查看: 3365|回复: 0
单片机万年历
ID:206855 发表于 2017-6-1 20:34 | 显示全部楼层 |阅读模式
#include<reg52.h>
uchar a,miao,shi,fen,ri,yue,nian,week,flag,temp,key1n;
#define yh 0x80  //第一行的初始位置
#define er 0x80+0x44 //第二行初始位置
sbit dula=P2^6;
sbit wela=P2^7;
sbit rs=P3^5;
sbit en=P3^4;
sbit wr=P3^6;
sbit SCLK=P2^5;
sbit IO=P2^4;
sbit RST=P2^3;
sbit ACC0=ACC^0;
sbit ACC7=ACC^7;
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
uchar code tab1[]={"2017-  -   THU"};
uchar code tab2[]={"  :  :  "};
void delay(uint xms)//延时函数
uint x,y;
for(x=xms;x>0;x--)
  for(y=110;y>0;y--);
/******************液晶写入************************/
write_1602com(uchar com)//液晶写入指令函数
rs=0;//置为写入命令
P0=com;//送入数据
delay(1);
en=1;//拉高使能端
delay(1);
en=0;//完成高脉冲
write_1602dat(uchar dat)
rs=1;//置为写入数据
P0=dat;//送入数据
delay(1);
en=1;
delay(1);
en=0;
/*********************over***********************/
/********************ds1302****************************/
void write_byte(uchar dat)
ACC=dat;
RST=1;
for(a=8;a>0;a--)
  IO=ACC0;
  SCLK=0;
  SCLK=1;
  ACC=ACC>>1;
uchar read_byte()
RST=1;
for(a=8;a>0;a--)
  ACC7=IO;
  SCLK=1;
  SCLK=0;
  ACC=ACC>>1;
return (ACC);
void write_1302(uchar add,uchar dat)
RST=0;
SCLK=0;
RST=1;
write_byte(add);
write_byte(dat);
SCLK=1;
RST=0;
uchar read_1302(uchar add)
uchar temp;
RST=0;
SCLK=0;
RST=1;
write_byte(add);
temp=read_byte();
SCLK=1;
RST=0;
return(temp);
uchar BCD_Decimal(uchar bcd)
uchar Decimal;
Decimal=bcd>>4;
return(Decimal=Decimal*10+(bcd&=0x0F));
void ds1302_init()
RST=0;
SCLK=0;
write_1302(0x80,miao|0x00);//允许写
void write_sfm(uchar add,uchar dat)//写时分秒
uchar gw,sw;
gw=dat%10;
sw=dat/10;
write_1602com(er+add);
write_1602dat(0x30+sw);
write_1602dat(0x30+gw);
void write_nyr(uchar add,uchar dat)
uchar gw,sw;
gw=dat%10;
sw=dat/10;
write_1602com(yh+add);
void write_week(uchar week)//写星期函数
write_1602com(yh+0x0d);
switch(week)
  case 1:write_1602dat('M');//delay(5);
      write_1602dat('O');//delay(5);
      write_1602dat('N');
      break;
  case 2:write_1602dat('T');//delay(5);
      write_1602dat('U');//delay(5);
      write_1602dat('E');
      break;
  case 3:write_1602dat('W');//delay(5);
      write_1602dat('E');//delay(5);
      write_1602dat('D');
      break;
  case 4:write_1602dat('T');//delay(5);
      write_1602dat('H');//delay(5);
      write_1602dat('U');
      break;
  case 5:write_1602dat('F');//delay(5);
      write_1602dat('R');//delay(5);
      write_1602dat('I');
      break;
  case 6:write_1602dat('S');//delay(5);
      write_1602dat('A');
      break;
  case 7:write_1602dat('S');//delay(5);
      write_1602dat('N');
      break;
lcd_init()//液晶初始化函数
write_1602com(0x38);//设置液晶工作模式
write_1602com(0x0c);//开显示不显示光标
write_1602com(0x06);//整屏不移动,指针加一
write_1602com(0x01);
write_1602com(yh+2);//字符写入的位置
for(a=0;a<14;a++)
write_1602dat(tab1[a]);
//delay(3);
write_1602com(er+4);
for(a=0;a<8;a++)
write_1602dat(tab2[a]);
//delay(3);
void keyscan()
if(key1==0)//key1为功能键
delay(5);
if(key1==0)
while(key1==0);
key1n++;
