2440 ARM裸奔实现电子时钟,对我们学习ARM体系很有帮助,原创全部源码下载:
LCD--ZHIKU.rar
(1 MB, 下载次数: 15)
- // File Name : 2440lib.c
- // Function : S3C2410 PLL,Uart, LED, Port Init
- // Date : March 20, 2002
- // Version : 0.0
- // History
- // 0.0 : Programming start (February 20,2002) -> SOP
- #include "def.h"
- #include "option.h"
- #include "2440addr.h"
- #include "2440lib.h"
- #include "2440slib.h"
- #include <stdarg.h>
- #include <string.h>
- #include <stdlib.h>
- #include <stdio.h>
- #include <ctype.h>
- extern char Image$RW$Limit[];
- void *mallocPt=Image$RW$Limit;
- //***************************[ SYSTEM ]***************************************************
- void Delay(int time)
- U32 val = (PCLK>>3)/1000-1;
- rTCFG0 &= ~(0xff<<8);
- rTCFG0 |= 3<<8; //prescaler = 3+1
- rTCFG1 &= ~(0xf<<12);
- rTCFG1 |= 0<<12; //mux = 1/2
- rTCNTB3 = val;
- rTCMPB3 = val>>1; // 50%
- rTCON &= ~(0xf<<16);
- rTCON |= 0xb<<16; //interval, inv-off, update TCNTB3&TCMPB3, start timer 3
- rTCON &= ~(2<<16); //clear manual update bit
- while(time--) {
- while(rTCNTO3>=val>>1);
- while(rTCNTO3<val>>1);
- //***************************[ PORTS ]****************************************************
- void Port_Init0(void)
- //CAUTION:Follow the configuration order for setting the ports.
- // 1) setting value(GPnDAT)
- // 2) setting control register (GPnCON)
- // 3) configure pull-up resistor(GPnUP)
- //32bit data bus configuration
- //*** PORT A GROUP
- //Ports : GPA22 GPA21 GPA20 GPA19 GPA18 GPA17 GPA16 GPA15 GPA14 GPA13 GPA12
- //Signal : nFCE nRSTOUT nFRE nFWE ALE CLE nGCS5 nGCS4 nGCS3 nGCS2 nGCS1
- //Binary : 1 1 1 , 1 1 1 1 , 1 1 1 1
- //Ports : GPA11 GPA10 GPA9 GPA8 GPA7 GPA6 GPA5 GPA4 GPA3 GPA2 GPA1 GPA0
- //Signal : ADDR26 ADDR25 ADDR24 ADDR23 ADDR22 ADDR21 ADDR20 ADDR19 ADDR18 ADDR17 ADDR16 ADDR0
- //Binary : 1 1 1 1 , 1 1 1 1 , 1 1 1 1
- rGPACON = 0x7fffff;
- //**** PORT B GROUP
- //Ports : GPB10 GPB9 GPB8 GPB7 GPB6 GPB5 GPB4 GPB3 GPB2 GPB1 GPB0
- //Signal : nXDREQ0 nXDACK0 nXDREQ1 nXDACK1 nSS_KBD nDIS_OFF L3CLOCK L3DATA L3MODE nIrDATXDEN Keyboard
- //Setting: INPUT OUTPUT INPUT OUTPUT INPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT OUTPUT
- //Binary : 00 , 01 00 , 01 00 , 01 01 , 01 01 , 01 01
- rGPBCON = 0x044555;
- rGPBUP = 0x7ff; // The pull up function is disabled GPB[10:0]
- //*** PORT C GROUP for youlong
- //Ports : GPC15 GPC14 GPC13 GPC12 GPC11 GPC10 GPC9 GPC8 GPC7 GPC6 GPC5 GPC4 GPC3 GPC2 GPC1 GPC0
- //Signal : VD7 VD6 VD5 VD4 VD3 VD2 VD1 VD0 LCDVF2 LCDVF1 LCDVF0 VM VFRAME VLINE VCLK LEND
- //Binary : 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 10
- rGPCCON = 0xaaaaaaaa;
