查看: 7346|回复: 1
Verilog状态机实现序列检测
ID:105323 发表于 2016-2-23 01:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
经常在笔试的时候出现这样的题:检测序列为11001101,输出为1,否则输出为0。抽空写了下代码,仅供参考。
FSM1:一段式
module machine_test1(clk,rst,din,dout);
input clk,rst;
input din;
output dout;
//11001101
parameter idle=0,
    st0=1,
    st1=2,
    st2=3,
    st3=4,
    st4=5,
    st5=6,
    st6=7;
reg [3:0] next_state;
reg dout;
always @ (posedge clk or negedge rst)
begin
if(!rst)
begin
  next_state=idle;
  dout=0;
end
begin
  case(next_state)
  idle:
   if(din)
   begin
    next_state=st0;
    dout=0;
   end
   begin
    next_state=idle;
    dout=0;
   end
  st0:
   if(din)
   begin
    next_state=st1;
    dout=0;
   end
   begin
    next_state=idle;
    dout=0;
   end
  st1:
   if(!din)
   begin
    next_state=st2;
    dout=0;
   end
   begin
    next_state=st1;
    dout=0;
   end
  st2:
   if(!din)
   begin
    next_state=st3;
    dout=0;
   end
   begin
    next_state=st0;
    dout=0;
   end
  st3:
   if(din)
   begin
    next_state=st4;
    dout=0;
   end
   begin
    next_state=idle;
    dout=0;
   end
  st4:
   if(din)
   begin
    next_state=st5;
    dout=0;
   end
   begin
    next_state=idle;
    dout=0;
   end
  st5:
   if(!din)
   begin
    next_state=st6;
    dout=0;
   end
   begin
    next_state=st1;
    dout=0;
   end
  st6:
   if(din)
   begin
    next_state=idle;
    dout=1;
   end
   begin
    next_state=idle;
    dout=0;
   end
  default:
   begin
    next_state=idle;
    dout=0;
   end
  endcase
end
end
endmodule
FSM2:两段式
module machine_test(clk,rst,din,dout);
input clk,rst;
input din;
output dout;
//11001101
parameter idle=0,
    st0=1,
    st1=2,
    st2=3,
    st3=4,
    st4=5,
    st5=6,
    st6=7;
reg [3:0] current_state,next_state;
reg dout;
begin
if(!rst)
  current_state<=idle;
  current_state<=next_state;
end
always @ (next_state or current_state or din or dout)
begin
case(current_state)
idle:
  if(din)
  begin
   next_state=st0;
   dout=0;
  end
  begin
   next_state=idle;
   dout=0;
  end
st0:
  if(din)
  begin
   next_state=st1;
   dout=0;
  end
  begin
   next_state=idle;
   dout=0;
  end
st1:
  if(!din)
  begin
   next_state=st2;
   dout=0;
  end
  begin
   next_state=st1;
   dout=0;
  end
st2:
  if(!din)
  begin
   next_state=st3;
   dout=0;
  end
  begin
   next_state=st0;
   dout=0;
  end
st3:
  if(din)
  begin
   next_state=st4;
   dout=0;
  end
  begin
   next_state=idle;
   dout=0;
  end
st4:
  if(din)
  begin
   next_state=st5;
   dout=0;
  end
  begin
   next_state=idle;
   dout=0;
  end
st5:
  if(!din)
  begin
   next_state=st6;
   dout=0;
  end
  begin
   next_state=st1;
   dout=0;
  end
st6:
  if(din)
  begin
   next_state=idle;
   dout=1;
  end
  begin
   next_state=idle;
   dout=0;
  end
default:
  begin
   next_state=idle;
   dout=0;
  end
endcase
end
endmodule
FSM3:三段式
module machine_test2(clk,rst,din,dout);
input clk,rst;
input din;
output dout;
//11001101
parameter idle=0,
    st0=1,
    st1=2,
    st2=3,
    st3=4,
    st4=5,
    st5=6,
    st6=7,
    st7=8;
reg dout;
begin
if(!rst)
end
begin
case(current_state)
idle:
  if(din)
   next_state=st0;
   next_state=idle;
st0:
  if(din)
   next_state=st1;
   next_state=idle;
st1:
  if(!din)
   next_state=st2;
   next_state=st1;
st2:
  if(!din)
   next_state=st3;
   next_state=st0;
st3:
  if(din)
   next_state=st4;
   next_state=idle;
st4:
  if(din)
   next_state=st5;
   next_state=idle;
st5:
  if(!din)
   next_state=st6;
   next_state=st1;
st6:
  if(din)
   next_state=st7;
   next_state=idle;
st7:
  if(din)
   next_state=st1;
   next_state=idle;
default:
  next_state=idle;
endcase
end
always @ (posedge clk)
begin
if(next_state==st7)
  dout<=1'd1;
  dout<=1'd0;
end
endmodule
仿真结果:
ID:792100 发表于 2020-6-28 18:49 | 只看该作者
二段式具体的波形信号输入的是多少呀
