查看: 6571|回复: 2
基于51单片机的温度报警器设计源码
ID:206901 发表于 2017-6-1 22:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg52.h>
#include<intrins.h>
#define uint  unsigned int
typedef unsigned char  U8;       /*   ???8?????    */
typedef unsigned int   U16;     /*           ???16?????  */
sbit sclk = P1^0;
//sbit io= P1^1;
//sbit rst= P1^2;
sbit en=P2^5;          //?????
sbit rs=P2^3;          //?????????
sbit rd=P2^4;
sbit DQ=P2^2;         //DS18B20
sbit buzz = P1^3;
sbit P3_2 = P2^7;    //DHT11???
sbit key1 = P3^4;
sbit key2 = P3^5;
sbit key3 = P3^6;
sbit key4 = P3^7;
sbit led1 = P1^2;//RED
sbit led2 = P1^4;//GREEN
sbit led3 = P1^5;//YELLOW
uchar tplsb,tpmsb; //
uint temp,temp1;
U8  U8FLAG;
U8  U8comdata;
U8  U8count,U8temp;
U8  U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
U8  U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,
U8RH_data_L_temp,U8checkdata_temp;
#define CONTROL 0x80
#//define TIMING 0x81
#define DATA0LOW 0x8C
#define DATA0HIGH 0x8D
#define DATA1LOW 0x8E
#define DATA1HIGH 0x8F
uchar DataLow0,DataHigh0,DataLow1,DataHigh1,commad;
bit keyflag=0;
uchar tem,temlow=20,temhigh=40;
uchar code ASCII[]="0123456789%c.";
uchar show;
void DelayUs2x(unsigned char t)
while(--t);
void DelayMs(unsigned int t)
while(t--)
   DelayUs2x(245);
         DelayUs2x(245);
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void  Delay_10us(void)
    U8 i;
    i--;
    i--;
    i--;
    i--;
    i--;
    i--;
void delayus()
        _nop_();
        _nop_();
        _nop_();
        _nop_();
void delay1(int ms)
  unsigned char y ;
while(ms--)
  for(y=0;y<250;y++)
   _nop_() ;
   _nop_() ;
   _nop_() ;
   _nop_() ;
void delay2(){;;;}
/**************************LCD1602??*****************************/
void write1602_com(uint com)
        rs=0;
        rd=0;
        P0=com;
        delay(5);
        en=1;
        delay(5);
        en=0;
void write1602_date(uchar date)
        rs=1;
        rd=0;
        P0=date;
        delay(5);
        en=1;
        delay(5);
        en=0;
void write1602(uchar add,uchar dat)
write1602_com(add);
write1602_date(dat);
void write1602_String(unsigned char x,unsigned char y,unsigned char *s)
if (y == 0)
         write1602_com(0x80 + x);
        write1602_com(0xC0 + x);
while (*s)
write1602_date( *s);
s ++;
void write1602_Char(unsigned char x,unsigned char y,unsigned char Data)
if (y == 1)
write1602_date( Data);
void Clear1602(void)          //????
write1602_com(0x01);
DelayMs(5);
void init1602(void)                //1602???
        en=0;
        write1602_com(0x38);
        write1602_com(0x0c);
        write1602_com(0x06);
/*********************DS18B20??***********************************/
/*******************?????????DS18B20**************/
void reset(void)
        uint i;
        DQ=0;
        i=100;
        while(i--);
        DQ=1;// ?????
        i=4;
        while(i--);
void wait(void)
        uint i;
        while(DQ);
        while(~DQ); // ???????
        i=4;
        while(i--);
bit readbit(void)
        uint i;
        bit b;
        DQ=0;
        i++;
        DQ=1;
        i++;i++;// ??15us??,???????15us,DS18B20???????
        b=DQ;
        i=10;
        while(i--);
        return (b);
uchar readbyte(void)
        uchar i,j,b;
        b=0;
        for(i=0;i<8;i++)
                j=readbit();
                b=(j<<7)|(b>>1);
        return(b);
/******************????????,???1??0?????************/
void writebyte(uchar b)
        uint i;
        uchar j;
        bit btmp;
        for(j=0;j<8;j++)
                btmp=b&0x01;
                b=b>>1; // ????(??????)
                if(btmp)
                        DQ=0;
                        i++;i++;
                        DQ=1;
                        i=10;
                        while(i--);// ???1?????60us
                        DQ=0;
                        i=10;
                        while(i--); // ????60us?120us??
