专注电子技术学习与研究
基于stc单片机的AT89S52离线烧录器程序
作者:佚名   来源:本站原创   点击数:…  更新时间:2013年08月16日   【字体:大 中 小】
下面是部分源码预览,完整的代码请到http://www.51hei.com/bbs/dpj-20605-1.html下载
#include "uart.h"
#include "s51pro.h"
#include "myfun.h"
#include "znfat/znFAT.h"
extern unsigned char OutBuf[4];
extern unsigned char InBuf[4];
unsigned char idata psignbuf[3];
unsigned char code_buf[32];
sfr P1M0 = 0x92;
sfr P1M1 = 0x91; //定义STC12单片机IO模式特殊功能寄存器
struct znFAT_Init_Args idata Init_Args; //初始化参数集合
struct FileInfo idata fileinfo; //文件信息集合
 unsigned int idata addr=0,i=0;
 unsigned int idata res=0,n_file=0,len=0;
 P1M1=0x40; //P16高阻输入
 P1M0=0xa0; //如果使用51单片机来调试SD卡模块,打开推挽,增强IO驱动能力
 UART_Init();
 UART_Send_Str("串口设置完毕\r\n");
 znFAT_Device_Init(); //存储设备初始化
 UART_Send_Str("SD卡初始化完毕\r\n");
 znFAT_Select_Device(0,&Init_Args); //选择设备
 res=znFAT_Init(); //文件系统初始化
 if(!res) //文件系统初始化成功
  UART_Send_Str("Suc. to init FS\r\n");
  UART_Put_Inf("BPB_Sector_No:",Init_Args.BPB_Sector_No);
  UART_Put_Inf("Total_SizeKB:",Init_Args.Total_SizeKB);
  UART_Put_Inf("BytesPerSector:",Init_Args.BytesPerSector);
  UART_Put_Inf("FATsectors:",Init_Args.FATsectors);
  UART_Put_Inf("SectorsPerClust:",Init_Args.SectorsPerClust);
  UART_Put_Inf("FirstFATSector:",Init_Args.FirstFATSector);
  UART_Put_Inf("FirstDirSector:",Init_Args.FirstDirSector);
  UART_Put_Inf("FSsec:",Init_Args.FSINFO_Sec);
  UART_Put_Inf("Next_Free_Cluster:",Init_Args.Next_Free_Cluster);
  UART_Put_Inf("FreenCluster:",Init_Args.Free_nCluster);
 else //文件系统初始化失败
 UART_Put_Inf("Fail to init FS , Err Code:",res);
 res=znFAT_Open_File(&fileinfo,"/*.bin",n_file,1); //打开文件
 while(!res)
  UART_Put_Inf("Suc. to open file ",n_file);
  UART_Send_Str("================================\n");
  UART_Send_Str("File_Name(Short 8.3):");
  UART_Send_Str(fileinfo.File_Name);UART_Send_Enter();
  if(fileinfo.have_lfn) //如果有长名,则输出长名
   UART_Send_Str("File_Name(Long Name):");
   //中文输出其UNICODE编码码值
  i=0;
  while(fileinfo.longname[i])
  if(fileinfo.longname[i]<0x80)
   UART_Send_Byte((unsigned char)fileinfo.longname[i++]);
   UART_Put_Hex(fileinfo.longname[i++]);
   UART_Send_Byte(' ');
   UART_Send_Enter();
   UART_Send_Str("This file have not Long Name.\r\n");;
  UART_Put_Inf("File_Size:",fileinfo.File_Size);
  UART_Send_Str("File_CDate:");
  UART_Put_Num(fileinfo.File_CDate.year); UART_Send_Str("年");
  UART_Put_Num(fileinfo.File_CDate.month);UART_Send_Str("月");
  UART_Put_Num(fileinfo.File_CDate.day);  UART_Send_Str("日");
  UART_Put_Num(fileinfo.File_CTime.hour); UART_Send_Str("时");
  UART_Put_Num(fileinfo.File_CTime.min);  UART_Send_Str("分");
  UART_Put_Num(fileinfo.File_CTime.sec);  UART_Send_Str("秒\r\n");
  UART_Put_Inf("File_StartClust:",fileinfo.File_StartClust);
  UART_Put_Inf("File_CurClust:",fileinfo.File_CurClust);
  UART_Put_Inf("File_CurSec:",fileinfo.File_CurSec);
  UART_Put_Inf("File_CurPos:",fileinfo.File_CurPos);
  UART_Put_Inf("File_CurOffset:",fileinfo.File_CurOffset);
  Pro_Enable();
  UART_Send_Str("Program enable....\n");
  Pro_ReadSign(psignbuf);
  UART_Send_Str("Sign[0]:");
  binary(psignbuf[0]);UART_Send_Enter();
  UART_Send_Str("Sign[1]:");
  binary(psignbuf[1]);UART_Send_Enter();
  UART_Send_Str("Sign[2]:");
  binary(psignbuf[2]);UART_Send_Enter();
  Pro_Erase();
  UART_Send_Str("Program erase....\n");
 UART_Send_Str("Start programming....\n");
 addr=0;
 while(len=znFAT_ReadData(&fileinfo,fileinfo.File_CurOffset,32,code_buf))
  for(i=0;i<len;i++)
  while(!Write(code_buf[i],addr));
  addr++;
  UART_Send_Byte('.');
  UART_Send_Enter();
  Pro_Over();
  UART_Send_Str("Program over....\n");
 UART_Send_Str("Start to Play this Code....\n");
 RST=1;
 delay(1000);
 RST=0;
 for(i=0;i<100;i++)
  delay(60000);
 RST=1;
 UART_Send_Str("Complete playing this Code\n");
  znFAT_Close_File(&fileinfo);
 n_file++;
 if(res==ERR_NO_FILE) //出现无匹配文件错误
 UART_Put_Inf("Number of code file is ",n_file);
 UART_Put_Inf("Have some Err:",res);
 znFAT_Flush_FS(); //刷新文件系统
 while(1);
【关闭窗口】
相关文章
