查看: 3778|回复: 0
数控直流电流源源码
ID:126804 发表于 2016-6-15 17:50 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <STC12C5A.H>
sbit cs=P2^0;
sbit dat=P2^1;
sbit clk=P2^2;
sbit psb=P2^3;
sbit ret=P2^4;
sbit reley=P2^6;
sbit reley1=P2^7;
sbit aa=P1^0;
sbit fang_xiang1=P0^0;
sbit inc1=P0^1;
sbit cs1=P0^2;
sbit fang_xiang2=P0^3;
sbit inc2=P0^4;
sbit cs2=P0^5;
sbit jia1=P3^2;
sbit jian1=P3^3;
sbit jia2=P3^4;
sbit jian2=P3^5;
bit flag;
sbit key=P3^6;
uchar ADC_P1_EN,led;
uchar *t[]={"上电压值:","下电压值:","比值:"};
uchar code t1[]={"电流值:"};
float current;
uchar a1,a2,a3;
uint m1;
bit flag;
void  delay(uint x)
         uint i,j;
         for(i=x;i>0;i--);
         for(j=110;j>0;j--);
void delayms(uint x)
        uint i,j;
        for(i=x;i>0;i--)
                for(j=110;j>0;j--);
void send_byte(uchar da)
        uchar i;
        for(i=0;i<8;i++)
                if(da&0x80)
                dat=1;
                dat=0;
                clk=0;
                clk=1;
                da=da<<1;
void write_com(uchar command)
        cs=1;
        delay(5);
        send_byte(0xf8);
        send_byte(command&0xf0);
        send_byte((command<<4)&0xf0);
        cs=0;
void write_da(uchar temp)
        cs=1;
        delay(5);
        send_byte(0xfa);
        send_byte(temp&0xf0);
        send_byte((temp<<4)&0xf0);
        cs=0;
//LCD初始化
void lcd_init()
        psb=0;
        ret=1;
        write_com(0x30);
        delay(5);
        write_com(0x01);
        delay(5);
        write_com(0x06);
        delay(5);
        write_com(0x0c);
        delay(5);
void disp(uchar x,uchar*str)
        uchar temp;
        temp=*str;
        write_com(x);
        while(temp!='\0')
                write_da(temp);
                str++;
                temp=*str;
uint get_adc_dat(uchar num)
        uchar adc_flag=0;
        uint  dat;
        ADC_RES=0;
        ADC_RESL=0;
        ADC_CONTR=0xe8|num;
        while(adc_flag==0)
                adc_flag=ADC_CONTR&0x10;
        ADC_CONTR=ADC_CONTR&0xe7;
        dat=ADC_RES*4+ADC_RESL;
        return(dat);
void chu_li()
        if(jia1==0)
                delayms(1);
                if(jia1==0)
                        cs=0;
                        fang_xiang1=1;
                        inc1=1;
                        inc1=0;
                        inc1=1;
                        cs1=1;
                        while(!jia1);
        if(jian1==0)
                delayms(1);
                if(jian1==0)
                        cs1=0;
                        fang_xiang1=0;
                        inc1=1;
                        inc1=0;
                        inc1=1;
                        cs1=1;
                        while(!jian1);
        if(jia2==0)
                delayms(1);
                if(jia2==0)
                        cs2=0;
                        fang_xiang2=1;
                        inc2=1;
                        inc2=0;
                        inc2=1;
                        cs=1;
                        while(!jia2);
        if(jia2==0)
                delayms(1);
                if(jian2==0)
                        cs2=0;
                        fang_xiang2=0;
                        inc2=1;
                        inc2=0;
                        inc2=1;
                        cs2=1;
                        while(!jian2);
void key_scan()
        if(key==0)
                delayms(1);
                if(key==0)
                        flag=~flag;
                        while(!key);
//主函数
        uint i;
        aa=0;
        delayms(100);
        aa=1;
        lcd_init();
        reley=0;
        reley1=0;
        disp(0x80,t1);
        ADC_P1_EN=0xff;
        led=1;
                key_scan();
                current=get_adc_dat(2)/1024.0;
                current=4.94545*current;
                if(current>4.40)
                        led=1;
                        reley=1;
                        for(i=0;i<10;i++)
                        delayms(50000);
                        reley=0;
                        if(flag=0)
                                if(current>1.47&&current<1.53)
                                        reley1=1;
                                        led=0;
                                        delayms(10);
                                led=1;
                                reley1=0;
                                delayms(10);
                                chu_li();
                m1=current*100;
                a1=current;
                a2=m1%100/10;
                a3=m1%10;
                write_com(0x84);
                write_da(a1+48);
                write_da('.');
                write_da(a2+48);
                write_da(a3+48);
