查看: 2154|回复: 0
跪求大神给我讲讲这个点阵程序输出0~9
ID:101194 发表于 2015-12-30 17:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#include<intrins.h>
uchar code Table_OF_Digits[]={0x00,0x3e,0x41,0x41,0x41,0x3e,0x00,0x00,
0x00,0x00,0x00,0x21,0x7f,0x01,0x00,0x00,
0x00,0x27,0x45,0x45,0x45,0x39,0x00,0x00,
0x00,0x22,0x49,0x49,0x49,0x36,0x00,0x00,
0x00,0x0c,0x14,0x24,0x7f,0x04,0x00,0x00,
0x00,0x72,0x51,0x51,0x51,0x4e,0x00,0x00,
0x00,0x3e,0x49,0x49,0x49,0x26,0x00,0x00,
0x00,0x40,0x40,0x40,0x4f,0x70,0x00,0x00,
0x00,0x36,0x49,0x49,0x49,0x36,0x00,0x00,
0x00,0x32,0x49,0x49,0x49,0x3e,0x00,0x00};
uchar i=0,t=0,Num_index=0;
   P3=0x80;
   Num_index=0;
   TMOD=0x00;
   TH0=(8192-2000)/32;
   TL0=(8192-2000)%32;
   TR0=1;
   IE=0x82;
   while(1);
   void LED_Screen_Display()interrupt 1
    TH0=(8192-2000)/32;
    TL0=(8192-2000)%32;
    P3=_crol_(P3,1);
    P0=~Table_OF_Digits[Num_index*8+i];
    if(++i==8)
    i=0;
    if(++t==250)
    {t=0x00;
      if(++Num_index==10)Num_index=0;
