查看: 3711|回复: 2
单总线挂接4路ds18B20温度监测系统 仿真 程序加电路
51单片机做的 单总线挂接4路ds18B20的动态温度监测系统
以上全部资料下载: 单总线挂接4路ds18B20温度监测系统.zip (273.05 KB, 下载次数: 46)
实物图:
4路ds18B20温度监测系统proteus仿真图电路图:
部分程序预览(完整代码请下载附件):
  1. #include "lcd1602.h"
  2. #include "ds18b20.h"
  3. unsigned char temp[5];
  4. extern char xiaoshu_temp[5],zhen_temp[4];
  5. extern bit flag;
  6. extern bit dot_dis;
  7. sbit beep=P2^3;
  8. uchar ds18b20_num1[8]={0x8e,0x00,0x00,0x00,0xb8,0xc5,0x30,0x28};
  9. uchar ds18b20_num2[8]={0xfd,0x00,0x00,0x00,0xb8,0xc5,0x45,0x28};
  10. uchar ds18b20_num3[8]={0xb9,0x00,0x00,0x00,0xb8,0xc5,0x31,0x28};
  11. uchar ds18b20_num4[8]={0xe0,0x00,0x00,0x00,0xb8,0xc5,0x32,0x28};
  12. void delay(unsigned int time)
  13. {
  14.         unsigned int i,j;
  15.         for(i=0;i<time;i++)
  16.                 for(j=0;j<200;j++);
  17. }
  18.
  19. void main(void)
  20. {
  21.         uchar i;
  22.         char *str1="1:";
  23.         char *str2="2:";
  24.         char *str3="3:";
  25.         char *str4="4:";
  26.         serial_set();
  27.         Lcd_Init();
  28.         ClrScreen();
  29.         GotoXY(0,0);
  30.         dot_dis=1;
  31.         while(1)
  32.         {
  33.                 ds18b20_init();
  34.                 ds18b20_writecommand(0xcc);
  35.                 ds18b20_writecommand(0x44);         //转换
  36.                 delay(500);
  37.                 match_rom(ds18b20_num1);          //匹配第一路
  38.                 ds18b20_writecommand(0xbe);          //读
  39.                 for(i=0;i<2;i++)
  40.                 {
  41.                         temp[i]=ds18b20_readdata();
  42.                 }
  43.                 temperature_process(temp[0],temp[1]);
  44.                 Screen_home();
  45.                 Print(str1);
  46.                 if(!flag) //正
  47.                 {
  48.                         Print(zhen_temp);
  49.                         if(dot_dis)
  50.                         Print(".");
  51.                         Print(xiaoshu_temp);
  52.                 }
  53.                 else   //负
  54.                 {
  55.                         Print("-");
  56.                         Print(zhen_temp);
  57.                         if(dot_dis)
  58.                         Print(".");
  59.                         Print(xiaoshu_temp);
  60.                    }
  61.                 Print("  ");
  62.                 ds18b20_init();
  63.                 ds18b20_writecommand(0xcc);
  64.                 ds18b20_writecommand(0x44);         //转换
  65.                 delay(500);
  66.                 match_rom(ds18b20_num2);          //匹配第二路
  67.                 ds18b20_writecommand(0xbe);          //读
  68.                 for(i=0;i<2;i++)
  69.                 {
  70.
  71.                         temp[i]=ds18b20_readdata();
  72.
  73.                 }
  74.                 temperature_process(temp[0],temp[1]);
  75.                 GotoXY(9,0);
  76.                 Print(str2);
  77.
  78.                 if(!flag) //正
  79.                 {
  80.                         Print(zhen_temp);
  81.                         if(dot_dis)
  82.                         Print(".");
  83.                         Print(xiaoshu_temp);
  84.                 }
  85.                 else   //负
  86.                 {
  87.                         Print("-");
  88.                         Print(zhen_temp);
  89.                         if(dot_dis)
  90.                         Print(".");
  91.                         Print(xiaoshu_temp);
  92.                    }
  93.                 Print("  ");
  94.                 ds18b20_init();
  95.                 ds18b20_writecommand(0xcc);
  96.                 ds18b20_writecommand(0x44);         //转换
  97.                 delay(500);
  98.                 match_rom(ds18b20_num3);          //匹配第三路
  99.                 ds18b20_writecommand(0xbe);          //读
  100.                 for(i=0;i<2;i++)
  101.                 {
  102.
  103.                         temp[i]=ds18b20_readdata();
  104.
  105.                 }
  106.                 temperature_process(temp[0],temp[1]);
  107.                 GotoXY(0,1);
  108.                 Print(str3);
  109.
  110.                 if(!flag) //正
  111.                 {
  112.                         Print(zhen_temp);
  113.                         if(dot_dis)
  114.                         Print(".");
  115.                         Print(xiaoshu_temp);
  116.                 }
  117.                 else   //负
  118.                 {
  119.                         Print("-");
  120.                         Print(zhen_temp);
  121.                         if(dot_dis)
  122.                         Print(".");
  123.                         Print(xiaoshu_temp);
  124.                    }
  125.                 Print("  ");
  126.                 ds18b20_init();
  127.                 ds18b20_writecommand(0xcc);
  128.                 ds18b20_writecommand(0x44);         //转换
  129.                 delay(500);
  130.                 match_rom(ds18b20_num4);          //匹配第二路
  131.                 ds18b20_writecommand(0xbe);          //读
  132.                 for(i=0;i<2;i++)
  133.                 {
  134.
  135.                         temp[i]=ds18b20_readdata();
  136.
  137.                 }
  138.                 temperature_process(temp[0],temp[1]);
  139.                 GotoXY(9,1);
  140.                 Print(str4);
  141.                 if(!flag) //正
  142.                 {
  143.                         Print(zhen_temp);
  144.                         if(dot_dis)
  145.                         Print(".");
  146.                         Print(xiaoshu_temp);
  147.                 }
  148.                 else   //负
  149.                 {
  150.                         Print("-");
  151.                         Print(zhen_temp);
  152.                         if(dot_dis)
  153.                         Print(".");
  154.                         Print(xiaoshu_temp);
  155.                    }
  156.                 Print("  ");
  157.            //delay(100);
  158.         }
  159.         while(1);
  160.
  161. }
ID:222743 发表于 2017-7-27 12:56 | 只看该作者
我来学习一下~最近正好在学这个呢
ID:324139 发表于 2018-5-7 21:42 | 只看该作者
有原理图吗?
