专注电子技术学习与研究
RT12864M液晶模块单片机驱动程序
作者:佚名   来源:本站原创   点击数:…  更新时间:2013年06月23日   【字体:大 中 小】
                 /*-----------RT12864M模块-----------*/
                 /*------外部晶振为     12MHz-------*/
     /*--------最后修改2011.02.26-------*/
#include "STC12C5620AD.h"
#include "RT12864M.h"
#include "delay.h"
/**********************自定义字符编码*************************/
unsigned char code CGROM_Code[]={0x00,0x00,0x00,0x00,0x7F,0xFE,0x60,0x06,0x33,0xCC,0x19,0x98,0x0C,0x30,0x06,0x60,
           0x03,0xC0,0x01,0x80,0x01,0x80,0x01,0x80,0x01,0x80,0x01,0x80,0x01,0x80,0x01,0x80,   //天线图形
          0x00,0x00,0xE0,0x00,0xA0,0x00,0xEE,0x00,0x1B,0x00,0x31,0x00,0x30,0x00,0x30,0x00,
         0x30,0x00,0x30,0x00,0x31,0x00,0x1B,0x00,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00};    //摄氏图形
/**********************LCD检测是否忙*************************/
bit LCD_Test_Busy(void)
   bit Temp;
   LCD_DATAPORT=0xff;                  //数据口先全部置位
   LCD_RS=0;
   LCD_RW=1;
   LCD_E=1;
   Temp=(bit)(LCD_DATAPORT & 0x80);    //取最高位,1为忙
   LCD_E=0;
   return Temp;
/*************************LCD写命令**************************/
void LCD_Write_CMD(uchar cmd)
 while(LCD_Test_Busy());           //先检测LCD是否忙
 LCD_RS=0;
 LCD_RW=0;
 LCD_E=1;
    LCD_DATAPORT=cmd;            //写入命令
 LCD_E=0;
/*************************LCD写数据**************************/
void LCD_Write_DATA(uchar Inputdata)
 LCD_RS=1;
 LCD_RW=0;
 LCD_E=1;
    LCD_DATAPORT=Inputdata;      //写入数据
 LCD_E=0;
/************ 写入自定义字符或图形到 CGRAM  *****************/
void LCD_Write_CGRAM(uchar *Char_Code)
 uchar  i;
 LCD_Write_CMD(0x34);    //打开扩充指令
 LCD_Write_CMD(0x02);    //SR=0,允许输入CGRAM地址
 LCD_Write_CMD(0x30);    //恢复基本指令
 LCD_Write_CMD(0x40);    //CGRAM地址
 for(i=0;i<32;i++)
   LCD_Write_DATA(Char_Code[i*2]);
   LCD_Write_DATA(Char_Code[i*2+1]);
/**********************设置操作地址**************************/
void LCD_Set_XY(uchar x,uchar y)
 uchar Address;
 switch(x)
 case 0:
     Address = 0x80 + y;
     break;
    case 1:
     Address = 0x90 + y;
  break;
 case 2:
  Address = 0x88 + y;
  break;
    case 3:
  Address = 0x98 + y;
  break;
 default:
  Address = 0x80 + y;
    LCD_Write_CMD(Address);
/*************************显示一个CGRAM**************************/
/**************参数:行号,列号,要显示的CGRAM*****************/
void LCD_Display_CGRAM(uchar x,uchar y,uchar add1,uchar add2)
    LCD_Set_XY(x,y);            //先确定显示行和列
 LCD_Write_DATA(add1);
 LCD_Write_DATA(add2);
/**************在X(行)Y(列)显示字符串********************/
void LCD_Display_String( uchar x,uchar y,uchar *str )
    LCD_Set_XY(x,y);         //先确定起始行和列
 while (*str!='\0')
        LCD_Write_DATA(*str);
     str++;
/**************在X(行)Y(列)显示数值********************/
void LCD_Display_Value( uchar x,uchar y,uchar val )
 LCD_Write_DATA(val);
/**************在X(行)Y(列)显示数组********************/
void LCD_Display_Array( uchar x,uchar y,uchar *Array,uchar Lenth )
 while(Lenth--)
   LCD_Write_DATA(*Array);
   Array++;
/*************************LCD初始化**************************/
void LCD_Init(void)
 LCD_RST=0;
 Delay_us(10);
 LCD_RST=1;          //LCD复位
    LCD_Write_CMD(0x30);          //功能设定(并行、基本指令)
    LCD_Write_CMD(0x0c);          //整体显示,光标
    LCD_Write_CMD(0x01);          //清屏
 LCD_Write_CMD(0x06);       //光标右移,整体不右移
 LCD_Write_CGRAM(CGROM_Code);   //写入自定义字符
这是一个完整项目里面截取出来的子程序 头文件和原理图请到http://www.51hei.com/bbs/dpj-19294-1.html 去下载.
【关闭窗口】
相关文章
