0xCF,0xFD,0xEF,0xFD,0xED,0xFD,0xA3,0xFD,0xAB,0xFD,0xAF,0xBD,0xAE,0x7D,0xA1,0x80,0x2B,0xFD,0xAF,0xFD,0xE7,0xFD,0xA8,0xFD,0xCD,0xFD,0xEF,0xFD,0xFF,0xFF,/*"学",2*/
0xFF,0xFF,0xFF,0xFF,0xFD,0xFB,0xFD,0xF3,0xF5,0xFB,0xED,0xFD,0xDD,0xFD,0x9D,0xFE,0xFD,0xFE,0x7D,0xFF,0x7D,0xDF,0xBD,0xBF,0xFD,0x7F,0x01,0x80,0xFF,0xFF,0xFF,0xFF,/*"习",3*/
0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",4*/
0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",5*/
0xFF,0xFF,0xFF,0xFF,0x03,0x80,0xFB,0xFF,0xFB,0xFF,0x19,0xF0,0xDA,0xFB,0xDB,0xFB,0xDB,0xFB,0xDB,0xFB,0x1B,0xF0,0xFB,0xDF,0xFB,0xBF,0x03,0xC0,0xFF,0xFF,0xFF,0xFF,/*"向",6*/
0xFF,0xFF,0xFF,0xBF,0xFF,0xBF,0xFF,0xBF,0xFF,0xBF,0xFF,0xBF,0xFF,0xBF,0x01,0x80,0xBF,0xBF,0xBF,0xBF,0xBF,0xBF,0xBF,0xBF,0xBF,0xBF,0xFF,0x9F,0xFF,0xBF,0xFF,0xFF,/*"上",7*/
unsigned char code text2[]={
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0x00,0xB7,0xBB,0xB7,0xBB,0xB3,0xBB,0xB4,0xBB,0xB5,0xBB,0xB7,0xBB,0xB7,0xBB,0xB7,0xBB,0x07,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"自",0*/
0xBF,0xBF,0xBE,0xDF,0x39,0xE0,0xFF,0xDF,0xEF,0xBF,0xEF,0xBF,0x6D,0xB0,0x6D,0xB7,0x6D,0xB7,0x01,0xB7,0x6E,0xB7,0x6E,0xB7,0x6E,0xB0,0xEF,0xBF,0xEF,0xBF,0xFF,0xFF,/*"适",1*/
0xFF,0xBF,0xFF,0xC7,0x03,0xF8,0xBB,0xDF,0x7B,0xDF,0xFB,0xD0,0xEB,0xDB,0xDA,0xDF,0x39,0xDC,0x7B,0xCF,0xFB,0xD3,0xFB,0xDC,0x1B,0xDF,0xBB,0xDF,0xFF,0xDF,0xFF,0xFF,/*"应",2*/
0xBF,0xBF,0xBD,0xDF,0x33,0xE0,0xFF,0xDF,0xFB,0xB7,0x1B,0xB6,0xDB,0xBA,0xDB,0xBC,0x00,0x80,0xDB,0xBE,0xDB,0xBC,0xDB,0xBA,0x1B,0xB2,0xFB,0xBF,0xFF,0xBF,0xFF,0xFF,/*"速",3*/
0xFF,0x7F,0xFF,0x9F,0x03,0xE0,0xFB,0x7F,0xDB,0x7F,0xDB,0xBD,0x03,0xB9,0x5A,0xD5,0x59,0xED,0x5B,0xED,0x03,0xD5,0xDB,0xD9,0xDB,0xBD,0xDB,0x3F,0xFB,0xBF,0xFF,0xFF,/*"度",4*/
0xEF,0xFB,0xEF,0xBB,0xEF,0x7D,0x00,0x80,0x6F,0xFF,0xAF,0xFD,0x75,0x05,0x8D,0xBD,0xB9,0xBD,0xA5,0xBD,0x3D,0x80,0x9E,0xBD,0xAE,0xBD,0xB6,0xBD,0xFF,0x05,0xFF,0xFF,/*"摇",5*/
0xEF,0xFB,0xEF,0xBB,0xEF,0x7D,0x00,0x80,0x6F,0xFF,0xAF,0xFD,0x75,0x05,0x8D,0xBD,0xB9,0xBD,0xA5,0xBD,0x3D,0x80,0x9E,0xBD,0xAE,0xBD,0xB6,0xBD,0xFF,0x05,0xFF,0xFF,/*"摇",6*/
0xEF,0xFC,0x2F,0xFF,0x00,0x00,0xAF,0xFF,0x6F,0xFD,0xBB,0xF5,0xAB,0xF6,0x2B,0xF5,0x8B,0xF5,0xA0,0x00,0x2B,0xF5,0xAB,0xF4,0xAB,0xF6,0xBB,0xF5,0xBF,0xFD,0xFF,0xFF,/*"棒",7*/
