在 VK2635官方文档中,各个指令虽然已经换成16进制,但是在使用时总是不方便。
我在使用中,将代码归纳整理,修改成了单片机能直接使用的16进制格式。
下面是部分代码截图。
编辑的代码
- uint8_t ModCmd0[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x44,0x54,0x4d,0x2a,0x33,0x42,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x0a,0x00,0x04,0x23}; //--> 关闭GPDTM语句0
- uint8_t ModCmd1[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x42,0x53,0x2a,0x33,0x30,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x09,0x00,0x03,0x21}; //--> 关闭GPGBS语句1
- uint8_t ModCmd2[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x47,0x41,0x2a,0x32,0x37,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x00,0x00,0xfa,0x0f}; //--> 关闭GPGGA语句2
- uint8_t ModCmd3[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x4c,0x4c,0x2a,0x32,0x31,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x01,0x00,0xfb,0x11}; //--> 关闭GPGLL语句3
- uint8_t ModCmd4[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x53,0x41,0x2a,0x33,0x33,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x02,0x00,0xfc,0x13}; //--> 关闭GPGSA语句4
- uint8_t ModCmd5[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x53,0x54,0x2a,0x32,0x36,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x07,0x00,0x01,0x1d}; //--> 关闭GPGST语句5
- uint8_t ModCmd6[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x53,0x56,0x2a,0x32,0x34,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x03,0x00,0xfd,0x15}; //--> 关闭GPGSV语句6
- uint8_t ModCmd7[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x52,0x4d,0x43,0x2a,0x33,0x41,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x04,0x00,0xfe,0x17}; //--> 关闭GPRMC语句70x
- uint8_t ModCmd8[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x56,0x54,0x47,0x2a,0x32,0x33,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x05,0x00,0xff,0x19};//--> 关闭GPVTG语句8
- uint8_t ModCmd9[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x5a,0x44,0x41,0x2a,0x33,0x39,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x08,0x00,0x02,0x1f}; //--> 关闭GPZDA语句9
- uint8_t ModCmd10[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x44,0x54,0x4d,0x2a,0x33,0x42,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x0a,0x01,0x05,0x24}; //--> 打开GPDTM语句10
- uint8_t ModCmd11[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x42,0x53,0x2a,0x33,0x30,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x09,0x01,0x04,0x22}; //--> 打开GPGBS语句11
- uint8_t ModCmd12[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x47,0x41,0x2a,0x32,0x37,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x00,0x01,0xfb,0x10}; //--> 打开GPGGA语句12
- uint8_t ModCmd13[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x4c,0x4c,0x2a,0x32,0x31,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x01,0x01,0xfc,0x12}; //--> 打开GPGLL语句13
- uint8_t ModCmd14[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x52,0x53,0x2a,0x32,0x30,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x06,0x01,0x01,0x1c}; //--> 打开GPGRS语句14
- uint8_t ModCmd15[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x53,0x41,0x2a,0x33,0x33,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x02,0x01,0xfd,0x14}; //--> 打开GPGSA语句15
- uint8_t ModCmd16[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x53,0x54,0x2a,0x32,0x36,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x07,0x01,0x02,0x1e}; //--> 打开GPGST语句16
- uint8_t ModCmd17[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x47,0x53,0x56,0x2a,0x32,0x34,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x03,0x01,0xfe,0x16}; //--> 打开GPGSV语句17
