查看: 6358|回复: 4
基于51单片机的数字电子钟C程序设计 仿真图
ID:104835 发表于 2016-2-4 03:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. /***************************lns主程序snl***************************/
  2. #include <absacc.h> //包含头文件
  3. #include <reg52.h> //包含头文件
  4. /***************************数据类型定义***************************/
  5. #define uchar unsigned char //数据类型定义
  6. /*************************定义变量并初始化*************************/
  7. uchar n=31; //定义月份天数变量并初始化
  8. uchar ms=0; //定义毫秒变量并初始化
  9. uchar h1=0,m1=0,s1=0; //定义计时时、分、秒变量并初始化
  10. uchar h2=0,m2=1,s2=1; //定义定时时、分、秒变量并初始化
  11. uchar year=7,month=9,day=8; //定义年、月、日变量并初始化
  12. uchar wday=6; //定义星期变量并初始化
  13. uchar *h=&h1,*m=&m1,*s=&s1; //定义显视位变量并初始化
  14. uchar *p; //定义调节指针
  15. uchar k1=0,k2=0,k3=0,k4=0,k5=0; //定义控制变量并初始化
  16. uchar counter=0; //定义铃声节拍变量并初始化
  17. uchar count=0; //定义铃声音符变量并初始化
  18. sbit sound=P1^0; //定义铃声输出位
  19. uchar a[8]={1,2,3,4,5,6,7}; //定义显视输出位数组并初始化
  20. uchar code tt[12]={
  21. 0x3f,0x06,0x5b,0x4f,0x66,0x6d,
  22. 0x7d,0x07,0x7f,0x6f,0x40,0x00
  23. }; //数码管显视代码
  24. uchar code array[]={
  25. 0x18, 0x30, 0x1C, 0x10, 0x20, 0x40, 0x1C, 0x10,
  26. 0x18, 0x10, 0x20, 0x10, 0x1C, 0x10, 0x18, 0x40,
  27. 0x1C, 0x20, 0x20, 0x20, 0x1C, 0x20, 0x18, 0x20,
  28. 0x20, 0x80, 0xFF, 0x00, 0x20, 0x30, 0x1C, 0x10,
  29. 0x18, 0x20, 0x15, 0x20, 0x1C, 0x20, 0x20, 0x20,
  30. 0x26, 0x40, 0x20, 0x20, 0x2B, 0x20, 0x26, 0x20,
  31. 0x20, 0x20, 0x30, 0x80, 0xFF, 0x00, 0x20, 0x20,
  32. 0x1C, 0x10, 0x18, 0x10, 0x20, 0x20, 0x26, 0x20,
  33. 0x2B, 0x20, 0x30, 0x20, 0x2B, 0x40, 0x20, 0x20,
  34. 0x1C, 0x10, 0x18, 0x10, 0x20, 0x20, 0x26, 0x20,
  35. 0x2B, 0x20, 0x30, 0x20, 0x2B, 0x40, 0x20, 0x30,
  36. 0x1C, 0x10, 0x18, 0x20, 0x15, 0x20, 0x1C, 0x20,
  37. 0x20, 0x20, 0x26, 0x40, 0x20, 0x20, 0x2B, 0x20,
  38. 0x26, 0x20, 0x20, 0x20, 0x30, 0x80, 0x20, 0x30,
  39. 0x1C, 0x10, 0x20, 0x10, 0x1C, 0x10, 0x20, 0x20,
  40. 0x26, 0x20, 0x2B, 0x20, 0x30, 0x20, 0x2B, 0x40,
  41. 0x20, 0x15, 0x1F, 0x05, 0x20, 0x10, 0x1C, 0x10,
  42. 0x20, 0x20, 0x26, 0x20, 0x2B, 0x20, 0x30, 0x20,
  43. 0x2B, 0x40, 0x20, 0x30, 0x1C, 0x10, 0x18, 0x20,
  44. 0x15, 0x20, 0x1C, 0x20, 0x20, 0x20, 0x26, 0x40,
  45. 0x20, 0x20, 0x2B, 0x20, 0x26, 0x20, 0x20, 0x20,
  46. 0x30, 0x30, 0x20, 0x30, 0x1C, 0x10, 0x18, 0x40,
  47. 0x1C, 0x20, 0x20, 0x20, 0x26, 0x40, 0x13, 0x60,
  48. 0x18, 0x20, 0x15, 0x40, 0x13, 0x40, 0x18, 0x80,
  49. 0x00, 0x00
  50. }; //array[i]=0x00 代表歌曲演唱完毕
  51. //array[i]=0xff 代表是休止符
  52. /*******************************************************************
  53. * 函数名称:leap()
  54. * 功 能:计算二月份天数
  55. * 入口参数:year
  56. * 出口参数:无
  57. *******************************************************************/
  58. uchar leap(uchar year) //判断是否闰年并返回二月份的天数
  59. { //闰年返回29,平年返回28
  60. year+=2000;
  61. if(year%4==0)
  62. {if(year%100==0)
  63. {if(year%400==0)
  64. return 29;
  65. else return 28;
  66. }
  67. else return 29;
  68. }
  69. else return 28;
  70. }
  71. /*******************************************************************
  72. * 函数名称:mon()
  73. * 功 能:计算并返回每个月的天数
  74. * 入口参数:month
  75. * 出口参数:无
  76. *******************************************************************/
  77. uchar mon(uchar month) //计算并返回每个月的天数
  78. {
  79. switch(month)
  80. {
  81. case 1:
  82. case 3:
  83. case 5:
  84. case 7:
