查看: 5241|回复: 1
我想用hc-06蓝牙模块控制电机的正反转,请问思路是什么
ID:100512 发表于 2016-6-15 19:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有没有相关的代码什么的参考一下·
ID:117161 发表于 2016-7-23 10:54 | 只看该作者
                                          #include<reg51.h>
sbit IN1=P1^0;
sbit IN2=P1^1;
sbit IN3=P1^2;
sbit IN4=P1^3;
sbit IN11=P1^4;
sbit IN22=P1^5;
sbit IN33=P1^6;
sbit IN44=P1^7;
sbit LED=P0^0;
uchar pwm,push,push1,shu,flag,flagg,butt[5]=0,j;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void init()
        IN1=0;
        IN2=0;
        TMOD=0X21;
        TH0=(65536-100)/256;
        TL0=(65536-100)%256;
        TH1=0xfd;
        TL1=0xfd;
        TR0=1;
        ET0=1;
        TR1=1;
        REN=1;
        SM0=0;
        SM1=1;
        ES=1;
        EA=1;
    pwm=0;
        push=12;
        push1=15;
        j=0;
        flagg=0;
void time1() interrupt 1
         pwm++;
         if(pwm<=push)
                 LED=1;
                LED=0;
        if(pwm<=push1)
                 LED=1;
                 LED=0;
         if(pwm>=200)
                pwm=0;
void ser() interrupt 4
        ES=0;
        if(RI==1)
                RI=0;
                shu=SBUF;
                if((shu==0x4f)&&(j==0))
                        butt[j]=shu;
                        flag=1;
                else if(flag==1)
                                        j++;
                                        butt[j]=shu;
                                        if(j>=2)
                                                j=0;
                                                flag=0;
                                                flagg=1;
                ES=1;
void qian()
        IN1=1;
        IN2=0;
        IN3=1;
        IN4=0;
        IN11=1;
        IN22=0;
        IN33=1;
        IN44=0;
void hou()
        IN1=0;
        IN2=1;
        IN3=0;
        IN4=1;
        IN11=0;
        IN22=1;
        IN33=0;
        IN44=1;
void zuo()
        IN1=1;
        IN2=0;
        IN3=1;
        IN4=0;
        IN11=0;
        IN22=1;
        IN33=0;
        IN44=1;
void you()
        IN1=0;
        IN2=1;
        IN3=0;
        IN4=1;
        IN11=1;
        IN22=0;
        IN33=1;
        IN44=0;
void ting()
        IN1=0;
        IN2=0;
        IN3=0;
        IN4=0;
        IN11=0;
        IN22=0;
        IN33=0;
        IN44=0;
        init();
                if(flagg==1)
                        flagg=0;
                        if((butt[0]==0x4f)&&(butt[1]==0x4e))
                                switch(butt[2])
                                        case 0x41:qian();break;
                                        case 0x42:hou();break;
                                        case 0x43:zuo();break;
                                        case 0x44:you();break;
                                        case 0x45:ting();break;
                                        case 0x31:LED=0;break;
                                        case 0x32:LED=1;break;
