专注电子技术学习与研究
基于单片机的数码管按键计算器程序
作者:胡琴   来源:本站原创   点击数:…  更新时间:2013年11月16日   【字体:大 中 小】
这是一个51hei论坛版主测试成功的程序。用的是stc单片机,电路比较简单就不画出来了 按键接在P2口
数码管的位选口是:
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
数码管的段选口是P0
还有一个led灯p1.4 一个喇叭P1.6
 * Easy calculator
 * K4:+ K8:- K12:* K16:/ K14:Clear K15:=
 *数码管按键计算器程序
#include <reg52.h>
typedef   unsigned char  uint8;
typedef   unsigned int   uint16;
typedef   unsigned long  uint32;
typedef   char  int8;
typedef   int   int16;
typedef   long  int32;
sbit KeyIn1 = P2^4;
sbit KeyIn2 = P2^5;
sbit KeyIn3 = P2^6;
sbit KeyIn4 = P2^7;
sbit KeyOut1 = P2^3;
sbit KeyOut2 = P2^2;
sbit KeyOut3 = P2^1;
sbit KeyOut4 = P2^0;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
sbit BUZZ  = P1^6;
#define FADD 10
#define FSUB 11
#define FMUL 12
#define FDIV 13
#define FRES 14
#define FEQU 15
#define KEY_DELAY 300
#define BUZ_DELAY 80
code uint8 Ledcode[13]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff,0xbf,0x86};
uint8 Led_n=0;
uint8 Led_buf[6];
float Tmp1=0, Tmp2=0;
int8 C_flag=0;
 * 延时
void delay(uint16 n)
 while (n--);
 * 蜂鸣器发声
void buzzer_sound(void)
 uint16 i;
 for (i=0; i<BUZ_DELAY; i++)
  BUZZ = ~BUZZ;
  delay(100);
 BUZZ = 1;
 * 按键扫描
int8 scan_key(void)
 int8 val=-1;
 KeyOut1 = 0;
 KeyOut2 = 1;
 KeyOut3 = 1;
 KeyOut4 = 1;
 if (KeyIn1 == 0)
  delay(KEY_DELAY);
  if (KeyIn1 == 0)
   val = 1;
 if (KeyIn2 == 0)
  delay(KEY_DELAY);
  if (KeyIn2 == 0)
   val = 2;
 if (KeyIn3 == 0)
  delay(KEY_DELAY);
  if (KeyIn3 == 0)
   val = 3;
 if (KeyIn4 == 0)
  delay(KEY_DELAY);
  if (KeyIn4 == 0)
   val = FADD;
 while ((KeyIn1 == 0)||(KeyIn2 == 0)||(KeyIn3 == 0)||(KeyIn4 == 0));
 KeyOut1 = 1;
 KeyOut2 = 0;
 KeyOut3 = 1;
 KeyOut4 = 1;
 if (KeyIn1 == 0)
  delay(KEY_DELAY);
  if (KeyIn1 == 0)
   val = 4;
 if (KeyIn2 == 0)
  delay(KEY_DELAY);
  if (KeyIn2 == 0)
   val = 5;
 if (KeyIn3 == 0)
  delay(KEY_DELAY);
  if (KeyIn3 == 0)
   val = 6;
 if (KeyIn4 == 0)
  delay(KEY_DELAY);
  if (KeyIn4 == 0)
   val = FSUB;
 KeyOut1 = 1;
 KeyOut2 = 1;
 KeyOut3 = 0;
 KeyOut4 = 1;
 if (KeyIn1 == 0)
  delay(KEY_DELAY);
  if (KeyIn1 == 0)
   val = 7;
 if (KeyIn2 == 0)
  delay(KEY_DELAY);
  if (KeyIn2 == 0)
   val = 8;
 if (KeyIn3 == 0)
  delay(KEY_DELAY);
  if (KeyIn3 == 0)
   val = 9;
 if (KeyIn4 == 0)
  delay(KEY_DELAY);
  if (KeyIn4 == 0)
   val = FMUL;
 KeyOut1 = 1;
 KeyOut2 = 1;
 KeyOut3 = 1;
 KeyOut4 = 0;
 if (KeyIn1 == 0)
  delay(KEY_DELAY);
  if (KeyIn1 == 0)
   val = 0;
 if (KeyIn2 == 0)
  delay(KEY_DELAY);
  if (KeyIn2 == 0)
   val = FRES;
 if (KeyIn3 == 0)
  delay(KEY_DELAY);
  if (KeyIn3 == 0)
   val = FEQU;
 if (KeyIn4 == 0)
  delay(KEY_DELAY);
  if (KeyIn4 == 0)
   val = FDIV;
 if (val > 0)
  buzzer_sound();
 return val;
 * 验证数据有效性
bit check_num(float f_num)
 if (f_num >= 100000)
  return 1;
 return 0;
 * 制作数码管错误标志
void make_led_error(void)
 int8 i;
 for (i=0; i<5; i++)
  Led_buf[i] = Ledcode[10];
 Led_buf[5] = Ledcode[12];
 * 制作数码管整数数据
void make_led_inumber(int32 i_num)
 bit s_flag=0;
