专注电子技术学习与研究
“屏幕式”声光电子琴程序
作者:佚名   来源:本站原创   点击数:…  更新时间:2013年11月04日   【字体:大 中 小】
/*编写人:伍浩荣
8个按键发出8个基本音,
能播放内置音乐,音乐跟随灯光闪烁
版权所有,翻版必究
sfr P4=0xe8;//定义P4组I0口
#include<reg52.h>
sbit speaker=P1^4;//喇叭接30脚
sbit key1=P4^4;//流水灯按键(暂时)
sbit key2=P4^6;//播放音乐按键(暂定)
uchar a,b,num1,s1num,n1,n2;
char num;//定义num为可以负数
uchar code yinfu[]={0xfb,0xe9,      //Do
                   0xfc,0x5c,      //Re
                   0xfc,0xc1,      //Mi
                   0xfc,0xef,      //Fa
                   0xfd,0x45,      //So
                   0xfd,0x92,      //La
                   0xfd,0xd0,      //Si
                   0xfd,0xee,      //Do#
  0x00,0x00,   //间隔
uchar code shengri_tone[]={   1,0,1,2,1,4,3,0, //生日快乐音调
                                   1,0,1,2,1,5,4,0,
                                   1,0,1,8,6,4,3,2,0,
                                   7,0,7,6,4,5,4,0       //0代表不发声,即停顿;数字即为音调
uchar code shengri_beat[]={   24,1,24,48,48,48,72,5,//节拍
                                   24,1,24,48,48,48,48,72,5,
                                   24,1,24,48,48,48,72,5    //节拍,即tone表各音调的延时
uchar code ledtable[]={0x7f,0xbf,0xdf,0xef, //取反
0xf7,0xfb,0xfd,0xfe};//P0组口的发光二极管代码(焊接过程可能会相反,具体更改)
uchar code ledtable2[]={0x7f,0xbf,0xdf,0xef, //取反
0xf7,0xfb,0xfd,0xfe};//P2组口发光二极管代码,相反!
void check_key();//改为P3组为按键
void keyscan();
void turn();//顺时针流动
void back();
void qianhou();
void dangshuang();
void delay(uint z);//延时函数声明
void delay1(void);//声明第二个延时函数
void play1(void);//播放生日快乐
s1num=0;//流水灯种类标志
key1=1;
key2=1;
TMOD=0x01;
TH0=a;
TL0=b;
ET0=1;//打开定时器,但是未允许中断
TR0=1;
check_key();
keyscan();
void time0() interrupt 1
TH0=a;
TL0=b;
speaker=~speaker;
void check_key()
P3=0xff;//先赋给P2组口高电平
switch(P3)//按下一个键相应4个灯亮
case 0xfe:P0=0xee;P2=0x77;a=0xfb;b=0xe9;EA=1;break;//P0,P2组为发光二极管组
case 0xfd:P0=0xdd;P2=0xbb;a=0xfc;b=0x5c;EA=1;break;//注意:EA不能改为TR0
case 0xfb:P0=0xbb;P2=0xdd;a=0xfc;b=0xc1;EA=1;break;
case 0xf7:P0=0x77;P2=0xee;a=0xfc;b=0xef;EA=1;break;
case 0xef:P0=0xee;P2=0x77;a=0xfd;b=0x45;EA=1;break;
case 0xdf:P0=0xdd;P2=0xbb;a=0xfd;b=0x92;EA=1;break;
case 0xbf:P0=0xbb;P2=0xdd;a=0xfd;b=0xd0;EA=1;break;
case 0x7f:P0=0x77;P2=0xee;a=0xfd;b=0xee;EA=1;break;
default:EA=0;speaker=0;//P0=0xff;P2=0xff ;
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void keyscan()
 if(key1==0)
  delay(5);
if(key1==0)
s1num++;
while(!key1);
if(s1num==1)
turn();
if(s1num==2)
back();
if(s1num==3)
qianhou();
if(s1num==4)
dangshuang();
if(s1num==5)
s1num=1;
if(key2==0)
delay(5);
while(~key2);
play1();
 void delay1(void)//第二个延时函数
       uchar n=15;
       while(n--)
              uchar i;
              for(i=0;i<125;i++);
void play1(void)//播放生日快乐
       uchar m=0;
       uchar s;
       uchar c=1;
  P0=0xaa;
  P2=0x55;
              EA=0;
              c=shengri_tone[m];                            //取音符
              s=shengri_beat[m];                      //取节拍
              a=yinfu[2*c-2];
              b=yinfu[2*c-1];
              EA=1;
              while(s--)
                     delay1();
P0=~P0;
P2=~P2;
              m++;
              if(m>=33) return;                      //数值是shengri相关表中的元素数量
/*以下为N种流水灯流动花式*/
void turn()//流水灯顺时针走动(5次)
for(num1=0;num1<8;num1++)
for(num=0;num<8;num++)
 P0=ledtable[num];
 delay(30);//时间暂定
P0=0xff;//之后关闭P1组
for(num=7;num>-1;num--)
P2=ledtable2[num];
delay(30);
P2=0xff;//之后关闭P2组
void back()//逆时针流动
P2=ledtable[num];
delay(30);
P2=0xff;
P0=ledtable2[num];
delay(30);
P0=0xff;
void qianhou()//前后来回
for(num1=0;num1<10;num1++)
P0=ledtable[num];
P2=ledtable2[num];
delay(30);
P0=0xff;
P2=0xff;
P0=ledtable[num];
P2=ledtable2[num];
delay(30);
P0=0xff;
P2=0xff;
void dangshuang()//单数双数
for(num1=0;num1<15;num1++)
P0=0x55;
P2=0xaa;
delay(150);
P0=0xaa;
P2=0x55;
delay(150);
【关闭窗口】
相关文章
