查看: 5435|回复: 9
求助网上下的程序,没有正反转,求加 KEY_LR= P3^5;//正反转键 按一下正转按一下正转
ID:126608 发表于 2016-7-27 05:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
*求助网上下的程序,没有正反转,求加         KEY_LR= P3^5;//正反转键 按一下正转按一下正转
#include <reg52.h>
* 定时器初值
#define T0HIGH        0xec
#define T0LOWW        0x8a
typedef unsigned char        u8;
typedef unsigned int        u16;
typedef unsigned long        u32;
typedef bit                                BOOL;
* 单片机管脚定义
sbit KEY_ON = P3^2;
sbit KEY_INC = P3^3;
sbit KEY_DEC = P3^4;
sbit KEY_LR= P3^5;//正反转键 按一下正转按一下正转
sbit MOTO_LEFT = P3^6;//正转
sbit MOTO_RIGHT = P3^7;//反转
* 按键定义
#define KEY_NULL                0xff
#define KEY_LONG_PERIOD        25
#define KEY_CONTINUE_PERIOD        20
#define KEY_DOWN                0x80
#define KEY_CONTINUE        0x40
#define KEY_UP                        0x20
#define KEY_STATE_INIT                0
#define KEY_STATE_WOBBLE        1
#define KEY_STATE_PRESS                2
#define KEY_STATE_LONG                3
#define KEY_STATE_CONTINUE        4
#define KEY_STATE_RELEASE        5
#define KEY_ON_VALUE                1
#define KEY_INC_VALUE                2
#define KEY_DEC_VALUE                3
#define KEY_ON                (KEY_ON_VALUE | KEY_DOWN)
#define KEY_INC                (KEY_INC_VALUE | KEY_DOWN)
#define KEY_INC_CON        (KEY_INC_VALUE | KEY_CONTINUE)
#define KEY_DEC                (KEY_DEC_VALUE | KEY_DOWN)
#define KEY_DEC_CON        (KEY_DEC_VALUE | KEY_CONTINUE)
* 常量定义
#define true        1
#define false        0
#define MOTO_ON                MOTO_LEFT = false;\
                                        MOTO_RIGHT = true
#define MOTO_OFF        MOTO_LEFT = true;\
                                        MOTO_RIGHT = true
* 全局变量定义
code u8 DisCode[] = {0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0xff};
u8 PWMpercent = 0;
u8 DisNum[4] = {0x0a, 0x0a, 0x0a, 0x00};
u8 DisPosition = 0;
u8 SecCount = 0;
u8 u10msNum = 0;
BOOL b10msEvent = false;
BOOL b100msEvent = false;
BOOL b1secEvent = false;
BOOL MotoStart = false;
BOOL MotoRun = false;
void Key_Prosess(void);
void Dynamic_Display(void);
void Speed_Display(void);
* 主函数
main()
        TMOD = 0x01;
        TH0 = T0HIGH;
        TL0 = T0LOWW;
        TR0 = 1;
        ET0 = 1;
        EA = 1;
        P1 = 0x00;
                if(true == b10msEvent)        //10毫秒定时标志
                        b10msEvent = false;
                        Key_Prosess();                //按键扫描
                        Dynamic_Display();                //动态显示
                        if(true == MotoStart)        //如果电机启动
                                if(true == MotoRun)
                                        if(--u10msNum == 0)                //如果电机转动时间到,停止电机
                                                MotoRun = false;
                                                MOTO_OFF;
                                if(true == b1secEvent)                //PWM周期为1秒,1秒钟时间到,开始下一个周期
                                        b1secEvent = false;
                                        MotoRun = true;
                                        MOTO_ON;
                                        u10msNum = PWMpercent;
* 清显示
void Num_Clear(void)
        u8 i;
        for(i=0; i<3; i++)
                DisNum[i] = 0x0a;
        DisNum[3] = 0x00;
* 读键值
u8 Key_Scan(void)
        if(KEY_ON == false)
                return KEY_ON_VALUE;
        if(KEY_LR == false)
        if(KEY_INC == false)
                return KEY_INC_VALUE;
        if(KEY_DEC == false)
                return KEY_DEC_VALUE;
        return KEY_NULL;
* 按键状态扫描
u8 GetKey(void)
        static u8 KeyState = KEY_STATE_INIT;
        static u8 KeyTimeCount = 0;
        static u8 LastKey = KEY_NULL;        //保存按键释放时候的键值
        u8 KeyTemp = KEY_NULL ;
        KeyTemp = Key_Scan();
        switch(KeyState)
                case KEY_STATE_INIT:        //初始状态
                        if(KEY_NULL != KeyTemp)        //有键按下
                                KeyState = KEY_STATE_WOBBLE;        //进入消抖
                        break;
                case KEY_STATE_WOBBLE:        //消抖
                        KeyState = KEY_STATE_PRESS;
                        break;
                case KEY_STATE_PRESS:
                                LastKey = KeyTemp;        //保存键值,以便在释放按键状态返回键值
                                KeyTemp |= KEY_DOWN;        //按键按下
                                KeyState = KEY_STATE_LONG;
                        break;
                case KEY_STATE_LONG:
                                if(++KeyTimeCount >= KEY_LONG_PERIOD)
                                        KeyTimeCount = 0;
                                        KeyState = KEY_STATE_CONTINUE;
                                KeyState = KEY_STATE_RELEASE;
                        break;
