专注电子技术学习与研究
51单片机制作的波形发生器
作者:佚名   来源:本站原创   点击数:…  更新时间:2012年01月02日   【字体:大 中 小】
     相信很多朋友都可能接触到一个波型发生器的制作,可能刚刚入门,做的东西也不会说是很复杂。可能就一个矩形波,或者是三角波。但是网上的很多资料是忽悠人的,就此,我也提供一个比较完整的波型发生器 C51 原代:
       该系统的软件比较典型:包括键盘的应用,显示的应用和 DA 转换器的应用。本设计中,输出的波形有三种:正弦波,方波,三角波。
       方波的输出最为简单,只要按照设定的周期值将输出的电压改变即可。
       三角波的输出也比较简单,单片机的输出只要完成数字量递增和递减交替进行即可。、
      正弦波的输出最麻烦,如果在软件中计算出输出的各点电压值,将会浪费很多的 CPU 时间,以至于无法满足频率的要求。通常最简单的方法是通过手动的方法计算出输出各点的电压值,然后在编写程序时以数组的方式给出。当需要时,只要按照顺序进行输出即可。这种方法比运算法速度快且曲线的形状修改灵活。在本设计中将 360 度分为 256 个点,则每两个点之间的间隔为 1.4 度,然后计算出每个点电压对应的数字量即可。只要反复输出这组数据到 DAC0832, 就可以在系统输出端得到想要的正弦波。
具体程序如下:
#include <reg52.h>
#define DAdata P0
uchar code Sinetab[256]=
0x80,0x82,0x84,0x86,0x88,0x8a,0x8c,0x8e,
0x90,0x92,0x94,0x96,0x98,0x9a,0x9c,0x9e,
0xa0,0xa2,0xa4,0xa6,0xa8,0xaa,0xab,0xad,
0xaf,0xb1,0xb2,0xb4,0xb6,0xb7,0xb9,0xba,
0xbc,0xbd,0xbf,0xc0,0xc1,0xc3,0xc4,0xc5,
0xc6,0xc8,0xc9,0xca,0xcb,0xcc,0xcd,0xce,
0xce,0xcf,0xd0,0xd1,0xd1,0xd2,0xd2,0xd3,
0xd3,0xd3,0xd2,0xd2,0xd1,0xd1,0xd0,0xcf,
0xce,0xce,0xcd,0xcc,0xcb,0xca,0xc9,0xc8,
0xc6,0xc5,0xc4,0xc3,0xc1,0xc0,0xbf,0xbd,
0xbc,0xba,0xb9,0xb7,0xb6,0xb4,0xb2,0xb1,
0xaf,0xad,0xab,0xaa,0xa8,0xa6,0xa4,0xa2,
0xa0,0x9e,0x9c,0x9a,0x98,0x96,0x94,0x92,
0x90,0x8e,0x8c,0x8a,0x88,0x86,0x84,0x82,
0x80,0x7d,0x7b,0x79,0x77,0x75,0x73,0x71,
0x6f,0x6d,0x6b,0x69,0x67,0x65,0x63,0x61,
0x5f,0x5d,0x5b,0x59,0x57,0x55,0x54,0x52,
0x50,0x4e,0x4d,0x4b,0x49,0x48,0x46,0x45,
0x43,0x42,0x40,0x3f,0x3e,0x3c,0x3b,0x3a,
0x39,0x37,0x36,0x35,0x34,0x33,0x32,0x31,
0x31,0x30,0x2f,0x2e,0x2e,0x2d,0x2d,0x2c,
0x2c,0x2b,0x2b,0x2b,0x2b,0x2a,0x2a,0x2a,
0x2a,0x2a,0x2a,0x2a,0x2b,0x2b,0x2b,0x2b,
0x2c,0x2c,0x2d,0x2d,0x2e,0x2e,0x2f,0x30,
0x31,0x31,0x32,0x33,0x34,0x35,0x36,0x37,
0x39,0x3a,0x3b,0x3c,0x3e,0x3f,0x40,0x42,
0x43,0x45,0x46,0x48,0x49,0x4b,0x4d,0x4e,
0x50,0x52,0x54,0x55,0x57,0x59,0x5b,0x5d,
0x5f,0x61,0x63,0x65,0x67,0x69,0x6b,0x6d,
0x6f,0x71,0x73,0x75,0x77,0x79,0x7b,0x7d,
uchar code Triangletab[58]=
0x1a,0x21,0x28,0x2f,0x36,0x3d,0x44,0x4b,
0x52,0x59,0x60,0x67,0x6e,0x75,0x7c,0x83,
0x8a,0x91,0x98,0x9f,0xa6,0xad,0xb4,0xbb,
0xc2,0xc9,0xd0,0xd7,0xde,0xe5,
0xde,0xd7,0xd0,0xc9,0xc2,0xbb,0xb4,0xad,
0xa6,0x9f,0x98,0x91,0x8a,0x83,0x7c,0x75,
0x6e,0x67,0x60,0x59,0x52,0x4b,0x44,0x3d,
0x36,0x2f,0x28,0x21,
uchar code Squaretab[2]={0x56,0xaa};
uchar code disp1[]=
"Sine Wave       "
"Triangle Wale   "
"Square Wave     "
uchar idata disp2[16]={"Frequency:    Hz"};
uchar code Coef[3]={10,100,200};
uchar idata WaveFre[3]={1,1,1};
uchar code WaveTH[]=
0xfc,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
uchar code WaveTL[]=
0xf2,0x78,0xfb,0x3c,0x63,0x7d,0x8f,0x9d,0xa8,0xb1,
