查看: 3374|回复: 1
用stc12c2052ad做的一个检测电压开关源码
ID:162491 发表于 2017-2-5 15:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "STC12C2052AD.H"
#include <intrins.h>
#define  ADC_POWER    0x80
#define  ADC_FLAG     0x10
#define  ADC_START    0x08
#define  ADC_SPEEDH   0x40
#define  BAUD                                 9600
sbit RELAY1=P3^4;
sbit RELAY2=P3^5;
sbit LED=P1^4;
void delay(uint i)
        uint x;
        while(i--)
        {x=5000;
while(x--);
void InitADC()
        P1=P1M0=P1M1=0x01;
        ADC_DATA=0;   //清除AD缓存器数据
        ADC_CONTR=ADC_POWER|ADC_SPEEDH; //启动A/D电源
        delay(2);
uchar GetADCResult(uchar ch)
        ADC_CONTR=ADC_POWER|ADC_SPEEDH|ADC_START|ch;
        _nop_();
        _nop_();
        _nop_();
        _nop_();
        while(!(ADC_CONTR&ADC_FLAG));
        ADC_CONTR=ADC_CONTR&(~ADC_FLAG);
        return ADC_DATA;
void process()
  uchar  adcnumber=0;
        uchar  adcnumber_temp=0;
        uchar  n;
        uchar i=0;
        TMOD=0x01;
        TH0=0x3C;
        TL0=0xb0;
        for (n=0;n<5;n++)    //adc convert  5 times
                adcnumber_temp=GetADCResult(0);    // get p10 adc number
                if(adcnumber_temp>adcnumber)        // get biggest
                {adcnumber=adcnumber_temp;  }
                if(adcnumber>152&adcnumber<212)
                        {          TR0=1;
                                i++;
                                if (i==40)
{                                i=0;
                                RELAY1=0;      //powerdown
                                RELAY2=0;
                                LED=0;         //faguang
                {   TR0=0;
                                RELAY1=1;      //powerdown
                                RELAY2=1;
                                LED=1;
        InitADC();
process();
ID:162491 发表于 2017-2-5 15:40 | 只看该作者
两路继电器  分压电阻 46 和5欧
