专注电子技术学习与研究
单片机PID算法实现
作者:韩冰   来源:本站原创   点击数:…  更新时间:2013年11月28日   【字体:大 中 小】
在avr单片机上实现的100%通过测试,用单片机调的倒立摆非常稳定.
#include <stdio.h>
#include<math.h>
struct _pid
int pv; //integer that contains the process value 过程量
int sp; //*integer that contains the set point   设定值
float integral; // 积分值
float pgain;
float igain;
float dgain;
int deadband;    //死区
int last_error;
struct _pid warm,*pid;
int process_point, set_point,dead_band;
float p_gain, i_gain, d_gain, integral_val,new_integ;;
void pid_init(struct _pid *warm, int process_point, int set_point)
struct _pid *pid;
pid = warm;
pid->pv = process_point;
pid->sp = set_point;
void pid_tune(struct _pid *pid, float p_gain, float i_gain, float d_gain, int dead_band)
pid->pgain = p_gain;
pid->igain = i_gain;
pid->dgain = d_gain;
pid->deadband = dead_band;
pid->integral= integral_val;
pid->last_error=0;
void pid_setinteg(struct _pid *pid,float new_integ)
pid->integral = new_integ;
pid->last_error = 0;
void pid_bumpless(struct _pid *pid)
pid->last_error = (pid->sp)-(pid->pv);  //设定值与反馈值偏差
float pid_calc(struct _pid *pid)
int err;
float pterm, dterm, result, ferror;
// 计算偏差
err = (pid->sp) - (pid->pv);
// 判断是否大于死区
if (abs(err) > pid->deadband)
ferror = (float) err;   //do integer to float conversion only once 数据类型转换
// 比例项
pterm = pid->pgain * ferror;
if (pterm > 100 || pterm < -100)
pid->integral = 0.0;
// 积分项
pid->integral += pid->igain * ferror;
if (pid->integral > 100.0)
pid->integral = 100.0;
else if (pid->integral < 0.0)
// 微分项
dterm = ((float)(err - pid->last_error)) * pid->dgain;
result = pterm + pid->integral + dterm;
result = pid->integral; // 在死区范围内,保持现有输出
// 保存上次偏差
pid->last_error = err;
return (result);
参数说明:
p_gain = (float)(5.2);//比例系数
i_gain = (float)(0.77);//积分系数
d_gain = (float)(0.18);//微分系数
process_point为设定的稳定值
display_value为系统输出值
process_point为传感器传入当前值
函数调用示例:
float display_value;
int count=0;
pid = &warm;
process_point = 30;
set_point = 40;
dead_band = 2;
integral_val =(float)(0.01);
scanf("%d",&process_point);
// 设定PV,SP值
pid_init(&warm, process_point, set_point);
// 初始化PID参数值
pid_tune(&warm, p_gain,i_gain,d_gain,dead_band);
// 初始化PID输出值
pid_setinteg(&warm,0.0);
//pid_setinteg(&warm,30.0);
pid_bumpless(&warm);
display_value = pid_calc(&warm);
printf("%f\n", display_value);
【关闭窗口】
相关文章