0x17,0x0b,0xb2,0x05,0x37,0x58,0x70,0x82,0x90,0x9b,
0x4d,0xa7,0xc4,0xd3,0xdc,0xe2,0xe6,0xea,0xec,0xee
uchar Wavecount,THtemp,TLtemp;
uchar Waveform;
sbit rs=P2^5;
sbit rw=P2^6;
sbit e=P2^7;
sbit DA=P2^0;
sbit KEY=P3^2;
void delay(uchar i)
uchar j;
for(;i>0;i--)
   for(j=20;j>0;j--);
void busy()
uchar temp;
temp=0x00;
rs=0;
rw=1;
while((temp&0x80)==0x80)
    P0=0xff;
    e=1;
    temp=P0;
    e=0;
void WR_Com(uchar temp)
busy();
rs=0;
rw=0;
P0=temp;
e=1;
e=0;
void WR_Data(uchar num)
busy();
rs=1;
rw=0;
P0=num;
e=1;
e=0;
void disp_lcd(uchar addr,uchar *temp1)
uchar i;
WR_Com(addr);
delay(100);
for(i=0;i<16;i++)
    WR_Data(temp1[i]);
    delay(100);
void lcd_ini()
char i;
for(i=3;i>0;i--)
    P0=0x30;
    rs=0;
    rw=0;
    e=1;
    e=0;
    delay(100);
P0=0x38;
rs=0;
rw=0;
e=1;
e=0;
delay(100);
void lcd_Reset()
WR_Com(0x01);
delay(100);
WR_Com(0x06);
delay(100);
WR_Com(0x0c);
delay(100);
void SineOUT(uchar Wavecount)
DAdata=Sinetab[Wavecount++];
Wavecount=0;
DA=0;
DA=1;
void TriangleOUT(uchar Wavecount)
DAdata=Triangletab[Wavecount++];
if(Wavecount>57)
   Wavecount=0;
DA=0;
DA=1;
void SquareOUT(uchar Wavecount)
DAdata=Squaretab[Wavecount++];
if(Wavecount>1)
Wavecount=0;
DA=0;
DA=1;
void timer() interrupt 1
TH0=THtemp;
TL0=THtemp;
if(Waveform==0)
   SineOUT(Wavecount);
else if(Waveform==1)
   TriangleOUT(Wavecount);
else if(Waveform==2)
   SquareOUT(Wavecount);
void key_int() interrupt 0
uchar keytemp,keytemp1;
uint WaveCoef;
EA=0;
TR0=0;
keytemp1=0;
delay(10);
while(!KEY);
keytemp=~P2&0x1e;
keytemp>>=1;
while(keytemp!=8)
    keytemp=~P2&0x1e;
    keytemp>>=1;
    if(keytemp!=keytemp1)
      keytemp1=keytemp;
      switch(keytemp)
        case 1:
         if(++Waveform==3)
          Waveform=0;
         break;
        case 2:
         if(++WaveFre[Waveform]==11)
          WaveFre[Waveform]=1;
         break;
        case 4:
         if(--WaveFre[Waveform]==0)
          WaveFre[Waveform]=10;
         break;
    THtemp=WaveTH[Waveform*16+(WaveFre[Waveform]-1)];
    TLtemp=WaveTL[Waveform*16+(WaveFre[Waveform]-1)];
    WaveCoef=WaveFre[Waveform]*Coef[Waveform];
    disp2[13]=WaveCoef%10+0x30;
    WaveCoef/=10;
    disp2[12]=WaveCoef%10+0x30;
    WaveCoef/=10;
    disp2[11]=WaveCoef%10+0x30;
    WaveCoef/=10;
    disp2[10]=WaveCoef%10+0x30;
    WaveCoef/=10;
    disp_lcd(0x80,&disp1[Waveform*16]);
    disp_lcd(0xc0,disp2);
   TH0=THtemp;
   TL0=THtemp;
   Wavecount=0;
   TR0=1;
uint WaveCoef;
uchar i;
lcd_ini();
lcd_Reset();
WaveCoef/=10;
WaveCoef/=10;
WaveCoef/=10;
WaveCoef/=10;
i=0;
DAdata=0x00;
DA=0;
TMOD=0x01;
IT0=1;
ET0=1;
EX0=1;
EA=1;
while(1);
【关闭窗口】
相关文章