                        DQ=1;
                        i++;i++;
void convert(void)
        reset();// ??????,???DS18B20
        wait();//??DS18B20??????
        writebyte(0xcc);// skip rom ??
        writebyte(0x44);// convert T ??
uint readtemp(void)
        float tt;
        reset();
        wait();
        delay(1);
        writebyte(0xbe);// read scratchpad ??
        tplsb=readbyte();// ???????(???4??????"??"??)
        tpmsb=readbyte();// ???????(???5?????)
        temp=tpmsb;
        temp<<=8;
        temp=temp|tplsb;
        tt=temp*0.0625;
        temp=tt*10+0.5;
        return (temp);
void ds18B20disp(uint t)
        uchar a1,a2,a3,a4;
        a1=t/100;
        a2=t%100;
        a3=a2/10;
        a4=a2%10;
        write1602_com(0x80+0x40);//????9????????????????????
        write1602_date(a1+0x30);
        delay(1);
        write1602_date(a3+0x30);
        delay(1);
        write1602_date('.');
        delay(1);
        write1602_date(a4+0x30);
        write1602_date('C');
        delay(1);
void keyscan()
        unsigned char turn=0;
    bit change=0;
  // led1=0;
         led2=0;
    if(key4==0)
                DelayMs(10);
                if(key4==0)
                     show++;
                while(!key4);
                Clear1602();
if(show==1)
                timedisp();
                if(keyflag==0)
                         readtime();
                           write_second();
                            write_minute();
                            write_hour();
                            write_day();
                          write_month();
                          write_year();
                            write_week();
if(show==2)
                 unsigned char *pa,*pb;
                 pa="Temperature";
           pb="           ";
                 write1602_String(0,0,pa);
                 write1602_String(0,1,pb);
                show=0;
           if(key1==0)
                led3=0;
                DelayMs(10);
                if(key1==0)
                        turn++;
                 while(!key1);
                 Clear1602();
           while(turn)
            if(key1==0)
              DelayMs(90);
                  if(key1==0)
                      turn++;
                   while(!key1);
                  Clear1602();
if(turn==1)
                                  write1602_String(0,0,"Temperature Set");
                                write1602_String(0,1,"min     max");
                                  if(key4==0)
                                      DelayMs(10);
                                          if(key4==0)
                                            change=~change;
                                          while(!key4);
                                  if(change==0)
                                       write1602_String(4,2,">");
                                           write1602_String(13,2," ");
                                           write1602_Char(5,  2, ASCII[ temlow/10 ] );
                                           write1602_Char(6,  2, ASCII[ temlow%10 ] );
                                       write1602_Char(14, 2, ASCII[ temhigh/10 ] );
                                           write1602_Char(15, 2, ASCII[ temhigh%10 ] );
                                    if(!key2)
                                              DelayMs(90);
                                                  if(key2==0)
                                                        if(temlow>=0&&temlow<99)
        temlow++;
                                                   while(!key2);
                                         if(key3==0)
                                              DelayMs(90);
                                                  if(key3==0)
                                                        if(temlow>0&&temlow<=99)
        temlow--;
                                                   while(!key3);
                                 if(change==1)
                               write1602_String(4,2," ");
                               write1602_String(13,2,">");
                                       write1602_Char(14,2, ASCII[ temhigh/10 ] );
                                           write1602_Char(15,2, ASCII[ temhigh%10 ] );
                                    if(!key2)
                                              DelayMs(90);
                                                  if(key2==0)
                                                        if(temhigh>=0&&temhigh<99)
        temhigh++;
                                                   while(!key2);
                                         if(key3==0)
                                              DelayMs(90);
                                                  if(key3==0)
                                                        if(temhigh>0&&temhigh<=99)
        temhigh--;
                                                   while(!key3);
                        if(turn>=2)
                                 pa="Temperature";
                            pb="             ";
                                 turn=0;
  uint t;
        pa="Temperature";
  pb="           ";
        init1602();
//        init_1302();
//        TSL2561_Write(CONTROL,0x03);
        convert();
        delay(1000);// 启动温度转换,延时750ms
        readtemp(); // 读取温度
        buzz =0;
        t=readtemp();
                led3=1;
                if(show==0||show==2)
                convert();
                ds18B20disp(readtemp());
                if((((temp/10)%100)>=temhigh)||(((temp/10)%100)<=temlow))
                buzz=1;//蜂鸣器报警
                led1=0;//红灯亮、
                 led2=1;
          delay(1000);
         if((((temp/10)%100)<temhigh)||(((temp/10)%100)>temlow))
                buzz=0;//蜂鸣器报警
                led1=1;//红灯亮
                keyscan();
//                warning();
收藏收藏2 分享淘帖 顶顶 踩踩
ID:273523 发表于 2018-1-9 02:14 | 只看该作者
很好 对我有很大帮助
ID:924478 发表于 2021-5-20 17:49 | 只看该作者
很好 对我有很大帮助