                case KEY_STATE_CONTINUE:
                        if(KEY_NULL != (KeyTemp))
                                if(++KeyTimeCount >= KEY_CONTINUE_PERIOD)
                                        KeyTimeCount = 0;
                                        KeyTemp |= KEY_CONTINUE;  //连击按键事件发生
                        break;
                case KEY_STATE_RELEASE:
                        LastKey |= KEY_UP;        //按键释放
                        KeyTemp = LastKey;
                        break;
                default:
                        break;
        return KeyTemp;
* 按键功能处理
        u8 KeyData;
        KeyData = GetKey();
        switch(KeyData)
                case KEY_ON:        //开关电机
                                MotoStart = false;
                                Num_Clear();
                                MOTO_OFF;
                                MotoRun = false;
                                PWMpercent= 0;
                                MotoStart = true;
                                MOTO_ON;
                                MotoStart = true;
                                MotoRun = true;
                                u10msNum = PWMpercent = 1;
                        break;
                case KEY_INC:        //单步增加
                case KEY_INC_CON:        //连续增加
                        if((PWMpercent < 100) && MotoStart)                //PWM从1%~100%
                                PWMpercent++;
                        break;
                case KEY_DEC:        //单步减小
                case KEY_DEC_CON:        //连续减小
                        if((PWMpercent > 1) && MotoStart)                //PWM从1%~100%
                                PWMpercent--;
                        break;
                default:
                        break;
        Speed_Display();
* 速度转换成十进制数
        u8 i;
        DisNum[1] = PWMpercent / 100;
        DisNum[2] = PWMpercent % 100 / 10;
        DisNum[3] = PWMpercent % 10;
        for(i=1; i<3; i++)
                if(DisNum[i] != 0)
                        break;
                DisNum[i] = 0x0a;
* 动态显示速度百分比
        static u8 DisPinOn = 0x01;
        DisPinOn <<= 1;
        if(DisPinOn == 0x10)
                DisPosition = 0;
                DisPinOn = 0x01;
        P1 = 0xff;
        P2 = DisPinOn;
        P1 = DisCode[DisNum[DisPosition++]];
* 定时器0中断
void timer0(void) interrupt 1
        TH0 = T0HIGH;
        TL0 = T0LOWW;
        b10msEvent = true;                //10毫秒中断
        if(++SecCount == 100)
                SecCount = 0;
                b1secEvent = true;                //1秒到时
ID:126608 发表于 2016-8-2 07:39 | 只看该作者
没人回复,请管理员改一下,用我的80黑币,奖给解决问题的人,谢谢您。
ID:121156 发表于 2016-8-2 16:53 | 只看该作者
回帖奖励 +2
前面增加定义:
#define KEY_LR_VALUE                4
#define KEY_LR                (KEY_LR_VALUE | KEY_DOWN)
* 读键值
u8 Key_Scan(void)
        if(KEY_ON == false)
        if(KEY_LR == false)
                return KEY_LR_VALUE;
        return KEY_NULL;
* 按键功能处理
        u8 KeyData;
        KeyData = GetKey();
        switch(KeyData)
                case KEY_ON:        //开关电机
                                MotoStart = false;
                                Num_Clear();
                                MOTO_OFF;
                                MotoRun = false;
                                PWMpercent= 0;
                                MotoStart = true;
                                MOTO_ON;
                                MotoStart = true;
                                MotoRun = true;
                        break;
                                PWMpercent++;
                        break;
                                PWMpercent--;
                        break;
               case KEY_LR:                        if(ture==MOTO_LEFT)
                                 MOTO_LEFT=false;
                                 MOTO_RIGHT=ture;
                                MOTO_LEFT=ture;
                                 MOTO_RIGHT=false;
                default:
                        break;
        Speed_Display();
ID:121156 发表于 2016-8-2 17:10 | 只看该作者
getkey有点复杂化了
ID:111634 发表于 2016-8-3 21:22 | 只看该作者
与其奖给80黑币,不如买本有效的书可靠。
张志良编著《80C51单片机仿真设计实例教程——基于Keil C和Proteus》清华大学出版社ISBN 978-7-302-41682-1
实例98  驱动四相步进电动机
实例99  驱动二相步进电动机
实例100  驱动直流电动机正反转及PWM调速
书中电路和程序设计有详细说明,程序语句条条有注解。
ID:126608 发表于 2016-8-4 15:21 | 只看该作者
感谢PK250指导。改了后仿真还没有正反转,不知那里还不对,希望得到进一步帮助。现把工程文件和仿真文件发上。 电机PWM显示.rar (89.86 KB, 下载次数: 15)
ID:86913 发表于 2016-8-5 17:50 | 只看该作者
谢谢zl2168的介绍
ID:135253 发表于 2016-8-5 19:54 | 只看该作者
怎么按,P3.7脚似乎都没有脉冲信号?应该检查一下3.7脚信号的来源
ID:135253 发表于 2016-8-5 20:02 | 只看该作者
还有,按ON键(P3.2)时,P3.6脚就有信号,这似乎不太对劲,按正转(P3.2),P3.7脚应该有信号,但是没有,总之,P3.7脚信号的来源仔细检查一下
ID:126608 发表于 2016-8-6 06:57 | 只看该作者
是的,原先是没反转,我加不上才发贴的,但这份资料却很珍贵,键铿k可以单点和连续,希望有高人将反转加上。
