专注电子技术学习与研究
单片机IO口模拟rs232串口通讯C51程序
作者:佚名   来源:本站原创   点击数:…  更新时间:2013年06月02日   【字体:大 中 小】
此程序已经应用在本人的一个项目中非常稳定,编写过程中参考了51hei网站里面的 http://www.51hei.com/mcu/1541.html  这篇文章.部分子程序节选于此.
#include "reg52.h"
#include "intrins.h"
#include "math.h"
#include "stdio.h"
sbit BT_SND =P1^5;
sbit BT_REC =P1^6;
sbit LED =P1^7;
bit  LED_flage=1;
//单片机IO 口模拟232串口通讯程序
//使用两种方式的C程序 占用定时器0
#define MODE_QUICK
#define F_TM F0
#define TIMER0_ENABLE  TL0=TH0; TR0=1;
#define TIMER0_DISABLE TR0=0;
sbit ACC0=   ACC^0;
sbit ACC1=   ACC^1;
sbit ACC2=   ACC^2;
sbit ACC3=   ACC^3;
sbit ACC4=   ACC^4;
sbit ACC5=   ACC^5;
sbit ACC6=   ACC^6;
sbit ACC7=   ACC^7;
void IntTimer0() interrupt 1
  F_TM=1;
//发送一个字符
void PSendChar(unsigned char inch)
 #ifdef MODE_QUICK
    ACC=inch;
    F_TM=0;
    BT_SND=0; //start bit
    TIMER0_ENABLE; //启动
    while(!F_TM);
    BT_SND=ACC0; //先送出低位
    F_TM=0;
    while(!F_TM);
    BT_SND=ACC1;
    F_TM=0;
    while(!F_TM);
    BT_SND=ACC2;
    F_TM=0;
    while(!F_TM);
    BT_SND=ACC3;
    F_TM=0;
    while(!F_TM);
    BT_SND=ACC4;
    F_TM=0;
    while(!F_TM);
    BT_SND=ACC5;
    F_TM=0;
    while(!F_TM);
    BT_SND=ACC6;
    F_TM=0;
    while(!F_TM);
    BT_SND=ACC7;
    F_TM=0;
    while(!F_TM);
    BT_SND=1;
    F_TM=0;
    while(!F_TM);
    TIMER0_DISABLE; //停止timer
    #else
    unsigned char ii;
     ii=0;
     F_TM=0;
     TIMER0_ENABLE; //启动
     while(!F_TM);
     while(ii<8)
   if(inch&1)
   BT_SND=1;
   BT_SND=0;
   F_TM=0;
 while(!F_TM);
   ii++;
  inch>>=1;
  BT_SND=1;
  F_TM=0;
  while(!F_TM);
    #endif
//接收一个字符
unsigned char PGetChar()
 #ifdef MODE_QUICK
 TIMER0_ENABLE;
 F_TM=0;
 while(!F_TM); //等过起始位
 ACC0=BT_REC;
 TL0=TH0;
 F_TM=0;
 while(!F_TM);
 ACC1=BT_REC;
 F_TM=0;
 while(!F_TM);
 ACC2=BT_REC;
 F_TM=0;
 while(!F_TM);
 ACC3=BT_REC;
 F_TM=0;
 while(!F_TM);
 ACC4=BT_REC;
 F_TM=0;
 while(!F_TM);
 ACC5=BT_REC;
 F_TM=0;
 while(!F_TM);
 ACC6=BT_REC;
 F_TM=0;
 while(!F_TM);
 ACC7=BT_REC;
 F_TM=0;
 while(!F_TM)
  if(BT_REC)
    break;
 return ACC;
 #else
 unsigned char rch,ii;
 TIMER0_ENABLE;
 F_TM=0;
 ii=0;
 rch=0;
 while(ii<8)
     rch>>=1;
  if(BT_REC)
  rch|=0x80;
  ii++;
  F_TM=0;
  while(!F_TM);
 F_TM=0;
  while(!F_TM)
  if(BT_REC)
     break;
 return rch;
 #endif
//检查是不是有起始位
bit StartBitOn()
  return (BT_REC==0);
//定时器1初始化
void Time1_Init(void)
   TMOD=0x22; //定时器1为工作模式2(8位自动重装),0为模式2(8位自动重装)
   PCON=00;
   TR0=0; //在发送或接收才开始使用
   TF0=0;
   TH0=(256-96); //9600bps 就是 1000000/9600=104.167微秒 执行的timer//104.167*11.0592/12= 96
   TL0=TH0;
   ET0=1;
   EA=1;
//发送字符串
void Send_Char(char *byte)
   int i=0;
   for(i=0;*(byte+i)!='\0';i++)
      PSendChar(*(byte+i));
//void delay(int x)
// int a,b;
// for(a=x;a>0;a--)
//  for(b=10;b>0;b--);
//void main()
//   unsigned char gch;
//   Time1_Init();
//   LED=0;
//  // Send_Char("S00.0C00.0%E00.0C00.0%L00000lx");
//   while(1)
//   PSendChar('1');
//   delay(1000);
////      if(StartBitOn())
////     gch=PGetChar();
////     if(gch=='1')
////    LED=LED_flage;
////    delay(1000);
////    LED_flage=~LED_flage;
【关闭窗口】
相关文章
