查看: 3089|回复: 1
基于51单片机的1602时钟的proteus仿真
ID:142187 发表于 2016-10-10 15:40 | 显示全部楼层 |阅读模式
源代码如下,通俗
#include<reg52.h>
sbit rs=P3^0;
sbit  e=P3^1;
int num,num1,num2=34,num3=9,num4=27,num5=9,num6=2016;
char table[]={'0','1','2','3','4','5','6','7','8','9'};
void delay(int z)
    int x;
    int y;
    for(x=z;x>0;x--)
    for(y=110;y>0;y--);
void com(char com)
    rs=0;
    P0=com;
    delay(5);
    e=1;
    delay(5);
    e=0;
void date(char date)
    rs=1;
    P0=date;
    delay(5);
    e=1;
    delay(5);
    e=0;
void init()
    e=0;
    com(0x38);
    com(0x0c);
    com(0x06);
    com(0x01);
void display(int a,int b,int c,int d,int e,int f)
    int miao1=a%10;
    int miao2=a/10;
    int fen1=b%10;
    int fen2=b/10;
    int shi1=c%10;
    int shi2=c/10;
    int ri1=d%10;
    int ri2=d/10;
    int m1=e%10;
    int m2=e/10;
    int n1=f%10;
    int n2=f%100/10;
    int n3=f%1000/100;
    int n4=f/1000;
    com(0x80+0x04);
    date(table[shi2]);
    date(table[shi1]);
    date(':');
    date(table[fen2]);
    date(table[fen1]);
    date(':');
    date(table[miao2]);
    date(table[miao1]);
    com(0x80+0x43);
    date(table[n4]);
    date(table[n3]);
    date(table[n2]);
    date(table[n1]);
    date('/');
    date(table[m2]);
    date(table[m1]);
    date('/');
    date(table[ri2]);
    date(table[ri1]);
    TMOD=0X01;
    TH0=(65536-45872)/256;
    TL0=(65536-45872)%256;
    EA=1;
    ET0=1;
    TR0=1;
    init();
        display(num1,num2,num3,num4,num5,num6);
void tm() interrupt 1
    num++;
    if(num==20)
        num1++;
        num=0;
    if(num1==60)
        num2++;
        num1=0;
    if(num2==60)
        num3++;
        num2=0;
    if(num3==24)
        num4++;
        num3=0;
    if((num5==1)||(num5==3)||(num5==5)||(num5==7)||(num5==8)||(num5==10)||(num5==12))
        if(num4==32)
            num5++;
            num4=1;
    if((num5==4)||(num5==6)||(num5==9)||(num5==11))
        if(num4==31)
            num5++;
            num4=1;
    if(num5==2)
        if(num4==29)
            num5++;
            num4=1;
    if(num5==13)
        num6++;
        num5=1;
ID:151879 发表于 2016-12-3 14:31 来自触屏版 | 显示全部楼层
请问哪段语句是设定时间的?