- rGPCUP = 0xffff; // The pull up function is disabled GPC[15:0]
- //*** PORT D GROUP
- //Ports : GPD15 GPD14 GPD13 GPD12 GPD11 GPD10 GPD9 GPD8 GPD7 GPD6 GPD5 GPD4 GPD3 GPD2 GPD1 GPD0
- //Signal : VD23 VD22 VD21 VD20 VD19 VD18 VD17 VD16 VD15 VD14 VD13 VD12 VD11 VD10 VD9 VD8
- //Binary : 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 10 ,10 10
- rGPDCON = 0xaaaaaaaa;
- rGPDUP = 0xffff; // The pull up function is disabled GPD[15:0]
- //*** PORT E GROUP
- //Ports : GPE15 GPE14 GPE13 GPE12 GPE11 GPE10 GPE9 GPE8 GPE7 GPE6 GPE5 GPE4
- //Signal : IICSDA IICSCL SPICLK SPIMOSI SPIMISO SDDATA3 SDDATA2 SDDATA1 SDDATA0 SDCMD SDCLK IN
- //Binary : 10 10 , 10 10 , 10 10 , 10 10 , 10 10 , 10 00 ,
- //Ports : GPE3 GPE2 GPE1 GPE0
- //Signal : IN IN IN IN
- //Binary : 00 00 , 00 00
- //rGPECON = 0xaaaaaaaa;
- //rGPEUP = 0xffff; // The pull up function is disabled GPE[15:0]
- rGPECON = 0xaaaaa800; // For added AC97 setting
- rGPEUP = 0xffff;
- //*** PORT F GROUP
- //Ports : GPF7 GPF6 GPF5 GPF4 GPF3 GPF2 GPF1 GPF0
- //Signal : nLED_8 nLED_4 nLED_2 nLED_1 nIRQ_PCMCIA EINT2 KBDINT EINT0
- //Setting: Output Output Output Output EINT3 EINT2 EINT1 EINT0
- //Binary : 01 01 , 01 01 , 10 10 , 10 10
- rGPFCON = 0x55aa;
- rGPFUP = 0xff; // The pull up function is disabled GPF[7:0]
- //*** PORT G GROUP
- //Ports : GPG15 GPG14 GPG13 GPG12 GPG11 GPG10 GPG9 GPG8 GPG7 GPG6
- //Signal : nYPON YMON nXPON XMON EINT19 DMAMODE1 DMAMODE0 DMASTART KBDSPICLK KBDSPIMOSI
- //Setting: nYPON YMON nXPON XMON EINT19 Output Output Output SPICLK1 SPIMOSI1
- //Binary : 11 11 , 11 11 , 10 01 , 01 01 , 11 11
- //Ports : GPG5 GPG4 GPG3 GPG2 GPG1 GPG0
- //Signal : KBDSPIMISO LCD_PWREN EINT11 nSS_SPI IRQ_LAN IRQ_PCMCIA
- //Setting: SPIMISO1 LCD_PWRDN EINT11 nSS0 EINT9 EINT8
- //Binary : 11 11 , 10 11 , 10 10
- rGPGCON = 0xff95ffba;
- rGPGUP = 0xffff; // The pull up function is disabled GPG[15:0]
- //*** PORT H GROUP
- //Ports : GPH10 GPH9 GPH8 GPH7 GPH6 GPH5 GPH4 GPH3 GPH2 GPH1 GPH0
- //Signal : CLKOUT1 CLKOUT0 UCLK nCTS1 nRTS1 RXD1 TXD1 RXD0 TXD0 nRTS0 nCTS0
- //Binary : 10 , 10 10 , 11 11 , 10 10 , 10 10 , 10 10
- rGPHCON = 0x2afaaa;
- rGPHUP = 0x7ff; // The pull up function is disabled GPH[10:0]
- // Added for S3C2440X, DonGo
- //*** PORT J GROUP
- //Ports : GPJ12 GPJ11 GPJ10 GPJ9 GPJ8 GPJ7 GPJ6 GPJ5 GPJ4 GPJ3 GPJ2 GPJ1 GPJ0
- //Signal : CAMRESET CAMPCLKOUT CAMHREF CAMVSYNC CAMPCLKIN CAMDAT[7] CAMDAT[6] CAMDAT[5] CAMDAT[4] CAMDAT[3] CAMDAT[2] CAMDAT[1] CAMDAT[0]
- //Binary : 10 10 10 10 10 10 10 10 10 10 10 10 10
- rGPJCON = 0x02aaaaaa;
- rGPJUP = 0x1fff; // The pull up function is disabled GPH[10:0]
- //External interrupt will be falling edge triggered.
