查看: 6025|回复: 0
在simulink中用RTW生成C代码
ID:105323 发表于 2016-2-13 03:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
一、
该步骤可以避免以下问题:
1  Your current working directory is:
C:\Program Files\MATLAB\R2009a\bin
Simulink does not permit you to build programs in the
MATLAB installation area. Please change to a working directory that
is not in the MATLAB installation area.
2 Error building Real-Time Workshop target for block diagram 'test'. MATLAB error message: Your current working directory is: C:\Program Files\MATLAB\R2009a\bin Simulink does not permit you to build programs in the MATLAB installation area. Please change to a working directory that is not in the MATLAB installation area.
二、生成的zip代码包编译时可能有错误