- uint8_t ModCmd18[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x52,0x4d,0x43,0x2a,0x33,0x41,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x04,0x01,0xff,0x18}; //--> 打开GPRMC语句18
- uint8_t ModCmd19[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x56,0x54,0x47,0x2a,0x32,0x33,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x05,0x01,0x00,0x1a}; //--> 打开GPVTG语句19
- uint8_t ModCmd20[]=
- {0x24,0x45,0x49,0x47,0x50,0x51,0x2c,0x5a,0x44,0x41,0x2a,0x33,0x39,0x0d,0x0a,0xb5,0x62,0x06,0x01,0x03,0x00,0xf0,0x08,0x01,0x03,0x20}; //--> 打开GPZDA语句200
- uint8_t BootSetCmd0[]=
- {0xb5,0x62,0x06,0x00,0x14,0x00,0x01,0x00,0x00,0x00,0xd0,0x08,0x00,0x00,0xc0,0x12,0x00,0x00,0x07,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0xd3,0xfc,0xb5,0x62,0x06,0x00,0x01,0x00,0x01,0x08,0x22}; //设置4800波特率0
- uint8_t BootSetCmd1[]=
- {0xb5,0x62,0x06,0x00,0x14,0x00,0x01,0x00,0x00,0x00,0xd0,0x08,0x00,0x00,0x80,0x25,0x00,0x00,0x07,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0xa6,0xcd,0xb5,0x62,0x06,0x00,0x01,0x00,0x01,0x08,0x22}; //设置9600波特率1
- uint8_t BootSetCmd2[]=
- {0xb5,0x62,0x06,0x00,0x14,0x00,0x01,0x00,0x00,0x00,0xd0,0x08,0x00,0x00,0x00,0x96,0x00,0x00,0x07,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x97,0xa8}; //设置38400波特率2
- uint8_t BootSetCmd3[]=
- {0xb5,0x62,0x06,0x00,0x14,0x00,0x01,0x00,0x00,0x00,0xd0,0x08,0x00,0x00,0x00,0xc2,0x01,0x00,0x07,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0xc4,0x96,0xb5,0x62,0x06,0x00,0x01,0x00,0x01,0x08,0x22}; //设置115200波特率3
- uint8_t HZ_SetCmd0[]=
- {0xB5,0x62,0x06,0x08,0x06,0x00,0xE8,0x03,0x01,0x00,0x01,0x00,0x01,0x39}; //1Hz模式(1秒输出1次数据)0
- uint8_t HZ_SetCmd1[]=
- {0xB5,0x62,0x06,0x08,0x06,0x00,0xC8,0x00,0x01,0x00,0x01,0x00,0xDE,0x6A,0xB5,0x62,0x06,0x08,0x00,0x00,0x0E,0x30}; //5Hz模式(1秒输出5次数据)1
- uint8_t HZ_SetCmd2[]=
- {0xB5,0x62,0x06,0x08,0x06,0x00,0x64,0x00,0x01,0x00,0x01,0x00,0x7A,0x12,0xB5,0x62,0x06,0x08,0x00,0x00,0x0E,0x30}; //10Hz模式(1秒输出10次数据)2
- uint8_t HZ_SetCmd3[]=
- {0xB5,0x62,0x06,0x08,0x06,0x00,0xB8,0x0B,0x01,0x00,0x01,0x00,0xD9,0x41,0xB5,0x62,0x06,0x08,0x00,0x00,0x0E,0x30}; //0.33Hz模式(3秒输出1次数据)3
- uint8_t HZ_SetCmd4[]=
- {0xB5,0x62,0x06,0x08,0x06,0x00,0x88,0x13,0x01,0x00,0x01,0x00,0xB1,0x49,0xB5,0x62,0x06,0x08,0x00,0x00,0x0E,0x30}; //0.2Hz模式(5秒输出1次数据)4
- uint8_t HZ_SetCmd5[]=
- {0xB5,0x62,0x06,0x08,0x06,0x00,0x10,0x27,0x01,0x00,0x01,0x00,0x4D,0xDD,0xB5,0x62,0x06,0x08,0x00,0x00,0x0E,0x30}; //0.1Hz模式(10秒输出1次数据) 5
- uint8_t HZ_SetCmd6[]=
- {0xB5,0x62,0x06,0x08,0x06,0x00,0x20,0x4E,0x01,0x00,0x01,0x00,0x84,0x00,0xB5,0x62,0x06,0x08,0x00,0x00,0x0E,0x30}; //0.05Hz模式(20秒输出1次数据) 6
- uint8_t StartModCmd0[]=
- {0xB5,0x62,0x06,0x04,0x04,0x00,0xFF,0x87,0x01,0x00,0x95,0xF7}; //复位 0
- uint8_t StartModCmd1[]=
- {0xB5,0x62,0x06,0x04,0x04,0x00,0xFF,0xFF,0x02,0x00,0x0E,0x61}; //冷启劢 1
- uint8_t StartModCmd2[]=
- {0xB5,0x62,0x06,0x04,0x04,0x00,0x00,0x00,0x02,0x00,0x10,0x68}; //热启劢2
- uint8_t StartModCmd3[]=
- {0xB5,0x62,0x06,0x09,0x0D,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x07,0x1F,0x9E}; //恢复出厂配置 3
- uint8_t StartModCmd4[]=
- {0xB5,0x62,0x06,0x04,0x04,0x00,0x00,0x00,0x08,0x00,0x16,0x74}; //进入低功耗模式(低功耗模式状态下丌输出数据,但保持定位。如需恢复正常模式,请输入热启劢命令)4
- uint8_t StartModCmd5[]=
- {0xB5,0x62,0x06,0x09,0x0D,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x17,0x31,0xBF}; //保存设置5
GPS_CMD.zip
(1.35 KB, 下载次数: 12)
