查看: 7114|回复: 0
ADC0809的proteus仿真及程序
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. uchar code table[]={ 0x3F,/*0*/
  5.         0x06,/*1*/
  6.         0x5B,/*2*/
  7.         0x4F,/*3*/
  8.         0x66,/*4*/
  9.         0x6D,/*5*/
  10.         0x7D,/*6*/
  11.         0x07,/*7*/
  12.         0x7F,/*8*/
  13.         0x6F,/*9*/
  14. };
  15. uchar Tcount;
  16. uint wei3,wei2,wei1,wei0,num;
  17. bit timerflag,ADflag;
  18. sbit AD_end        =P3^2;
  19. sbit OE=P1^5;
  20. sbit ST=P1^6;
  21. void AD_INT() interrupt 0
  22. {ADflag=1;
  23. AD_end=1;
  24. }
  25. void T0_int()interrupt 1
  26. {TL0|=0xb0;
  27. TH0=0x3c;
  28.    if(--Tcount==0)
  29.      {Tcount=20;
  30.       timerflag=1;}
  31.
  32. }
  33. void delay(uint z)
  34. {uint x,y;
  35. for(x=z;x>0;x--)
  36.     for(y=110;y>0;y--);
  37. }
  38. void main()
  39. {
  40. Tcount=20;
  41. TMOD=0x01;
  42. TL0=0xb0;
  43. TH0=0x3c;
  44. IT0=1;
  45. TR0=1;
  46. ET0=1;
  47. EX0=1;
  48. EA=1;
  49. while(1)
  50. { P1=P1&0xf0|0x07;
  51.   P0=table[wei0];
  52.   delay(1);
  53.   P1=P1&0xf0|0x0b;
  54.   P0=table[wei1];
  55.   delay(1);
  56.   P1=P1&0xf0|0x0d;
  57.   P0=table[wei2];
  58.   delay(1);
  59.   P1=P1&0xf0|0x0e;
  60.   P0=table[wei3]|0x80;
  61.   delay(1);
  62.   if(timerflag==1)
  63.     {timerflag=0;
  64.      ADflag=0;
  65.      ST=1;
  66.          ST=0;
  67.       while(!ADflag);
  68.          {OE=1;
  69.           num=P2*20;
  70.           wei3=num/1000;
  71.           wei2=num%1000/100;
  72.           wei1=num%100/10;
  73.           wei0=num%10;
  74.           OE=0;
  75.           ADflag=0;}
  76.     }
  77. }
  78. }
  79.
ADC0809仿真.zip (32.35 KB, 下载次数: 105)
