查看: 3921|回复: 13
大神求帮忙!!!关于51单片机数码管问题
ID:93574 发表于 2015-10-30 20:11 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include <reg51.h>          //程序目的:从0计时到9999(数码管一位一位的打开)
sbit K0=P3^0;sbit K1=P3^1;sbit K2=P3^2;sbit K3=P3^3;
uint counter,time_counter=0;
uchar code du[]={
                                0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F  //"9"
                                };         //每个数码管显示
void delay(uint z)//延时函数
        uchar x,y;
        for(x = z;x > 0;x--)
        for(y = 110;y >0;y--);
void init()        //定时初始函数
        TMOD = 0X10;
        TH1 = (65536-46082)/256;
        TL1 = (65536-46082)%256;
//        TR1 = 1;
void display(uint time_counter)  //数码管显示函数
        uchar ge,shi,bai,qian;
        ge = time_counter%1000%100%10;
        shi = time_counter%1000%100/10;
        bai = time_counter%1000/100;
        qian = time_counter/1000;
        if(0 <= time_counter <= 9)        //计时9之内
                P1 = 0xfe;
                P0 = du[ge];
                delay(1);
                P0 = 0X00;
        if(9 < time_counter <= 99)        //计时9至99之间
                P1 = 0xfe;
                P0 = du[ge];
                delay(1);
                P0 = 0X00;
                P1 = 0xfd;
                P0 = du[shi];
                delay(1);
                P0 = 0X00;
        if(99 < time_counter <= 999)  //计时99至999之间
                P1 = 0xfe;
                P0 = du[ge];
                delay(1);
                P0 = 0X00;
                P1 = 0xfd;
                P0 = du[shi];
                delay(1);
                P0 = 0X00;
                P1 = 0xfb;
                P0 = du[bai];
                delay(1);
                P0 = 0X00;
          if(time_counter > 999)                //计时999以上
                P1 = 0xfe;
                P0 = du[ge];
                delay(1);
                P0 = 0X00;
                P1 = 0xfd;
                P0 = du[shi];
                delay(1);
                P0 = 0X00;
                P1 = 0xfb;
                P0 = du[bai];
                delay(1);
                P0 = 0X00;
                P1 = 0xf7;
                P0 = du[qian];
                delay(1);
                P0 = 0X00;
        init();
        if(TF1 == 1)
                 TF1 = 0;
                counter++;                           //延时50ms后counter+1
        if(counter == 1)
                counter = 0;
                time_counter++;        //20次后即一秒time——counter+1
                if( time_counter == 9999)
                  while(1);
                if(K0 == 0)
                        delay(10);
                        if(K0 == 0)
                                TR1 = 1;
                                while(!K0);
                if(K1 == 0)
                        delay(10);
                        if(K1 == 0)
                                TR1 = 0;
                                while(!K1);
                if(K2 == 0 && TR1 == 0)
                        delay(10);
                        if(K2 == 0)
                                time_counter++;
                                while(!K2);
                if(K3 == 0 && TR1 == 0)
                        delay(10);
                        if(K3 == 0)
                                time_counter--;
                                while(!K3);
                display(time_counter);
我想实现数码管一位一位的亮(0-9999)~他却前三位都亮了~直到999开始才是我要的。
ID:36525 发表于 2016-2-29 20:47 | 只看该作者
参考一下0-99计数器的程序网上有
ID:18297 发表于 2016-2-25 21:05 | 只看该作者
改2个地方:
1)   红色为添加的;        if( time_counter <10)        //计时9之内
                P1 = 0xfe;
                P0 = du[ge];
                delay(1);
                P0 = 0X00;
        else if(time_counter <100)        //计时9至99之间
                P1 = 0xfe;
                P0 = du[ge];
                delay(1);
                P0 = 0X00;
                P1 = 0xfd;
                P0 = du[shi];
                delay(1);
                P0 = 0X00;
        else if(time_counter <1000)  //计时99至999之间
                P1 = 0xfe;
                P0 = du[ge];
                delay(1);
                P0 = 0X00;
                P1 = 0xfd;
                P0 = du[shi];
                delay(1);
                P0 = 0X00;
                P1 = 0xfb;
                P0 = du[bai];
                delay(1);
                P0 = 0X00;
        else if(time_counter >1000)                //计时999以上
                P1 = 0xfe;
                P0 = du[ge];
                delay(1);
                P0 = 0X00;
                P1 = 0xfd;
                P0 = du[shi];
                delay(1);
                P0 = 0X00;
                P1 = 0xfb;
                P0 = du[bai];
                delay(1);
                P0 = 0X00;
                P1 = 0xf7;
                P0 = du[qian];
                delay(1);
                P0 = 0X00;
2)上面的判断语句要改改;
      如0 <= time_counter <= 9 改成  time_counter <10。其他雷同
仿真结果可行。
修改后程序.rar
940 Bytes, 下载次数: 3
ID:74145 发表于 2016-2-25 19:16 | 只看该作者
应该是程序的问题
ID:104559 发表于 2016-2-25 17:42 | 只看该作者
程序问题,检查一下时序
ID:103889 发表于 2016-1-20 15:27 | 只看该作者
程序的问题。
ID:97249 发表于 2016-1-20 12:33 | 只看该作者
if(0 <= time_counter <= 9) 表达式可以这样写吗?应这样 if( time_counter <10)把那几个表达式改过来试试
ID:103865 发表于 2016-1-20 11:09 | 只看该作者
程序的问题吧,好好检查检查
ID:103849 发表于 2016-1-20 08:32 | 只看该作者
你好,我也遇到了这个问题,请问你解决了吗?
ID:93574 发表于 2015-10-31 12:52 | 只看该作者
哪里啊?
ID:79544 发表于 2015-10-31 11:27 | 只看该作者
程序的问题
ID:93574 发表于 2015-10-30 21:57 | 只看该作者
PLA 发表于 2015-10-30 20:39
应该是你的位驱动有问题,当小于10时只显示个位,小于100时显示个位和十位,小于1000是就显示个位、十位百 ...
在哪个if后面加else接下来的if语句就不会运行了。不会显示其他位了T_T,
ID:18867 发表于 2015-10-30 20:39 | 只看该作者
应该是你的位驱动有问题,当小于10时只显示个位,小于100时显示个位和十位,小于1000是就显示个位、十位百位。你加个else语句试试!
