查看: 2100|回复: 0
STM32单片机外部中断失效?
ID:833967 发表于 2023-3-26 16:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大佬们帮忙看看,外部中断初始化后按键按下没有作用,不知道是什么问题呀?大佬们看看下面单片机源码:
exit.c
#include "exti.h"
#include "oled.h"
#include "key.h"
#include "risk.h"
#include "delay.h"
#include "usart.h"
extern int oledSwitchFlag;        //oledSwitchFlag实现外部中断切换页面
extern int valueMode;                //valueMode实现阈值上限下限的切换  0-上限 1-下限
extern int temp_up, temp_low;                                                //温度阈值, up上限,low下限
extern int humi_up, humi_low;                                                //湿度阈值, up上限,low下限
extern int hydr_up;        //氢气阈值, up上限,气体只设置上限阈值
extern int carbon_up;        //一氧化碳阈值, up上限,气体只设置上限阈值
extern int natgas_up;        //天然气阈值, up上限,气体只设置上限阈值
extern int Timer3_Switch;                                                        //定时器TIM3的开关标记位
extern int riskFlag;
void EXTIX_Init(void)
           EXTI_InitTypeDef EXTI_InitStructure;
         NVIC_InitTypeDef NVIC_InitStructure;
        KEYInit();        //按键模块初始化
          RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE);
   //GPIOB12          //KEY_Mode
          GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource12);
          EXTI_InitStructure.EXTI_Line=EXTI_Line12;
        EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
          EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
          EXTI_Init(&EXTI_InitStructure);
   //GPIOB13          //KEY_Add
          GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource13);
          EXTI_InitStructure.EXTI_Line=EXTI_Line13;
        //GPIOB14          //KEY_Reduce
          GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource14);
          EXTI_InitStructure.EXTI_Line=EXTI_Line14;
        //GPIOB15          //KEY_Control
          GPIO_EXTILineConfig(GPIO_PortSourceGPIOB,GPIO_PinSource15);
          EXTI_InitStructure.EXTI_Line=EXTI_Line15;
   //GPIOA.0           PA0  WK_UP
         GPIO_EXTILineConfig(GPIO_PortSourceGPIOA,GPIO_PinSource0);
          EXTI_InitStructure.EXTI_Line=EXTI_Line0;
          EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
          NVIC_InitStructure.NVIC_IRQChannel = EXTI0_IRQn;
          NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x00;
          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x00;
          NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
          NVIC_Init(&NVIC_InitStructure);
          NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
          NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x01;
void EXTI0_IRQHandler(void)
        delay_ms(10);
        if(WK_UP == 1){
                Risk != Risk;
        EXTI_ClearITPendingBit(EXTI_Line0);
void EXTI15_10_IRQHandler(void)
        delay_ms(10);
        if(KEY_Mode == 0){                        //模式按键
                oledSwitchFlag++;
                OLED_Clear();
                UsartPrintf(USART_DEBUG,"oledSwitchFlag=%d\r\n",oledSwitchFlag);
                if(valueMode != 0)
                        valueMode = 0;
                if(oledSwitchFlag == 6)
                        oledSwitchFlag = 0;
                EXTI_ClearITPendingBit(EXTI_Line12);
        if(KEY_Add == 0){                        //数值加
                if(oledSwitchFlag == 0)        //控制警报
                        riskFlag = 0;
                if(oledSwitchFlag == 1){
                        if(valueMode == 0){
                                temp_up++;
                                if(temp_up > 99)
                                        temp_up = 0;
                        }else{
                                temp_low++;
                                if(temp_low > 99)
                                        temp_low = 0;
                }else if(oledSwitchFlag == 2){
                        if(valueMode == 0){
                                humi_up++;
                                if(humi_up > 99)
                                        humi_up = 0;
                        }else{
                                humi_low++;
                                if(humi_low > 99)
                                        humi_low = 0;
                }else if(oledSwitchFlag == 3){
                        hydr_up++;
                        if(hydr_up > 99)
                                hydr_up = 0;
                }else if(oledSwitchFlag == 4){
                        carbon_up++;
                        if(carbon_up > 99)
                                carbon_up = 0;
                }else if(oledSwitchFlag == 5){
                        natgas_up++;
                        if(natgas_up > 99)
                                natgas_up = 0;
                EXTI_ClearITPendingBit(EXTI_Line13);
        if(KEY_Reduce == 0){                //数值减
                        if(valueMode == 0){
                                temp_up--;
                                if(temp_up < 0)
                                        temp_up = 99;
                        }else{
                                temp_low--;
                                if(temp_low < 0)
                                        temp_low = 99;
                        if(valueMode == 0){
                                humi_up--;
                                if(humi_up < 0)
                                        humi_up = 99;
                        }else{
                                humi_low--;
                                if(humi_low < 0)
                                        humi_low = 99;
                        hydr_up--;
                        if(hydr_up < 0)
                                hydr_up = 99;
                        carbon_up--;
                        if(carbon_up < 0)
                                carbon_up = 99;
                        natgas_up--;
                        if(natgas_up < 0)
                                natgas_up = 99;
                EXTI_ClearITPendingBit(EXTI_Line14);
        if(KEY_Control == 0){                //控制光标和数据动态切屏
                if(oledSwitchFlag == 0){
                        if(Timer3_Switch == 1){
                                TIM_Cmd(TIM3, DISABLE);        //关闭定时器TIM3
                                Timer3_Switch = 0;
                        }else if(Timer3_Switch ==0){
                                TIM_Cmd(TIM3, ENABLE);        //打开定时器TIM3
                                Timer3_Switch = 1;
                }else if(oledSwitchFlag == 1 || oledSwitchFlag == 2){
                        valueMode++;
                        OLED_Clear();
                        if(valueMode > 1)
                                valueMode = 0;
                EXTI_ClearITPendingBit(EXTI_Line15);
key.c
#include "key.h"
void KEYInit(void){
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPU;
        GPIO_Init(GPIOB ,&GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode=GPIO_Mode_IPD;
        GPIO_Init(GPIOA,&GPIO_InitStructure);
