查看: 8837|回复: 11
51单片机温度测量 热敏电阻
ID:147493 发表于 2016-11-12 10:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
51单片机温度测量:
温度.rar (42.82 KB, 下载次数: 117)
用查表法测热敏电阻的电压
源程序:
  1. #include "STC15F2K60S2.H"
  2. sbit SEL0=P2^0;                        //定义引脚
  3. sbit SEL1=P2^1;
  4. sbit SEL2=P2^2;
  5. sbit SEL3=P2^3;
  6. sbit beep=P3^4;                //蜂鸣器引脚
  7. sbit s1=P4^1;                //步进电机IO口
  8. sbit s2=P4^2;
  9. sbit s3=P4^3;
  10. sbit s4=P4^4;
  11. sbit key=P3^2;  //开关按键
  12. #define uint unsigned int    //宏定义
  13. #define ulint unsigned long
  14. uint value=0x00;     //LED显示
  15. uint count=0;
  16. uint i=1;           //步进电机
  17. bit flag=0;        //开关
  18. uint time=0;                                //延时
  19. uint t=0;                                                //执行温度的次数
  20. ulint sumt=0;                                //温度AD值的总和
  21. uint date_temp;
  22. int temp=0;                                        //温度值
  23. uint abs_temp;                        //温度绝对值
  24. //设置用于显示温度的三个变量
  25. uint temp_bai=0;                //百位
  26. uint temp_shi=0;                //十位
  27. uint temp_ge =0;                //个位
  28. //数码管上显示0-F
  29. char segtable[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  30.        0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  31. //温度值对应表
  32. int code tempdata[]={239,197,175,160,150,142,135,129,124,120,116,113,109,107,104,101,
  33.        99, 97, 95, 93, 91, 90, 88, 86, 85, 84, 82, 81, 80, 78, 77, 76,
  34.        75, 74, 73, 72, 71, 70, 69, 68, 67, 67, 66, 65, 64, 63, 63, 62,
  35.        61, 61, 60, 59, 58, 58, 57, 57, 56, 55, 55, 54, 54, 53, 52, 52,
  36.        51, 51, 50, 50, 49, 49, 48, 48, 47, 47, 46, 46, 45, 45, 44, 44,
  37.        43, 43, 42, 42, 41, 41, 41, 40, 40, 39, 39, 38, 38, 38, 37, 37,
  38.        36, 36, 36, 35, 35, 34, 34, 34, 33, 33, 32, 32, 32, 31, 31, 31,
  39.        30, 30, 29, 29, 29, 28, 28, 28, 27, 27, 27, 26, 26, 26, 25, 25,
  40.        24, 24, 24, 23, 23, 23, 22, 22, 22, 21, 21, 21, 20, 20, 20, 19,
  41.        19, 19, 18, 18, 18, 17, 17, 16, 16, 16, 15, 15, 15, 14, 14, 14,
  42.        13, 13, 13, 12, 12, 12, 11, 11, 11, 10, 10, 9, 9, 9, 8, 8, 8, 7,
  43.        7, 7, 6, 6,5, 5, 54,4, 3, 3,3, 2, 2, 1, 1, 1, 0, 0, -1, -1, -1,
  44.        -2, -2, -3, -3, -4, -4, -5, -5, -6, -6, -7, -7, -8, -8, -9, -9,
  45.        -10, -10, -11, -11, -12, -13, -13, -14, -14, -15, -16, -16, -17,
  46.        -18, -19, -19, -20, -21, -22, -23, -24, -25, -26, -27, -28, -29,
  47.        -30, -32, -33, -35, -36, -38, -40, -43, -46, -50, -55, -63, 361};
  48. void Delay(int n);     //延时函数
  49. void weixuan(char i);  //数码管位的选择
  50. void SEG_Display();    //显示温度
  51. void InitADC_temp();   //初始化温度ADC
  52. void date_processtemp();
  53. void Delay(int n)                        //延时函数
  54. {
  55.         while(n--);
  56. }
  57. void weixuan(char i)        //数码管位的选择
  58. {
  59.         SEL2=i/4;
  60.         SEL1=i%4/2;
  61.         SEL0=i%2;
  62. }
  63. void SEG_Display()   //显示温度
  64. {
  65.   //用于设置温度的位数
  66.         SEL3=0;       //数码管点亮
  67.         if(temp<0)
  68.         {
  69.                 P0=0;
  70.                 weixuan(5);                                //若温度为负,则首位显示‘-‘
  71.                 P0=0x40;
  72.                 Delay(500);
  73.         }
  74.         else
  75.         {
  76.                 P0=0;
  77.                 weixuan(5);
  78.                 P0=segtable[temp_bai];
  79.                 Delay(500);
  80.         }
  81.
  82.         P0=0;
  83.         weixuan(6);
  84.         P0=segtable[temp_shi];
  85.         Delay(500);
  86.
  87.         P0=0;
  88.         weixuan(7);
  89.         P0=segtable[temp_ge];
  90.         Delay(500);
  91.
  92.         if(key==0)
  93.         {
  94.                 Delay(15000);   //延时10ms,按键消抖
  95.                 if(key==0)
  96.                 {
  97.                         while(key==0);
  98.                         flag=~flag;
  99.                 }
  100.         }
  101.
  102.         if(temp>30&&flag==0)
  103.         {
  104.                 beep=~beep;
  105.
