查看: 3227|回复: 0
电一资源:电子时钟(供参考)
ID:73735 发表于 2015-2-19 00:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
单片机作业分享:
    电子时钟1602显示。
    具体计时到每一天,年月恒定(太麻烦)。
    仅供学习和参考。
#include<reg52.h>
#include<intrins.h>
uint tt = 0;
uint nian,yue,ri,shi,fen,miao;
sbit RS = P2^5;
sbit RW = P2^6;
sbit E = P2^7;
void delay(uint z )                           //1ms延时程序
        uint x,y;
        for(x=0;x<z;x++)
                for(y=0;y<114;y++)
void wrcom(uchar com)                        //1602写指令
        RS = 0;
        _nop_();
        RW = 0;
           delay(2);
        P0 = com;
        delay(2);
        E = 1;
        delay(2);
        E = 0;
void wrdat(uchar dat)                        //1602写数据
        RS = 1;
        _nop_();
        RW = 0;
           delay(2);
        P0 = dat;
        delay(2);
        E = 1;
        delay(2);
        E = 0;
void init_1602()                            //1602初始化
        wrcom(0x38);
        delay(15);
        wrcom(0x38);
        delay(5);
        wrcom(0x38);
        delay(5);
        wrcom(0x38);
        wrcom(0x38);
        wrcom(0x08);
        wrcom(0x01);
        wrcom(0x06);
        wrcom(0x0c);
void busy()                                          //1602忙检测
        bit busy_flag;
        P0 =0x80;
        RS = 0;
        _nop_();
        RW = 1;
        delay(2);
        E = 1;
                busy_flag = (bit)(P0&0x80);
                if(busy_flag == 0)
                        break;
        E = 0;
        RW = 0;
void init_timer()                        //定时器0 方式2初始化
        TMOD = 0x02;
        TH0 = 0xa4;
        TL0 = 0xa4;
        ET0 = 1;
        EA = 1;
        TR0 = 1;
void init_time()                        //时间设定
        nian = 2012;
        yue = 11;
        ri = 16;
        shi = 20;
        fen = 30;
        miao = 0;
void time()
        if(tt > 10000)                          //时间状态判定
                miao++;
                tt = 0;
                if(miao == 60)
                        miao = 0;
                        fen++;
                        if(fen == 60)
                                fen = 0;
                                shi++;
                                if(shi == 24)
                                        shi = 0;
                                        ri++;
                                        if(ri == 30)
                                                ri = 0;
                                                yue ++;
void main(void)                                                //主函数
        uchar table1[10] = {'2','0','1','2','/','1','1','/','0','0'};         //时间装入字符数组为了1602
        uchar table2[8] = {'0','0',':','0','0',':','0','0'};
        uchar i;
        init_time();
        init_timer();
        init_1602();                                        //初始化
                time();
                table1[8] = (char)(ri/10+48);
                table1[9] = (char)(ri%10+48);
                table2[0] = (char)(shi/10+48);
                table2[1] = (char)(shi%10+48);
                table2[3] = (char)(fen/10+48);
                table2[4] = (char)(fen%10+48);
                table2[6] = (char)(miao/10+48);
                table2[7] = (char)(miao%10+48);
                busy();
                wrcom(0x80+0x03);
                for(i=0;i<10;i++)
                        busy();
                        wrdat(table1[i]);                //1602第一排写入年月日
                busy();
                wrcom(0x80+0x44);
                for(i=0;i<8;i++)
                        busy();
                        wrdat(table2[i]);                //1602第二排写入时分秒
void timer()interrupt 1
        tt++;
