查看: 3452|回复: 0
求大神将下面这篇c语程序转换成汇编语言程序(关于M、T法测转速的))
ID:136516 发表于 2016-8-11 19:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
#include <intrins.h>
#define        uchar        unsigned char
#define uint        unsigned int
#define   DataPort P0        //LCD1602数据端口
sbit    LCM_RS=P2^5;   //LCD1602命令端口
sbit    LCM_EN=P2^7;   //LCD1602命令端口
sbit    KEY1=P1^1;     //确认按键
sbit    KEY2=P1^3;            //减按键
sbit    KEY3=P1^5;     //加按键
uchar table[] = "Mode selection:";
uint M1 = 0;bit M_FLAG = 0;    //M法测速参数
uint M2 = 0;bit T_FLAG = 0;    //T法测速参数
uint Z = 1,T = 1000,n = 100;   //倍频系数*编码器光栅数 采样周期
bit flag = 0;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(uchar com)
                LCM_RS=0;
                DataPort=com;
                delay(5);
                LCM_EN=1;
                delay(5);
                LCM_EN=0;
void write_data(uchar date)
                LCM_RS=1;
                DataPort=date;
                delay(5);
                LCM_EN=1;
                delay(5);
                LCM_EN=0;
void init()
                LCM_EN=0;
                write_com(0x38);
                write_com(0x0e);
                write_com(0x06);
                write_com(0x01);
                write_com(0x80+0x00);
void main(void)
                uchar i;
                init();      //液晶初始化
                write_com(0x80);
                for(i = 0;i < 15;i++)
                                write_data(table);
                while(!flag)
                                if(!KEY2)
                                                delay(15);write_com(0x80 + 15);write_data('M');
                                                M_FLAG = 1;T_FLAG = 0;while(!KEY2);
                                if(!KEY3)
                                                delay(15);write_com(0x80 + 15);write_data('T');
                                                T_FLAG = 1;M_FLAG = 0;while(!KEY3);
                                if(!KEY1 &&(T_FLAG || M_FLAG))
                                {flag = 1;while(!KEY1);}
                write_com(0x80 + 0x40);
                write_data('Z');
                write_data('=');
                write_data(Z / 100 + '0');
                write_data(Z / 10 % 10 + '0');
                write_data(Z % 10 + '0');
                flag = 0;
                while(!flag)
                                if(!KEY2)
                                                delay(15);
                                                Z--;
                                                write_com(0x80 + 0x42);
                                                delay(15);while(!KEY2);
                                if(!KEY3)
                                                delay(15);
                                                Z++;
                                                delay(15);while(!KEY3);
                                if(!KEY1)
                write_com(0x80 + 0x48);
                write_data('T');
                write_data('=');
                write_data(T / 1000 + '0');
                write_data(T / 100 % 10 + '0');
                write_data(T / 10 % 10 + '0');
                write_data(T % 10 + '0');
                write_com(0x80 + 0x4E);
                write_data('m');
                write_data('s');
                flag = 0;
                while(!flag)
                                if(!KEY2)
                                                delay(15);
                                                T--;
                                                write_com(0x80 + 0x4A);
                                                while(!KEY2);
                                if(!KEY3)
                                                delay(15);
                                                T++;
                                                while(!KEY3);
                                if(!KEY1)
                flag = 0;write_com(0x01);
                IT0 = 1;       //下降沿触发
                EX0 = 1;
    TMOD = 0x11;   //定时/计数器0、1工作于方式1
                TH0 = 0xFC;    //12.000
                TL0 = 0x18;
    ET0=1;       //允许定时/计数器0 中断
    if(M_FLAG) TR0=1;       //启动定时/计数器0 中断
                else if(T_FLAG) TR0=0;       //启动定时/计数器0 中断
                EA=1;
void Int0(void) interrupt 0
                if(M_FLAG) M1++;
                if(T_FLAG)
                                TR0=1;
                                if(flag)
                                                flag = 0;
                                                n = T*60/Z/M2;
                                                write_com(0x80);
                                                write_data('S');
                                                write_data('p');
                                                write_data('e');
                                                write_data('e');
                                                write_data('d');
                                                write_data(':');
                                                write_data(n / 10000 + '0');
                                                write_data(n / 1000 % 10 + '0');
                                                write_data(n / 100 % 10 + '0');
                                                write_data(n / 10 % 10 + '0');
                                                write_data(n % 10 + '0');
                                                write_data('r');
                                                write_data('/');
                                                write_data('m');
                                                write_data('i');
                                                write_data('n');
                                                EA = 0;
                                flag = 1;M2 = 0;
void Timer0(void) interrupt 1
                TL0 = 0x18;
                M2++;
                if(T == M2)
