查看: 7044|回复: 4
讯为4412开发板运行linux系统无法挂载U盘?
ID:188759 发表于 2017-6-8 09:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
基于讯为4412开发板:
插上U盘
[ 2407.650440] usb 1-3.3: new high speed USB device number 7 using s5p-ehci
[ 2407.887332] usb 1-3.3: New USB device found, idVendor=0951, idProduct=1666, bcdDevice=0100
[ 2407.894249] usb 1-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2407.901651] usb 1-3.3: New USB device Class: class="0", SubClass=0, Protocol=0
[ 2407.908558] usb 1-3.3: Product: DataTraveler 3.0
[ 2407.913150] usb 1-3.3: Manufacturer: Kingston
[ 2407.917488] usb 1-3.3: SerialNumber: 50E5495131F7B0A0495A3E9A
[ 2407.945454] scsi3 : usb-storage 1-3.3:1.0
[ 2408.981773] scsi 3:0:0:0: Direct-Access     Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[ 2409.002820] sd 3:0:0:0: Attached scsi generic sg0 type 0
[ 2410.472934] sd 3:0:0:0: [sda] 60632064 512-byte logical blocks: (31.0 GB/28.9 GiB)
[ 2410.482241] sd 3:0:0:0: [sda] Write Protect is off
[ 2410.486619] sd 3:0:0:0: [sda] No Caching mode page present
[ 2410.491237] sd 3:0:0:0: [sda] Assuming drive cache: write through
[ 2410.503131] sd 3:0:0:0: [sda] No Caching mode page present
[ 2410.507269] sd 3:0:0:0: [sda] Assuming drive cache: write through
[ 2410.527868]  sda: sda1
[ 2410.549386] sd 3:0:0:0: [sda] No Caching mode page present
[ 2410.553692] sd 3:0:0:0: [sda] Assuming drive cache: write through
[ 2410.585133] sd 3:0:0:0: [sda] Attached SCSI removable disk
挂载U盘失败
~ # mount /dev/sda1 /mnt/udisk/
mount: mounting /dev/sda1 on /mnt/udisk/ failed: No such device or address
~ # mount /dev/sda /mnt/udisk/
mount: mounting /dev/sda on /mnt/udisk/ failed: Invalid argument
查看/dev
~ # ls /dev/
/dev中没有sdb1这个设备节点
手动创建节点
~ # mknod  /dev/sda1 b 8 1
挂载U盘
~ # ls /mnt/udisk/
Linux
挂载U盘成功
ID:188383 发表于 2017-6-9 10:05 | 只看该作者
看过楼主帖子,内容不错,多分享
ID:151620 发表于 2017-6-12 10:08 | 只看该作者
看过受益了,好帖子
ID:235680 发表于 2017-9-29 10:23 | 只看该作者
共同交流学习呀
ID:228570 发表于 2017-11-7 10:15 | 只看该作者
了解一下这块板子,有兴趣
