查看: 3100|回复: 0
PID算法控制电机转速
部分程序图
#include<reg52.h>
#include"lcd1602.h"
sfr T2MOD = 0x0c9;
sbit Q0 = P2^4;
sbit Q1 = P2^5;
sbit Q2 = P2^6;
sbit Q3 = P2^7;
sbit PWM                 = P1^7;
sbit UP                         = P1^0;
sbit DOWM                 = P1^1;
sbit GORB                = P2^3; //换相
sbit ADDSPEED         = P1^2;
sbit SUBSPEED        = P1^3;
uint tuint = 65535;
uint tpwm = 1;        //pwm周期为10000us tpwm变量表示pwm高电平时间,也相当于占空比 (仿真时,频率高时,电机反应慢。在实物上要加大频率)
uchar t1_flag = 0;
uint pulse = 0;
uint t0_flag = 0;
uchar t2_flag = 0;
bit t2_over = 0;
bit Just_Get = 1;
#define         ZZ                 { Q0 = 0;Q1 = 0;Q2 = 1;Q3 = 1;}        //正转
#define         FZ                 { Q0 = 1;Q1 = 1;Q2 = 0;Q3 = 0;}        //反转
#define         STOP        { Q0 = 1;Q1 = 0;Q2 = 1;Q3 = 0;}        //停止
//禁止出现 Q0 = 0;Q1 = 1;Q2 = 0;Q3 = 1; 不然会烧掉mos管
//************************ PID *************************************
float now = 0,bef = 0,bbef = 0;         //本次采样值,上次采样值,上上次采样值
float err_now,err_bef,err_bbef;                //当前偏差,上次偏差,上上次偏差
float error_add = 0;                                //所有偏差之和
float set = 25;                                                //设定值
float kp = 25;
float ki = 25;
float kd = 0;
void delayms(uint ms)//延时?个 ms
    uchar a,b,c;
        while(ms--)
          for(c=1;c>0;c--)
        for(b=142;b>0;b--)
            for(a=2;a>0;a--);
void timer_init()
        EA = 1;
        ET0 = 1;
        ET1 = 1;
        ET2 = 1;
        TMOD = 0x15; //定时器0 计数模式 定时器1模式1
        T2MOD = 0x01;
        TH0 = TL0 = 255;
        TH2 = 0x3C;
        TL2 = 0xB0;                //50MS
void timer1() interrupt 3
        if(t1_flag == 0)
                t1_flag = 1;
                PWM = 1;
                TH1 = (tuint - tpwm + 1)/256;
                TL1 = (tuint - tpwm + 1)%256;
                t1_flag = 0;
                PWM = 0;
                TH1 = (tuint - 10000 + tpwm + 1)/256;
                TL1 = (tuint - 10000 + tpwm + 1)%256;
