查看: 4577|回复: 0
51单片机控制PCF8591输出4种波形周期可调
ID:95068 发表于 2015-11-15 13:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
sbit  SCL=P2^6;
sbit  SDA=P2^7;
sbit  key1=P3^6;
sbit  key2=P3^7;
uint n=0;
uchar code  Sinwave[]={    //正弦波波表
127, 152, 176, 198, 217, 233, 245, 252,
255, 252, 245, 233, 217, 198,176, 152,
127, 102, 78,  56,  37,  21,  9,   2,
0,   2,   9,  21,  37,  56,  78, 102
uchar code Triwave[] = {   //三角波波表
0,  16,  32,  48,  64,  80,  96, 112,
128, 144, 160, 176, 192, 208,224, 240,
255, 240, 224, 208, 192, 176, 160, 144,
128, 112,  96,  80,  64,  48,  32,  16
uchar code Sawwave[] = {   //锯齿波表
0, 8, 16, 24, 32, 40,  48,  56,
64,72,80,  88,  96, 104, 112,120,
128, 136, 144, 152, 160, 168, 176,184,
192, 200, 208, 216, 224,232, 240, 248,
uchar code Squwave[]={   //方波波表
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,
255,255,255,255,255,255,255,255,
uint f=30;
void delay()
void  delay10()
{ uint i,j;
  for(i=0;i<10;i++)
    for(j=0;j<250;j++);
  void  delay11()
{ uint i,j;
  for(i=0;i<f;i++)
    for(j=0;j<250;j++);
void init()
{  SCL=1;
   delay();
   SDA=1;
   delay();
void start()
{   init();
        SDA=0;
        delay();
void write(uchar date)
{         uchar i,temp;
     temp=date;
         for(i=0;i<8;i++)
          { temp=temp<<1;
            SCL=0;
            delay();
            SDA=CY;
            delay();
            SCL=1;
            delay();
         SCL=0;
         delay();
         SDA=1;
         delay();
void respons()
{         uchar i;
     SCL=1;
         delay();
         while((SDA==1)&&(i<250))
           i++;
         SCL=0;
         delay();
void stop()
        SDA=0;
        delay();
        SCL=1;
        delay();
        SDA=1;
        delay();
  void writewave(uchar xc)
      init();
      start();
             write(0x90);
          respons();
          write(0x40);
          respons();
          write(xc);
          respons();
          stop();
void keyscan()
{ if(key1==0)
            delay10();
         if(key1==0)
         { f+=10;
           while(!key1);
   if(key2==0)
            delay10();
         if(key2==0)
         { f-=10;
         if(f<=20) f=20;
           while(!key2);
void  main()
   {  keyscan();
   for(n=0;n<32;n++)
        { writewave(Sinwave[n]);
     delay11();        }
    for(n=0;n<32;n++)
     { writewave(Triwave[n]);
       delay11();  }
        for(n=0;n<32;n++)
     { writewave(Sawwave[n]);
        delay11();}
         for(n=0;n<32;n++)
   { writewave(Squwave[n]);
      delay11(); }
admin + 50 共享资料的积分奖励!