if(key1n==9)
  key1n=1;
switch(key1n)
case 1: TR0=0;//关闭定时器
   //TR1=0;
   write_1602com(er+0x0b);//写入光标位置
      write_1602com(0x0f);//设置光标为闪烁
      temp=(miao)/10*16+(miao)%10;
      write_1302(0x8e,0x00);
      write_1302(0x80,0x80|temp);//miao
      write_1302(0x8e,0x80);
      break;
case 2:  write_1602com(er+8);//fen
       //write_1602com(0x0f);
   break;
case 3: write_1602com(er+5);//shi
   break;
case 4: write_1602com(yh+0x0f);//week
   break;
case 5: write_1602com(yh+0x0b);//ri
   break;
case 6: write_1602com(yh+0x08);//yue
   break;
case 7: write_1602com(yh+0x05);//nian
   break;
case 8:
   write_1602com(0x0c);//设置光标不闪烁
   TR0=1;//打开定时器
      write_1302(0x80,0x00|temp);//miao
            break;
if(key1n!=0)//当key1按下以下。再按以下键才有效
if(key2==0)  //上调键
delay(5);
if(key2==0)
while(key2==0);
switch(key1n)
case 1:miao++;
   if(miao==60)
    miao=0;
   write_sfm(0x0a,miao);//写入新的秒数
   write_1602com(er+0x0b);//因为设置液晶的模式是写入数据后,指针自动加一,在这里是写回原来的位置
   //write_1602com(0x0b);
   break;
case 2:fen++;
   if(fen==60)
    fen=0;
   write_sfm(0x07,fen);
   temp=(fen)/10*16+(fen)%10;
      write_1302(0x82,temp);
   break;
case 3:shi++;
   if(shi==24)
    shi=0;
   write_sfm(4,shi);
   temp=(shi)/10*16+(shi)%10;
      write_1302(0x84,temp);
   break;
case 4:week++;
   if(week==8)
    week=0;
    write_week(week);
   break;
case 5:ri++;
   if(ri==31)
    ri=0;
   write_nyr(10,ri);
   temp=(ri)/10*16+(ri)%10;
      write_1302(0x86,temp);
   write_1602com(yh+11);
   break;
case 6:yue++;
   if(yue==13)
    yue=0;
   write_nyr(7,yue);
   temp=(yue)/10*16+(yue)%10;
      write_1302(0x88,temp);
   write_1602com(yh+8);
   break;
case 7:nian++;
   if(nian==100)
   nian=0;
   write_nyr(4,nian);
   write_1602com(yh+5);
   break;
if(key3==0)
delay(5);
if(key3==0)
while(key3==0);
switch(key1n)
  case 1:miao--;
    if(miao==-1)
     miao=59;
   break;
  case 2:fen--;
    if(fen==-1)
     fen=59;
   write_sfm(7,fen);
   break;
  case 3:shi--;
      if(shi==-1)
     shi=23;
   write_sfm(4,shi);
   break;
  case 4:week--;
    if(week==-1)
     week=7;
   write_week(week);
   break;
  case 5:ri--;
    if(ri==-1)
     ri=30;
   write_nyr(10,ri);
   break;
  case 6:yue--;
    if(yue==-1)
     yue=12;
   write_nyr(7,yue);
   break;
  case 7:nian--;
   if(nian==-1)
   nian=99;
   write_nyr(4,nian);
   break;
void init()
TMOD=0x11;
TH0=0;
TL0=0;
EA=1;
ET0=1;
TR0=1;
void cmg(void)//数码管锁存函数
dula=1;
P0=0x00;
dula=0;
wela=1;
P0=0x00;
wela=0;
   cmg();//数码管锁存
lcd_init();
ds1302_init();
init();
  //TH0=(65536-60000)/256;
//TL0=(65536-60000)%256;
keyscan();
void timer0() interrupt 1
miao = BCD_Decimal(read_1302(0x81));
fen = BCD_Decimal(read_1302(0x83));
shi  = BCD_Decimal(read_1302(0x85));
ri  = BCD_Decimal(read_1302(0x87));
yue = BCD_Decimal(read_1302(0x89));
nian=BCD_Decimal(read_1302(0x8d));
week=BCD_Decimal(read_1302(0x8b));
  write_sfm(10,miao);
write_sfm(7,fen);
write_sfm(4,shi);
write_nyr(10,ri);
    write_nyr(7,yue);