 int16 sit;
 int8 i;
 if (i_num < 0)
  s_flag = 1;
  i_num = -i_num;
 ET0 = 0;
 for (i=4, sit=10000; i>=1; i--, sit/=10)
  if (i_num >= sit)
   break;
  i_num -= i_num/sit*sit;
 for (;i>=1; i--, sit/=10)
  Led_buf[i] = Ledcode[i_num/sit];
 Led_buf[0] = Ledcode[i_num] & 0x7F;
 if (s_flag)
  Led_buf[5] = Ledcode[11];
  Led_buf[5] = Ledcode[10];
 ET0 = 1;
 * 制作数码管浮点数据
void make_led_fnumber(float f_num)
 bit s_flag=0;
 int32 num;
 int16 sit;
 int8 i, decimal, dot_sit=0;
 if (f_num < 0)
  s_flag = 1;
  f_num = -f_num;
 num = (int32)(f_num*10000+0.5);
 for (decimal=4; decimal>0; decimal--)
  if (num % 10 != 0)
   break;
  num /= 10;
 dot_sit = decimal;
 if (f_num >= 10000)
  dot_sit = 0;
 else if (f_num >= 1000)
  if (decimal >= 1)
   dot_sit = 1;
 else if (f_num >= 100)
  if (decimal >= 2)
   dot_sit = 2;
 else if (f_num >= 10)
  if (decimal >= 3)
   dot_sit = 3;
 for (i=0; i<dot_sit; i++)
  f_num *= 10;
 num = (int32)(f_num+0.5);
 ET0 = 0;
  if (num >= sit)
   break;
  if (i == dot_sit)
   break;
  num -= num/sit*sit;
  Led_buf[i] = Ledcode[num/sit];
  num -= num/sit*sit;
 Led_buf[0] = Ledcode[num];
 Led_buf[dot_sit] &= 0x7F;
 if (s_flag)
 ET0 = 1;
 * 数码管显示
void show_num(uint8 *buf)
 ENLED = 1;
 switch (Led_n)
  case 0:
   ADDR0 = 0;
   ADDR1 = 0;
   ADDR2 = 0;
   P0 = buf[0];
   break;
  case 1:
   ADDR0 = 1;
   ADDR1 = 0;
   ADDR2 = 0;
   P0 = buf[1];
   break;
  case 2:
   ADDR0 = 0;
   ADDR1 = 1;
   ADDR2 = 0;
   P0 = buf[2];
   break;
  case 3:
   ADDR0 = 1;
   ADDR1 = 1;
   ADDR2 = 0;
   P0 = buf[3];
   break;
  case 4:
   ADDR0 = 0;
   ADDR1 = 0;
   ADDR2 = 1;
   P0 = buf[4];
   break;
  case 5:
   ADDR0 = 1;
   ADDR1 = 0;
   ADDR2 = 1;
   P0 = buf[5];
   break;
 ENLED = 0;
 if (Led_n >= 5)
  Led_n = 0;
  Led_n++;
 * 计算程序
void calculate(int8 key_val)
 float ans;
 bit err=0;
 if ((key_val >= FADD) && (key_val <= FDIV))
  C_flag = key_val;
 else if (key_val == FEQU)
  switch (C_flag)
   case FADD:  ans = Tmp1+Tmp2; break;
   case FSUB:  ans = Tmp1-Tmp2; break;
   case FMUL:  ans = Tmp1*Tmp2; break;
   case FDIV:  if (Tmp2 == 0)
       err = 1;
       break;
       ans = Tmp1/Tmp2;
       break;
  if (check_num(ans))
   err = 1;
  if (err)
   make_led_error();
   make_led_fnumber(ans);
  C_flag = 0;
  Tmp1 = 0;
  Tmp2 = 0;
 else if (key_val == FRES)
  make_led_fnumber(0);
  C_flag = 0;
  Tmp1 = 0;
  Tmp2 = 0;
  if (C_flag == 0)
   ans = Tmp1;
   ans *= 10;
   ans += key_val;
   if (check_num(ans))
    return;
    Tmp1 = ans;
   make_led_inumber(Tmp1);
   ans = Tmp2;
   ans *= 10;
   ans += key_val;
   if (check_num(ans))
    return;
    Tmp2 = ans;
   make_led_inumber(Tmp2);
main()
 int8 key_val;
 ADDR3 = 1;
 ENLED = 0;
 make_led_inumber(0);
    TMOD = 0x01;
    TH0 = 0xF8;
    TL0 = 0xCC;
    TR0 = 1;
 ET0 = 1;
 EA = 1;
 while (1)
  key_val = scan_key();
  if (key_val == -1)
   continue;
  calculate(key_val);
void time0() interrupt 1
 TR0 = 0;
 TH0 = 0xF8;
 TL0 = 0xCC;
 show_num(Led_buf);
 TR0 = 1;
【关闭窗口】
相关文章