  85. case 8:
  86. case 10:
  87. case 12:return 31;break; //1,3,5,7,8,10,12月每月31天
  88. case 4:
  89. case 6:
  90. case 9:
  91. case 11:return 30;break; //4,6,9,11月每月30天
  92. case 2: return leap(year);break;//返回二月份的天数
  93. default:break;
  94. }
  95. }
  96. /*******************************************************************
  97. * 函数名称:music()
  98. * 功 能:音乐节拍控制
  99. * 入口参数:无
  100. * 出口参数:无
  101. *******************************************************************/
  102. void music(void) //铃声音乐
  103. {
  104. counter++; //节拍次数计数
  105. if(counter>=array[count+1]) //节拍次数判断
  106. {
  107. count+=2; //音符变换
  108. counter=0; //清0节拍数
  109. if(count>=192) //判断是否唱完一曲
  110. count=0; //返回第一个音符
  111. }
  112. }
  113. /*******************************************************************
  114. * 函数名称:timer1()
  115. * 功 能:音乐频率设置
  116. * 入口参数:无
  117. * 出口参数:无
  118. *******************************************************************/
  119. void timer1(void)interrupt 1 using 1 //音调设置
  120. {
  121. sound=~sound; //铃声输出
  122. TH0=(0xffff-30*array[count])>>8; //音频设置
  123. TL0=(0xffff-30*array[count])&0xff;
  124. }
  125. /*******************************************************************
  126. * 函数名称:timer3()
  127. * 功 能:中断计时
  128. * 入口参数:无
  129. * 出口参数:无
  130. *******************************************************************/
  131. void timer3(void) interrupt 3 using 3 //计时中断
  132. {
  133. TH1=0xd8; //计数器初值重载
  134. TL1=0xef; //定义单位节拍的延时大小为10ms
  135. if(k5)music(); //调用闹铃音乐lns
  136. else TR0=0; //达到所设闹铃时间长度关铃声
  137. if(++ms==100) //计时一秒钟
  138. {ms=0;
  139. if(++s1==60) //计时一分钟
  140. {s1=0;
  141. if(++m1==60) //计时一小时
  142. {m1=0;
  143. if(++h1==24) //计时一天
  144. {h1=0;
  145. n=mon(month); //取每月的天数
  146. if(++day>n) //计时一个月
  147. {day=1;
  148. if(++month>12) //计时一年
  149. {month=1;
  150. year++;
  151. }
  152. }
  153. if(++wday>6) //星期计数
  154. wday=0;
  155. }
  156. }
  157. k5--; //闹铃时间长度倒记时
  158. if(h1==h2&&m1==m2) //判断是否到定时时刻
  159. {
  160. TR0=1; //开铃声中断lns
  161. k5=s2; //设置闹铃时间长度
  162. }
  163. }
  164. }
  165. }
  166. /*******************************************************************
  167. * 函数名称:d3()
  168. * 功 能:数码管输出显示
  169. * 入口参数:无
  170. * 出口参数:无
  171. *******************************************************************/
  172. void d3(void) //显示输出
  173. {
  174. uchar sel=0x80,i ; //定义sel为位选通变量并初使化
  175. if(k2) //判断是否处于调时状态
  176. {
  177. if(k2==4)a[0]=a[1]=a[4]=a[6]=a[7]=10; //星期显示设置
  178. if(k1&&(k3--==0)) k3=255; //设置位调节闪烁初值
  179. }
  180. for(i=0;i<=8;i++) //循环显示八个数码管
  181. {
  182. P2=0xff; //清屏
  183. P0=tt[a[i]]; //输出显示数值
  184. if(k1&&(k3>200)) //判断是否闪烁
  185. if (k1==1&&(i==6||i==7))P2=0xff; //时位闪烁
  186. else if(k1==2&&(i==3||i==4))P2=0xff; //分位闪烁
  187. else if(k1==3&&(i==0||i==1))P2=0xff; //秒位闪烁
  188. else P2=~sel; //非闪烁状态
  189. else P2=~sel; //非闪烁状态
  190. sel=sel>>1; //显示位移位
  191. }
  192. }
  193. /*******************************************************************
  194. * 函数名称:d2()
  195. * 功 能:循环调用
  196. * 入口参数:无
  197. * 出口参数:无
  198. *******************************************************************/
  199. void d2(void)
  200. {
  201. while(1)
  202. {
  203. a[0]=*s%10; //给显示数组赋值
  204. a[1]=*s/10;
  205. a[2]=10;
  206. a[3]=*m%10;
  207. a[4]=*m/10;
  208. a[5]=10;