- rEXTINT0 = 0x22222222; // EINT[7:0]
- rEXTINT1 = 0x22222222; // EINT[15:8]
- rEXTINT2 = 0x22222222; // EINT[23:16]
- void Port_Init(void)
- //rGPBCON = 0x000150;(youlong)
- rGPBCON = 0x015550;
- //rGPCCON = 0xaaaaaaaa;
- //rGPCUP = 0xffff; // The pull up function is disabled GPC[15:0]
- //Binary : 10 10 , 10 10 , 10 10 , 10 01 , 01 01 , 01 10 , 10 10 , 10 10
- rGPCCON = 0xaaa956aa;
- rGPECON = 0xa02aa800; // For added AC97 setting
- rGPEUP = 0xffff;
- rGPFCON = 0x55aa;
- rGPGCON = 0x00a2aaaa;// GPG9 input without pull-up
- rGPHCON = 0x00faaa;
- //***************************[ UART ]******************************
- static int whichUart=0;
- void Uart_Init(int pclk,int baud)
- int i;
- if(pclk == 0)
- pclk = PCLK;
- rUFCON0 = 0x0; //UART channel 0 FIFO control register, FIFO disable
- rUFCON1 = 0x0; //UART channel 1 FIFO control register, FIFO disable
- rUFCON2 = 0x0; //UART channel 2 FIFO control register, FIFO disable
- rUMCON0 = 0x0; //UART chaneel 0 MODEM control register, AFC disable
- rUMCON1 = 0x0; //UART chaneel 1 MODEM control register, AFC disable
- //UART0
- rULCON0 = 0x3; //Line control register : Normal,No parity,1 stop,8 bits
- // [10] [9] [8] [7] [6] [5] [4] [3:2] [1:0]
- // Clock Sel, Tx Int, Rx Int, Rx Time Out, Rx err, Loop-back, Send break, Transmit Mode, Receive Mode
- // 0 1 0 , 0 1 0 0 , 01 01
- // PCLK Level Pulse Disable Generate Normal Normal Interrupt or Polling
- rUCON0 = 0x245; // Control register
- rUBRDIV0=( (int)(pclk/16./baud+0.5) -1 ); //Baud rate divisior register 0
- //UART1
- rULCON1 = 0x3;
- rUCON1 = 0x245;
- rUBRDIV1=( (int)(pclk/16./baud+0.5) -1 );
- //UART2
- rULCON2 = 0x3;
- rUCON2 = 0x245;
- rUBRDIV2=( (int)(pclk/16./baud+0.5) -1 );
- for(i=0;i<100;i++);
- void Uart_Select(int ch)
- whichUart = ch;
- void Uart_TxEmpty(int ch)
- if(ch==0)
- while(!(rUTRSTAT0 & 0x4)); //Wait until tx shifter is empty.
- else if(ch==1)
- while(!(rUTRSTAT1 & 0x4)); //Wait until tx shifter is empty.
- else if(ch==2)
- while(!(rUTRSTAT2 & 0x4)); //Wait until tx shifter is empty.
