查看: 5096|回复: 1
TLC548+51单片机电压表 proteus仿真及汇编源程序
ID:151500 发表于 2016-12-1 18:14 | 显示全部楼层 |阅读模式
TLC548电路原理图:
TLC548汇编单片机程序:
  1. BCD_100   EQU 30H
  2. BCD_10    EQU 31H
  3. BCD_1     EQU 32H
  4. T050MS_NUM EQU 33H
  5. DLYMS_NUM EQU 34H
  6. TLC_DATA EQU 35H
  7. ND_ADC BIT 00H
  8. DIS_ON BIT P3.4
  9. TLC_CLR BIT P1.0
  10. TLC_CS  BIT P1.1
  11. TLC_DAT  BIT P1.2
  12. ORG 0000H
  13. LJMP MAIN
  14. ORG 000BH
  15. LJMP T0_ISR
  16. ORG 0100H
  17. MAIN:
  18. MOV SP,#6FH
  19. MOV BCD_100,#0
  20. MOV BCD_10,#0
  21. MOV BCD_1,#0
  22. CLR DIS_ON
  23. MOV T050MS_NUM,#5
  24. CLR ND_ADC
  25. MOV TMOD,#01H
  26. MOV TH0,#3CH
  27. MOV TL0,#0B0H
  28. CLR TF0
  29. SETB ET0
  30. SETB EA
  31. SETB TR0
  32. MAIN_LOOP:
  33. LCALL LED_DIS_3BIT
  34. JNB ND_ADC,MAIN_LOOP
  35. LCALL TLC_ADC
  36. CLR ND_ADC
  37. LJMP MAIN_LOOP
  38. LED_DIS_3BIT:
  39. MOV DPTR,#LED_TAB
  40. CLR DIS_ON
  41. MOV A,BCD_100
  42. MOVC A,@A+DPTR
  43. ANL A,#07FH
  44. MOV P0,A
  45. ANL P3,#1FH
  46. ORL P3,#5FH
  47. SETB DIS_ON
  48. MOV DLYMS_NUM,#2
  49. LCALL DELAYMS
  50. CLR DIS_ON
  51. MOV A,BCD_10
  52. MOVC A,@A+DPTR
  53. MOV P0,A
  54. ANL P3,#1FH
  55. ORL P3,#3FH
  56. SETB DIS_ON
  57. MOV DLYMS_NUM,#2
  58. LCALL DELAYMS
  59. CLR DIS_ON
  60. MOV A,BCD_1
  61. MOVC A,@A+DPTR
  62. MOV P0,A
  63. ANL P3,#1FH
  64. ORL P3,#1FH
  65. SETB DIS_ON
  66. MOV DLYMS_NUM,#2
  67. LCALL DELAYMS
  68. RET
  69. TLC_ADC:
  70. SETB TLC_DAT
  71. CLR  TLC_CLR
  72. CLR  TLC_CS
  73. MOV  R6,#8
  74. TLC_LOOP1:
  75. SETB TLC_CLR
  76. NOP
  77. NOP
  78. MOV C,TLC_DAT
  79. RLC A
  80. CLR TLC_CLR
  81. NOP
  82. DJNZ R6,TLC_LOOP1
  83. SETB TLC_CS
  84. SETB TLC_CLR
  85. MOV TLC_DATA,A
  86. MOV DLYMS_NUM,#1
  87. LCALL DELAYMS
  88. SETB TLC_DAT
  89. CLR  TLC_CLR
  90. CLR  TLC_CS
  91. MOV  R6,#8
  92. TLC_LOOP2:
  93. SETB TLC_CLR
  94. NOP
  95. NOP
  96. MOV C,TLC_DAT
  97. RLC A
  98. CLR TLC_CLR
  99. NOP
  100. DJNZ R6,TLC_LOOP2
  101. SETB TLC_CS
  102. SETB TLC_CLR
  103. MOV TLC_DATA,A
  104. MOV DLYMS_NUM,#1
  105. LCALL DELAYMS
  106. MOV A,TLC_DATA
  107. MOV B,#51
  108. DIV AB
  109. MOV BCD_100,A
  110. MOV A,B
  111. CJNE A,#50,CAL_10
  112. DEC A
  113. CAL_10:
  114. MOV B,#5
  115. DIV AB
  116. MOV BCD_10,A
  117. MOV BCD_1,B
  118. RET
  119. DELAYMS:
  120. MOV R4,#250
  121. DJNZ R4,$
  122. MOV R4,#250
  123. DJNZ R4,$
  124. DJNZ DLYMS_NUM,DELAYMS
  125. RET
  126. T0_ISR:
  127. MOV TH0,#3CH
  128. MOV TL0,#0B0H
  129. DJNZ T050MS_NUM,EXIT_T0
  130. MOV T050MS_NUM,#5
  131. SETB ND_ADC
  132. EXIT_T0:
  133. RETI
  134. LED_TAB:
  135. DB  0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H
  136. DB  88H,83H,0C6H,0A1H,86H,8EH
  137. END
TLC548电压表所有资料打包下载含仿真工程文件:
电压表.zip (23.48 KB, 下载次数: 25)
ID:1 发表于 2016-12-3 23:06 | 显示全部楼层
51黑有你更精彩!!!