  106.                 switch(i++)        //控制步进电机不同IO口脉冲电平
  107.           {
  108.             case 1: s1=1;s2=0;s3=0;s4=0;break;
  109.             case 2: s1=0;s2=1;s3=0;s4=0;break;
  110.             case 3: s1=0;s2=0;s3=1;s4=0;break;
  111.             case 4: s1=0;s2=0;s3=0;s4=1;break;
  112.           }
  113.           if(i==5)
  114.             i=1;
  115.
  116.                 count++;
  117.                 SEL3=1;          //LED灯点亮
  118.                 P0=value;                                        //LED发光
  119.                 Delay(500);
  120.                 if(count==30)
  121.                 {
  122.                         value=~value;
  123.                         count=0;
  124.                 }
  125.         }
  126. }
  127. void T_L()
  128. {
  129.         P0M1=0x00;                                                //设置P0为推挽模式,点亮数码管
  130.         P0M0=0xff;
  131.         P2M1=0x00;
  132.         P2M0=0x08;                                                //将P2^3设置为推挽模式,其余为准双向口模式
  133.         P3M1=0x00;
  134.         P3M0=0x10;                                          //设置P3^4为推挽模式
  135.         SEL3=0;        //熄灭LED灯
  136.
  137.         IE=0xa8;                                                        //EA=1打开总中断,EADC=1允许A/D转化中断,ET1=1允许T1中断
  138.         TMOD=0x10;                                                //使用定时器1,16位不可重装载模式,TH1、TL1全用
  139.         TH1=(65535-40000)/256;//高8位赋初值,定时40000周期
  140.         TL1=(65535-40000)%256;//低8位赋初值
  141.         TR1=1;        //启动定时器1
  142.         beep=0;
  143.
  144.         while(1)
  145.         {
  146.                 SEG_Display();
  147.         }
  148. }
  149. void InitADC_temp()                        //初始化温度ADC
  150. {
  151.         P1ASF=0xff;                                                //将P1口作为模拟功能A/D使用
  152.         ADC_RES=0;                                                //寄存器ADC_RES和ADC_RESL保存A/D转化结果
  153.         ADC_RESL=0;                                                //初始赋值0
  154.         ADC_CONTR=0x8b;                                //ADC_POWER=1打开A/D转换器电源;ADC_START=1启动模拟转换器ADC;CHS=011选择P1^3作为A/D输入使用
  155.         CLK_DIV=0x20;                                        //ADRJ=1:ADC_RES[1:0]存放高2位ADC结果,ADC_RESL[7:0]存放低8位ADC结果
  156. }
  157. //分别取出温度的百位、十位、个位
  158. void date_processtemp()
  159. {
  160.         if(temp<0)
  161.                 abs_temp=-temp;
  162.         else
  163.                 abs_temp=temp;
  164.         temp_bai=abs_temp%1000/100;
  165.         temp_shi=abs_temp%100/10;
  166.         temp_ge =abs_temp%10;
  167. }
  168. void Timer1_Routine() interrupt 3        //3为定时器1中断编号
  169. {
  170.         IE=0x00;                                                        //关闭总中断
  171.         TR1=0;        //定时器1停止
  172.         TH1=(65535-40000)/256;//重新赋值
  173.         TL1=(65535-40000)%256;
  174.         InitADC_temp();                        //初始化温度
  175.         IE=0xa8;                                                        //打开总中断
  176.         TR1=1;        //启动定时器1
  177. }
  178. //AD中断
  179. void adc_isr() interrupt 5 using 1
  180. {
  181.   time++;
  182.         IE=0x00;                                                        //关闭中断
  183.
  184.         if(time>2000)      //取多次值求平均值减小误差
  185.         {
  186.                 date_temp=(sumt+t/2)/t;                        //四舍五入
  187.                 temp=tempdata[date_temp-1]; //查找对应的AD的温度值
  188.                 sumt=0;
  189.                 t=0;
  190.                 time=0;
  191.                 date_processtemp();
  192.         }
  193.
  194.         //对应温度的数据处理
  195.         t++;
  196.         date_temp=(ADC_RES*256+ADC_RESL)/4;//由10位AD值转换为8位AD值
  197.         sumt+=date_temp;                                                //求t次AD值的和
  198.         ADC_CONTR&=~0X10;                                           //转换完成后,ADC_FLAG清零
  199.         ADC_CONTR|=0X08;                                                  //转换完成后,ADC_START赋1
  200.         IE=0xa8;        //打开中断
  201. }
  202. void main()
  203. {
  204.         T_L();
  205. }
参与人数 2黑币 +60 收起 理由
中恒电子asus + 10
收藏收藏3 分享淘帖 顶顶1 踩踩
ID:90816 发表于 2016-11-23 15:09 | 只看该作者
努力学习当中!
ID:161477 发表于 2017-1-12 17:03 | 只看该作者
学习了
ID:137629 发表于 2017-3-12 08:19 | 只看该作者
学习了
ID:161033 发表于 2017-4-24 11:29 | 只看该作者
感谢分享
ID:241325 发表于 2017-11-29 21:46 | 只看该作者
有电路么
ID:52896 发表于 2018-1-14 15:00 | 只看该作者
感谢分享学习中
ID:396551 发表于 2018-9-12 15:02 | 只看该作者
努力学习当中!
ID:106422 发表于 2018-9-12 15:47 | 只看该作者
努力学习当中!
ID:434169 发表于 2018-11-27 14:28 | 只看该作者
努力学习当中。。
ID:153611 发表于 2018-11-27 14:42 | 只看该作者
刚想学习这方面的知识
ID:379683 发表于 2019-1-9 08:51 | 只看该作者
谢谢分享