- char Uart_Getch(void)
- if(whichUart==0)
- while(!(rUTRSTAT0 & 0x1)); //Receive data ready
- return RdURXH0();
- else if(whichUart==1)
- while(!(rUTRSTAT1 & 0x1)); //Receive data ready
- return RdURXH1();
- else if(whichUart==2)
- while(!(rUTRSTAT2 & 0x1)); //Receive data ready
- return RdURXH2();
- return 0 ;
- char Uart_GetKey(void)
- if(whichUart==0)
- if(rUTRSTAT0 & 0x1) //Receive data ready
- return RdURXH0();
- else
- return 0;
- if(rUTRSTAT1 & 0x1) //Receive data ready
- return RdURXH1();
- else
- return 0;
- if(rUTRSTAT2 & 0x1) //Receive data ready
- return RdURXH2();
- else
- return 0;
- return 0 ;
- void Uart_GetString(char *string)
- char *string2 = string;
- char c;
- while((c = Uart_Getch())!='\r')
- if(c=='\b')
- if( (int)string2 < (int)string )
- Uart_Printf("\b \b");
- string--;
- else
- *string++ = c;
- Uart_SendByte(c);
- *string='\0';
- Uart_SendByte('\n');
- int Uart_GetIntNum(void)
- char str[30];
- char *string = str;
- int base = 10;
- int minus = 0;
- int result = 0;
- int lastIndex;
- int i;
- Uart_GetString(string);
- if(string[0]=='-')
- minus = 1;
- string++;
- if(string[0]=='0' && (string[1]=='x' || string[1]=='X'))
- base = 16;
- string += 2;
- lastIndex = strlen(string) - 1;
- if(lastIndex<0)
- return -1;
- if(string[lastIndex]=='h' || string[lastIndex]=='H' )
- base = 16;
- string[lastIndex] = 0;
- lastIndex--;
- if(base==10)
- result = atoi(string);
- result = minus ? (-1*result):result;
- else
- for(i=0;i<=lastIndex;i++)
- if(isalpha(string[i]))
- if(isupper(string[i]))
- result = (result<<4) + string[i] - 'A' + 10;
- else
- result = (result<<4) + string[i] - 'a' + 10;
- else
- result = (result<<4) + string[i] - '0';
- return result;
- //get a number for the uart
- int Uart_GetIntNum_GJ(void)
- char string[16] ;
- char *p_string = string ;
- char c;
- int i = 0 ;
- int data = 0 ;
- while( ( c = Uart_Getch()) != '\r' )
- if(c=='\b') p_string--;
- else *p_string++=c;
- Uart_SendByte( c ) ;
- *p_string = '\0';
- i = 0 ;
- while( string[i] != '\0' )
- data = data * 10 ;
- if( string[i]<'0'||string[i]>'9' )
- return -1 ;
- data = data + ( string[i]-'0' ) ;
- i++ ;
- return data ;
- void Uart_SendByte(int data)
- if(whichUart==0)
- if(data=='\n')
- while(!(rUTRSTAT0 & 0x2));
- // Delay(1); //because the slow response of hyper_terminal
- WrUTXH0('\r');
- while(!(rUTRSTAT0 & 0x2)); //Wait until THR is empty.
- // Delay(1);
- WrUTXH0(data);
- if(data=='\n')
- while(!(rUTRSTAT1 & 0x2));
- //Delay(1); //because the slow response of hyper_terminal
- rUTXH1 = '\r';
- while(!(rUTRSTAT1 & 0x2)); //Wait until THR is empty.
- //Delay(1);
- rUTXH1 = data;
- if(data=='\n')
- while(!(rUTRSTAT2 & 0x2));
- rUTXH2 = '\r';
- while(!(rUTRSTAT2 & 0x2)); //Wait until THR is empty.
- //Delay(1);
- rUTXH2 = data;
- void Uart_SendString(char *pt)
- while(*pt)
- Uart_SendByte(*pt++);
- //If you don't use vsprintf(), the code size is reduced very much.
- void Uart_Printf(char *fmt,...)
