查看: 2492|回复: 0
51单片机简易计算器文件
ID:125235 发表于 2016-6-5 14:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
#include<intrins.h>
sbit R=P2^0;
sbit W=P2^1;
sbit E=P2^2;
void show(unsigned long  x );
void delay(unsigned int k);//延时
int keyc();//键盘扫描
void init();//LCD初始化
void write_com_1602(unsigned char command);//写命令
void write_data_1602(unsigned char datum);//写数据
void desplay(unsigned int a);//显示程序
unsigned int key;
unsigned char anjian(void) ;
void DelayMS(uint x)
uchar i;
while(x--)
  for(i=0;i<250;i++);
uchar x;
  unsigned  long first,second,c;
  unsigned  long third ;
/// unsigned char flag ;//flag1;
  //first=0;flag=1;
   _nop_();
  init();
   P1=0x0f;
                               while(P1==0x0f);
                key=anjian();
                   if(key<11&&key>=0)
                         first=first*10+key;//key=0;
                     desplay(key);//显示第一位
                     // P1=0x0f;
                       while(P1!=0x0f);
                 delay(130);
                       if(key<17&&key>=13)
                   switch (key)
                           case 16:  write_data_1602('+');   second=first;  first=0; c=1;
                        break;
                case 15:  write_data_1602('-');   second=first;  first=0; c=2;
                        break;
                case 14:  write_data_1602('*');   second=first;  first=0; c=3;
                        break;
                case 13:  write_data_1602('/');   second=first;  first=0; c=4;
                        break;
                default:   break;
                           delay(130);
                   delay(130);
           if(key==12)
                 write_com_1602(0x80+0x40);//给AC送值
                 write_data_1602('=');
                // third= first ;
                  switch (c)
                           case 1:    third=second+first;
                        break;
                case 2:    third=second-first;
                        break;
                case 3:    third =second*first;
                        break;
