查看: 3053|回复: 2
单片机驱动16X192点阵程序及proteus仿真
下面是16X192点阵取模软件的设置截图
下面是16X192点阵的仿真原理图:
仿真工程文件及所有完整程序等资料下载地址:http://www.51hei.com/bbs/dpj-56304-1.html
单片机源程序:
  1. #include<AT89X52.H>
  2. sbit ST=P3^5;
  3. sbit E1=P3^4;
  4. sbit MR=P3^7;
  5. char cashe[12];
  6. char code wd[12][16]={
  7. {0xFF,0xC0,0xFE,0xFE,0xFE,0xFE,0x80,0xFE,0xFD,0xFD,0xFB,0xF7,0xEF,0xDF,0x3F,0xFF},
  8. {0xFF,0x03,0xFF,0xFF,0xFF,0xFF,0x01,0x7F,0x7F,0x7F,0x7F,0x7F,0x7D,0x7D,0x81,0xFF},/*"无",0*/
  9. /* (16 X 16 , 宋体 )*/
  10. {0xDF,0xDF,0xDF,0xCF,0x57,0x58,0x5F,0xDF,0xDE,0xDE,0xDE,0xDD,0xDD,0xDB,0xDB,0xD7},
  11. {0x7F,0x6F,0x73,0x77,0x7F,0x01,0x5F,0x5F,0xDF,0xDF,0xDF,0xDF,0xDD,0xDD,0xE1,0xFF},/*"忧",1*/
  12. /* (16 X 16 , 宋体 )*/
  13. {0xFE,0xFE,0xFE,0xC0,0xDE,0xDE,0xC0,0xDE,0xDE,0xDE,0xC0,0xDE,0xFE,0xFE,0xFF,0xFF},
  14. {0xFF,0xFF,0xFF,0x07,0xF7,0xF7,0x07,0xF7,0xF7,0xF7,0x07,0xF7,0xFD,0xFD,0x01,0xFF},/*"电",2*/
  15. /* (16 X 16 , 宋体 )*/
  16. {0xFF,0xC0,0xFF,0xFF,0xFF,0xFE,0xFE,0xFE,0x00,0xFE,0xFE,0xFE,0xFE,0xFE,0xFA,0xFD},
  17. {0xFF,0x0F,0xDF,0xBF,0x7F,0xFF,0xFF,0xFB,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF},/*"子",3*/
  18. /* (16 X 16 , 宋体 )*/
  19. {0xFF,0x83,0xBB,0xAB,0xAA,0xAA,0xA9,0xAB,0xAB,0xAA,0xEE,0xD7,0xDB,0xBB,0x7F,0xFF},
  20. {0x7F,0x3F,0x7F,0x01,0xFD,0xFD,0xBD,0xBD,0x5D,0xED,0x05,0xED,0xFD,0xFD,0xEB,0xF7},/*"购",4*/
  21. /* (16 X 16 , 宋体 )*/
  22. {0xEF,0xEF,0xAF,0xAE,0x82,0xAD,0x6B,0xEB,0xE6,0xCD,0x2B,0xEF,0xEE,0xED,0xEB,0xFF},
  23. {0x7F,0x7F,0x7F,0x03,0xAB,0xAB,0x6B,0x6B,0xDB,0xDB,0xBB,0x7B,0xFB,0xFB,0xD7,0xEF},/*"物",5*/
  24. /* (16 X 16 , 宋体 )*/
  25. };
  26. void del(int i)//============================//延时程序
  27. {while(i--);}
  28. aline()        ////=======================发送一行的显示程序
  29. {
  30. char i=0;
  31. TI=0;
  32. for(i=0;i<12;i++)
  33. {SBUF=cashe[i];while(~TI);TI=0;} //将缓存中的信息转存入595的存储器中,到此不显示
  34. }
  35. main()
  36. {
  37. int m=0,n=0;
  38.         TI=0;
  39.         SM0=0;
  40.         SM1=0;
  41. E1=0;
  42. while(1)
  43. for(m=0;m<16;m++)      //共有16行  循环16次显示这16行  串行的595送出行的数据
  44.         {                                        //由74hc154选中要显示的行
  45.         for(n=0;n<12;n++)         //这个for循环用来向缓存数组中装载要显示的内容
  46.                 {cashe[11-n]=wd[n][m];}  //将第m个字的第n行信息装载  ,因为595串接 数据第一个进去的会在最后一个595中,最后进去的会在第一个595中
  47.     aline();     //将缓存中的一行信息载入595缓存中
  48.         ST=0;ST=1; //595产生上升沿 输出595锁存的数据
  49.         P2=m;  //选中要显示的行输出数据
  50.
  51.         del(100);//延时一段时间,以造成视觉暂存效应
  52.           }
  53. }
ID:661591 发表于 2019-12-21 10:46 | 只看该作者
么有压缩包吗
ID:102963 发表于 2020-2-16 13:51 | 只看该作者
这个尺寸,应该是16×96点阵吧,怎么是16×192呢??