- va_list ap;
- char string[256];
- va_start(ap,fmt);
- vsprintf(string,fmt,ap);
- Uart_SendString(string);
- va_end(ap);
- //**************************[ BOARD LED ]*********************************
- void Led_Display(int data)
- //Active is low.(LED On)
- // GPF7 GPF6 GPF5 GPF4
- //nLED_8 nLED4 nLED_2 nLED_1
- // rGPFDAT = (rGPFDAT & 0xf) | !((data & 0xf)<<4);
- // rGPFDAT = (rGPFDAT & ~(0xf<<4)) | ((~data & 0xf)<<4);
- rGPBDAT = (rGPBDAT & ~(0xf<<5)) | ((~data & 0xf)<<5);
- //rGPCDAT = (rGPBDAT & ~(0xf<<5)) | ((~data & 0xf0)<<5);
- //***************************[ BOARD BEEP ]*******************************
- void Beep(U32 freq, U32 ms)
- rGPBCON &= ~3; //set GPB0 as tout0, pwm output
- rGPBCON |= 2;
- rTCFG0 &= ~0xff;
- rTCFG0 |= 15; //prescaler = 15+1
- rTCFG1 &= ~0xf;
- rTCFG1 |= 2; //mux = 1/8
- rTCNTB0 = (PCLK>>7)/freq;
- rTCMPB0 = rTCNTB0>>1; // 50%
- rTCON &= ~0x1f;
- rTCON |= 0xb; //disable deadzone, auto-reload, inv-off, update TCNTB0&TCMPB0, start timer 0
- rTCON &= ~2; //clear manual update bit
- Delay(ms);
- rGPBCON &= ~3; //set GPB0 as output
- rGPBCON |= 1;
- rGPBDAT &= ~1;
- void Buzzer_Freq_Set( U32 freq )
- rGPBCON |= 2;
- rTCFG0 &= ~0xff;
- rTCFG1 &= ~0xf;
- rTCON &= ~0x1f;
- void Buzzer_Stop( void )
- rGPBCON |= 1;
- rGPBDAT &= ~1;
- Buzzer_Freq_Set( freq ) ;
- Delay( ms ) ;
- Buzzer_Stop() ;
- 【功能说明】蜂鸣器PWM测试
- void BUZZER_PWM_Test( void )
- U16 freq = 1000 ;
- Uart_Printf( "\nBUZZER TEST ( PWM Control )\n" );
- Uart_Printf( "Press +/- to increase/reduce the frequency of BUZZER !\n" ) ;
- Uart_Printf( "Press 'ESC' key to Exit this program !\n\n" );
- while( 1 )
- U8 key = Uart_Getch();
- if( key == '+' )
- if( freq < 20000 )
- freq += 10 ;
- if( key == '-' )
- if( freq > 11 )
- freq -= 10 ;
- Uart_Printf( "\tFreq = %d\n", freq ) ;
- if( key == ESC_KEY )
- Buzzer_Stop() ;
- return ;
- //********************** BOARD LCD backlight ]****************************
- void LcdBkLtSet(U32 HiRatio)
- #define FREQ_PWM1 1000
- if(!HiRatio)
- rGPBCON = rGPBCON & (~(3<<2)) | (1<<2) ; //GPB1设置为output
- rGPBDAT &= ~(1<<1);
- return;
- rGPBCON = rGPBCON & (~(3<<2)) | (2<<2) ; //GPB1设置为TOUT1
- if( HiRatio > 100 )
- HiRatio = 100 ;
- rTCON = rTCON & (~(0xf<<8)) ; // clear manual update bit, stop Timer1
- rTCFG0 &= 0xffffff00; // set Timer 0&1 prescaler 0
- rTCFG1 &= 0xffffff0f; // set Timer 1 MUX 1/16
- rTCFG1 |= 0x00000030; // set Timer 1 MUX 1/16
- rTCNTB1 = ( 100000000>>8 )/FREQ_PWM1; //if set inverter off, when TCNT2<=TCMP2, TOUT is high, TCNT2>TCMP2, TOUT is low
- rTCMPB1 = ( rTCNTB1*(100-HiRatio))/100 ; //if set inverter on, when TCNT2<=TCMP2, TOUT is low, TCNT2>TCMP2, TOUT is high
- rTCON = rTCON & (~(0xf<<8)) | (0x0e<<8) ;
- //自动重装,输出取反关闭,更新TCNTBn、TCMPBn,死区控制器关闭
- rTCON = rTCON & (~(0xf<<8)) | (0x0d<<8) ; //开启背光控制
- 【功能说明】LCD背光亮度控制,PWM控制占空比
- void LCD_BackLight_Control( void )