unsigned char code text3[]={
0xFF,0xFF,0xBF,0x7F,0xBD,0xBF,0xBD,0xDF,0xBD,0xEF,0xBD,0xF7,0xBD,0xF9,0x01,0xFE,0xBD,0xFD,0xBD,0xFB,0xBD,0xF7,0xBD,0xEF,0xBD,0xCF,0xBD,0x9F,0xBF,0xDF,0xFF,0xFF,/*"天",0*/
0xBF,0xBF,0xBD,0xDF,0x33,0xE0,0xFF,0xDF,0xFB,0xBF,0xFB,0xBF,0x1A,0xA0,0x49,0xB5,0x53,0xB5,0x5B,0xB5,0x59,0xB5,0x1A,0xA0,0xFB,0xBF,0xFB,0xBF,0xFF,0xBF,0xFF,0xFF,/*"道",1*/
0x0E,0x80,0xEE,0xDA,0x00,0xDB,0xEE,0xDB,0x00,0xDB,0x6E,0xDB,0x0E,0x80,0xDE,0xDF,0x01,0xE0,0xDF,0xFF,0xBF,0xFF,0x01,0x80,0xDF,0xFF,0xBF,0xFF,0x00,0x80,0xFF,0xFF,/*"酬",2*/
0xFB,0xFF,0xFB,0x7F,0x3B,0x6A,0xA0,0x6A,0xAB,0x6A,0x0B,0x80,0xAB,0xAA,0xA0,0xAA,0x3B,0x6A,0xEB,0x9F,0xEF,0xE3,0x00,0xFC,0xEF,0xDF,0xEF,0x9F,0x0F,0xC0,0xFF,0xFF,/*"勤",3*/
0xFF,0xBF,0xFF,0xCF,0x00,0xF0,0xFE,0xFF,0x82,0xF6,0xAA,0xF6,0xAA,0xB6,0xAA,0x76,0xAA,0x82,0xAA,0xF2,0xAA,0xF4,0xAA,0xF4,0x82,0xF6,0xFE,0xF7,0xFF,0xFF,0xFF,0xFF,/*"厚",4*/
0xEF,0xFD,0xF7,0xFE,0x7B,0xFF,0x1C,0x00,0xE5,0xFF,0xFF,0xFD,0xA0,0xFD,0xAA,0xC5,0xAA,0xFD,0xAA,0xBD,0xAA,0x7D,0x2A,0x80,0xA0,0xFD,0xBF,0xFD,0xBF,0xFD,0xFF,0xFF,/*"得",5*/
0xEF,0xFF,0xAF,0xED,0xAB,0xEC,0x2B,0xED,0x8B,0xED,0xA0,0x00,0xAB,0xF5,0xAB,0xB5,0xEF,0xDF,0x00,0xEF,0xEF,0xF0,0xED,0xE3,0xEB,0xDC,0x2F,0xBF,0xEF,0xCF,0xFF,0xFF,/*"载",6*/
0xBF,0xFB,0xC3,0xFB,0xEF,0xFD,0x00,0x80,0xEF,0xFE,0x2F,0xBB,0xDF,0xDD,0xE7,0xEE,0x30,0xF7,0xC7,0xFB,0xF7,0xBC,0x07,0x7F,0xF7,0xBF,0x07,0xC0,0xFF,0xFF,0xFF,0xFF,/*"物",7*/
unsigned char code text4[]={
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0xFF,0xFF,0xF7,0xFB,0xFF,0xFF,0xF7,0xFB,0xFF,0xFF,0xF7,0x03,0x00,0x00,0xF0,0xFB,0xFF,0xFF,0xF7,
0xFB,0xFF,0xFF,0xF7,0xFB,0xFF,0xFF,0xF7,0xFB,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x1F,0x80,0xFF,0xFF,0x07,0x00,0xFE,0xFF,0x07,0x00,0xFC,0xFF,0x03,0x00,0xF8,0xFF,0x03,0x00,0xF0,0xFF,
0x03,0x00,0xC0,0xFF,0x03,0x00,0xC0,0xFF,0x03,0x00,0x80,0xFF,0x07,0x00,0x00,0xFF,0x1F,0x00,0x00,0xFE,0x3F,0x00,0x00,0xFC,0x3F,0x00,0x00,0xF8,0x3F,0x00,0x00,0xF0,
0x3F,0x00,0x00,0xF0,0x3F,0x00,0x00,0xF8,0x1F,0x00,0x00,0xFC,0x0F,0x00,0x00,0xFE,0x07,0x00,0x00,0xFE,0x03,0x00,0x00,0xFF,0x03,0x00,0x80,0xFF,0x03,0x00,0xE0,0xFF,