  209. a[6]=*h%10;
  210. a[7]=*h/10;
  211. d3(); //调用显示输出函数
  212. }
  213. }
  214. /*******************************************************************
  215. * 函数名称:d1()
  216. * 功 能:中断设置
  217. * 入口参数:无
  218. * 出口参数:无
  219. *******************************************************************/
  220. void d1(void)
  221. {
  222. TMOD=0x11;
  223. TH1=0xff; TH0=0xff;
  224. TL1=0xff; TL0=0xff;
  225. IE=0x8f;
  226. TR1=1;
  227. IT0=1; IT1=1;
  228. IP=0x02;
  229. }
  230. /*******************************************************************
  231. * 函数名称:main()
  232. * 功 能:程序入口,调用功能子函数
  233. * 入口参数:无
  234. * 出口参数:无
  235. *******************************************************************/
  236. void main(void) {
  237. d1(); //调用中断位设置函数
  238. d2();
  239. }
  240. /*******************************************************************
  241. * 函数名称:d5()
  242. * 功 能:切换显示菜单
  243. * 入口参数:无
  244. * 出口参数:无
  245. *******************************************************************/
  246. void d5(void) //显示菜单调节函数
  247. {
  248. switch(k2)
  249. {
  250. case 1:{h=&h1; m=&m1; s=&s1; }break; //菜单1:显示时钟时间
  251. case 2:{h=&h2; m=&m2; s=&s2; }break; //菜单2:显示定时时刻
  252. case 3:{h=&year;m=&month;s=&day; }break; //菜单3:显示日历年月日
  253. case 4:{h=&wday;m=&wday; s=&wday;}break; //菜单4:显示星期0--6
  254. default:{k2=0;h=&h1;m=&m1;s=&s1; }break; //复位显示
  255. }
  256. }
  257. /*******************************************************************
  258. * 函数名称:d7()
  259. * 功 能:调节限制,防止数值调节超出值域
  260. * 入口参数:无
  261. * 出口参数:无
  262. *******************************************************************/
  263. void d7(void) //调节限制函数
  264. {
  265. if(k2==1||k2==2) //计时与定时限制
  266. if (k1==1&&*p>=24) *p=0; //小时限制
  267. else if(*p>=60) *p=0; //分、秒限制
  268. if(k2==3) //日历限制
  269. if (k1==1&&*p>=100)*p=0; //年限制
  270. else if(k1==2&&*p>12) *p=1; //月限制
  271. else if(k1==3&&*p>n) *p=1; //日限制
  272. if(k2==4)
  273. if (k1==2&&*p>6) *p=0; //星期限制
  274. }
  275. /*******************************************************************
  276. * 函数名称:timer0()
  277. * 功 能:菜单切换及位加数调节
  278. * 入口参数:无
  279. * 出口参数:无
  280. *******************************************************************/
  281. /**外部中断1调节函数**/
  282. void timer0(void)interrupt 0 using 0 //外部中断0调节
  283. {
  284. if(k1) //判断是位调节还是菜单调节
  285. {
  286. (*p)++; //位加数调节
  287. d7(); //调用调节限制函数
  288. }
  289. else
  290. {
  291. k2++; //菜单加数调节
  292. d5(); //调用调节菜单
  293. }
  294. }
  295. /*******************************************************************
  296. * 函数名称:timer2()
  297. * 功 能:调节位选择及关铃声
  298. * 入口参数:无
  299. * 出口参数:无
  300. *******************************************************************/
  301. void timer2(void)interrupt 2 using 2 //外部中断1调节
  302. {
  303. TR0=0;k5=0; //手动关铃声
  304. if(k2) //断是否处于调节状态
  305. {
  306. if (k2==4){k1++;} //期调节位选择
  307. if (++k1==1) p=h; //选择时位
  308. else if(k1==2) p=m; //选择分位
  309. else if(k1==3) p=s; //选择秒位
  310. else k1=0; //复位
  311. }
  312. }
  313. /***************************lns主程序snl***************************/
收藏收藏1 分享淘帖 顶 踩
ID:236006 发表于 2017-12-20 14:36 | 只看该作者
6想下载仿真
ID:99056 发表于 2017-12-27 11:05 | 只看该作者
学习学习了
ID:324066 发表于 2018-5-7 12:23 | 只看该作者
为什么我的不可以运行成功结果?是不是程序中缺少主函数的缘故?
可以给一下源代码和仿真文件给我吗?谢谢!!!!
ID:347549 发表于 2018-6-9 19:34 | 只看该作者
哈哈,学习一下、谢谢老大