- U8 HiRatio = 50 ;
- Uart_Printf( "\nNOTE : ONLY SOME type LCD kit SUPPORT backlight adjust!!!\n" ) ;
- Uart_Printf( "Press +/- to increase/reduce the light of LCD !\n" ) ;
- Uart_Printf( "Press 'ESC' to Exit this test program !\n\n" );
- LcdBkLtSet( HiRatio ) ;
- while( 1 )
- if( key == '+' )
- if( HiRatio < 100 )
- HiRatio += 1 ;
- if( key == '-' )
- if( HiRatio > 1 )
- HiRatio -= 1 ;
- if( key == ESC_KEY ) break ;
- Uart_Printf( "LCD backlight HiRatio %d\n", HiRatio ) ;
- //*************************[ Timer ]********************************
- void Timer_Start(int divider) //0:16us,1:32us 2:64us 3:128us
- rWTCON = ((PCLK/1000000-1)<<8)|(divider<<3); //Watch-dog timer control register
- rWTDAT = 0xffff; //Watch-dog timer data register
- rWTCNT = 0xffff; //Watch-dog count register
- // Watch-dog timer enable & interrupt disable
- rWTCON = (rWTCON & ~(1<<5) & ~(1<<2)) |(1<<5);
- int Timer_Stop(void)
- rWTCON = ((PCLK/1000000-1)<<8);
- return (0xffff - rWTCNT);
- //*************************[ MPLL ]*******************************
- void ChangeMPllValue(int mdiv,int pdiv,int sdiv)
- rMPLLCON = (mdiv<<12) | (pdiv<<4) | sdiv;
- //************************[ HCLK, PCLK ]***************************
- // for 2410.
- void ChangeClockDivider(int hdivn,int pdivn)
- // hdivn,pdivn FCLK:HCLK:PCLK
- // 0,0 1:1:1
- // 0,1 1:1:2
- // 1,0 1:2:2
- // 1,1 1:2:4
- rCLKDIVN = (hdivn<<1) | pdivn;
- if(hdivn)
- MMU_SetAsyncBusMode();
- else
- MMU_SetFastBusMode();
- // Modified for 2440.
- void ChangeClockDivider(int hdivn_val,int pdivn_val)
- int hdivn=2, pdivn=0;
- // hdivn_val (FCLK:HCLK)ratio hdivn
- // 11 1:1 (0)
- // 12 1:2 (1)
- // 13 1:3 (3)
- // 14 1:4 (2)
- // pdivn_val (HCLK:PCLK)ratio pdivn
- // 11 1:1 (0)
- // 12 1:2 (1)
- switch(hdivn_val) {
- case 11: hdivn=0; break;
- case 12: hdivn=1; break;
- case 13:
- case 16: hdivn=3; break;
- case 14:
- case 18: hdivn=2; break;
- switch(pdivn_val) {
- case 11: pdivn=0; break;
- case 12: pdivn=1; break;
- //Uart_Printf("Clock division change [hdiv:%x, pdiv:%x]\n", hdivn, pdivn);
- case 16: // when 1, HCLK=FCLK/8.
- rCAMDIVN = (rCAMDIVN & ~(3<<8)) | (1<<8);
- break;
- case 18: // when 1, HCLK=FCLK/6.
- rCAMDIVN = (rCAMDIVN & ~(3<<8)) | (1<<9);
- break;
- if(hdivn!=0)
- else
- //**************************[ UPLL ]*******************************
- void ChangeUPllValue(int mdiv,int pdiv,int sdiv)
- rUPLLCON = (mdiv<<12) | (pdiv<<4) | sdiv;
- //*************************[ General Library ]**********************
- void * malloc(unsigned nbyte)
- //Very simple; Use malloc() & free() like Stack
- //void *mallocPt=Image$RW$Limit;
- void *returnPt = mallocPt;
- mallocPt = (int *)mallocPt+nbyte/4+((nbyte%4)>0); //To align 4byte
- if( (int)mallocPt > HEAPEND )
- mallocPt = returnPt;
- return NULL;
- return returnPt;
- void free(void *pt)
- mallocPt = pt;