0x07,0x00,0xF0,0xFF,0x07,0x00,0xF8,0xFF,0x07,0x00,0xFC,0xFF,0x0F,0x00,0xFF,0xFF,0x1F,0x80,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0x03,0x00,0x00,0xF0,0x03,0x00,0x00,0xE0,0xFF,0xFF,0xFF,0xE3,0xFF,0xFF,0xFF,0xEF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,
0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xCF,0xFF,0xFF,0xFF,0xE3,0x07,0x00,0x00,0xF0,0x07,0x00,0x00,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"未命名文件",0*/
unsigned char code text5[]={
0xFF,0xFF,0xFF,0xFF,0xFF,0xFB,0x9F,0xBF,0xFF,0xF9,0x9F,0xBF,0xFF,0xF9,0xCF,0x3F,0xFF,0xF9,0xCF,0x3F,0x07,0x00,0x00,0x00,0x07,0x00,0x00,0x80,0xFF,0xF9,0xF3,0xFF,
0xFF,0xF9,0xF9,0xFF,0xFF,0xF9,0xFC,0xFF,0xFF,0xFB,0xBF,0xFF,0xFF,0xFF,0x93,0xFF,0x9F,0xFF,0x99,0x80,0x9F,0xFC,0x98,0x9F,0x9F,0x71,0x9C,0x3F,0x9F,0x27,0x9E,0x3F,
0x9F,0x1F,0x9E,0x3F,0x9F,0x7F,0x9E,0x3F,0xDF,0x7F,0x9E,0x3F,0xDF,0x7C,0x9E,0x3F,0xDF,0x60,0x00,0x00,0xDF,0x67,0x9E,0x3F,0xCF,0x7F,0x9E,0x3F,0xCF,0x7F,0x9E,0x3F,
0xCF,0x7F,0x9E,0x3F,0xEF,0x67,0x9E,0x3F,0xE7,0x61,0x9E,0x3F,0x67,0x78,0x9E,0x81,0x27,0xFE,0x9E,0xC1,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,0xFF,0xFF,/*"摇",0*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,0xFF,0x0F,0xF8,0x3F,0x7F,0x80,0xFF,0x9F,0xFF,0xFF,0xFF,0xC7,0xFF,0xFF,0xFF,0xE1,0x07,0x00,0x00,0xF8,0x07,0x00,0x00,0xFF,
0xFF,0x1F,0x7F,0xFE,0xFF,0xC3,0xFF,0xF8,0x7F,0xF0,0xFF,0xE1,0x3F,0xFE,0xFF,0xC7,0xFF,0xFF,0xFF,0xDF,0x9F,0xFF,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,
0x9F,0xFF,0xFF,0xDF,0x9F,0xFF,0xFF,0xDF,0x9F,0xFF,0xFF,0x9F,0x9F,0xFF,0xFF,0x9F,0x9F,0xFF,0xFF,0xBF,0x9F,0xFF,0xFF,0xBF,0x9F,0xFF,0xFF,0xBF,0x9F,0xFF,0xFF,0xBF,
0x1F,0x00,0x00,0x80,0x1F,0x00,0x00,0xC0,0x9F,0xFF,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,0x9F,0xFF,0xFF,0xFF,0xBF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,/*"灯",1*/
/***********n(us)延时子程序***************/
void DelayUs(uint N)
uint x;
for(x=0; x<=N;x++);
AUXR=0x80;
CLK_DIV=0;
EX0=1; //开放外部中断0
IT0=1; //中断0为边沿触发方式
IP=0x02; //设置中断优先级
TMOD=0x02; //定时器0方式2,8位重装载
TH0=0x80; //设定定时器初值
TL0=0x80;
KY=0;
EA=1;  //开放中断
ET0=1; //开放定时器1中断
TR0=1; //启动定时器0,开始计时*/
key=0; //初始化显示第一组文字
