查看: 3300|回复: 0
实验室智能管理
ID:204897 发表于 2017-5-25 21:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
实验室智能管理
Private Sub Command1_Click()
Dim MPassword As String
      Adodc1.RecordSource = "select * from user_info where user_id ='" & Combo1.Text & "'"
       Adodc1.Refresh
        If Adodc1.Recordset.RecordCount > 0 Then
            MPassword = Adodc1.Recordset.Fields("user_password")
            If Text1.Text = MPassword Then
            qy = Adodc1.Recordset.Fields("user_qx")
                Form1.Show
                Unload Me
            Else
                MsgBox "密码不正确,请您确认后重新输入", , "提示信息"
                Text1.Text = ""
                Text1.SetFocus
            End If
        Else
            MsgBox "对不起 没有此用户的信息", , "提示信息"
          Combo1.Text = ""
            Text1.Text = ""
        End If
End Sub
Private Sub Command2_Click()
End
End Sub
Private Sub Form_Load()
Adodc1.ConnectionString = PublicStr
    Adodc1.RecordSource = "select * from user_info"
    Adodc1.Refresh
        Adodc1.Recordset.MoveFirst
      Combo1.Clear
        Do While Adodc1.Recordset.EOF = False
            Combo1.AddItem (Adodc1.Recordset.Fields("user_id"))
            Adodc1.Recordset.MoveNext
        Loop
    End If
End Sub
'Private Sub Text1_KeyPress(KeyAscii As Integer)
'If KeyAscii = 13 Then
'Call Command1_Click
'End If
'End Sub
Private Sub Text1_KeyDown(KeyCode As Integer, Shift As Integer)
If KeyCode = 13 Then
Call Command1_Click
End If
End Sub