P1M0=0x55;   //0101 0101 /P1.0  P1 .2 P1.4 P1.6推挽输出
    P1M1=0xAA;
while(1){//等待中断
  if(key1==0){
   DelayUs(200); //按键去抖处理
   if(key1==0){   //有键按下
    key++;    //更换下一幅图片
    if(key==5) key=0; //图片循环显示
    while(key1==0);  //等待按键释放
/*********文字显示子程序**********/
void display_word(unsigned char code *text)
{ char i,j=2;          //j为图片起始位置 2 为第3个开始是图片 如果要显示32*32大字 也属于图片格式
    DelayUs(5000);
for(i=0;i<64;i++)
        P3M0=0x00;   //0000 0000 //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
     P3M1=0x1B;
  if(key>j)
  BUFF=(*(text+i*4+3));
  BUFF=(*(text+128+i*2+1));
  led4=0;
  P1=~BUFF>>1;
  P3M0=0x10;   //0001 0000 //P3.4推挽输出 P3 .0 P3.3 P3.1输入高阻
     P3M1=0x0B;          //0000 1011
   delay(1);
     P3M1=0x1B;    //0001 1011
  led4=1;
      P1=BUFF;             //01010101  1357
   delay(1);
  if(key>j)
  BUFF=(*(text+i*4+2));
     BUFF=(*(text+128+i*2));
  led3=0;
  P1=~BUFF>>1;
  P3M0=0x08;   //0000 1000 //P3.3推挽输出 P3 .0 P3.1 P3.4输入高阻
     P3M1=0x13;          //0001 0011
  delay(1);
  led3=1;
   delay(1);
     P3M1=0x1B;
  if(key>j)
  BUFF=(*(text+i*4+1));
  BUFF=(*(text+i*2+1));
  led2=0;
     P1=~BUFF>>1;
  P3M0=0x02;   //0000 0010 //P3.1推挽输出 P3 .0 P3.3 P3.4输入高阻
     P3M1=0x19;   //0001 1001
  delay(1);
  led2=1;
   delay(1);
     P3M1=0x1B;    //0001
  if(key>j)
  BUFF=(*(text+i*4));
  BUFF=(*(text+i*2));
  led1=0;
  P1=~BUFF>>1;
  P3M0=0x01;   //0000 0001 //P3.0推挽输出 P3 .1 P3.3 P3.4输入高阻
     P3M1=0x1A;    //0001 1010
  delay(1);
  led1=1;
   delay(1);
/*********显示内容选择子程序**********/
void display(unsigned char t)
switch (t){  //通过按键选择显示内容
  case 0: {display_word(text1);}break;
  case 1: {display_word(text2);}break;
  case 2: {display_word(text3);}break;
  case 3: {display_word(text4);}break;
  case 4: {display_word(text5);}break;
  //default:{display_word(text1);}
/*********延时子程序**********/
for(;n>0;n--){
  DelayN=DelayTime;
  while (DelayN);
/*********中断子程序**********/
void int0() interrupt 0 //使用外部中断0
KY=~KY;
if(KY==0)
DelayTime=TimeCount/1580;
TimeCount=0; //延时周期计数清零
display(key); //根据按键选择循环显示文字
void timer0() interrupt 1  //定时器0中断子程序
TimeCount++;
if (DelayN!=0)
DelayN--;
ID:86938 发表于 2015-8-6 16:18 | 只看该作者
OKOKOKOKOK
