专注电子技术学习与研究
51单片机秒表C程序
作者:huqin   来源:徐冉   点击数:…  更新时间:2014年03月24日   【字体:大 中 小】
本程序所用的原理图下载: 点这里 ,单片机芯片使用的stc89c52;电路找到相应部分即可.这是一整个单片机开发板的电路图其他的忽略.
本程序的keil工程下载: http://www.51hei.com/f/miaobiao.rar   以下是通过测试的源代码:
*功能:用定时器0实现秒表,实现60秒定时,精确度为1毫秒
*   利用key1独立按键实现定时器的启动和停止,
*   利用key2独立按键实现秒表的清零;
*日期:2013-03-24
*作者:徐冉
*注意事项:若打开两个定时器时,必须使用两个定时器,
*     否则两个定时器都不工作!!!
/**********stc89C52-RC 51hei单片机实验板**********/
/**********51hei-5开发板**********/
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit wela = P2^7;
sbit dula = P2^6;
sbit key1 = P3^4;
sbit key2 = P3^5;
sbit FM   = P2^3;//蜂鸣器
uchar code table[] = {
       0x3F,  //"0"
                0x06,  //"1"
                0x5B,  //"2"
                0x4F,  //"3"
                0x66,  //"4"
                0x6D,  //"5"
                0x7D,  //"6"
                0x07,  //"7"
                0x7F,  //"8"
                0x6F,  //"9"
                0x77,  //"A"
                0x7C,  //"B"
                0x39,  //"C"
                0x5E,  //"D"
                0x79,  //"E"
                0x71,  //"F"
                0x76,  //"H"
                0x38,  //"L"
                0x37,  //"n"
                0x3E,  //"u"
                0x73,  //"P"
                0x5C,  //"o"
                0x40,  //"-"
                0x00,  //熄灭
                0x40  //自定义
uint counter, num_h, num_m;
void delay(uint xms);
void display_h(uint num_h);
void init();
void display_m(uint num_m);
void keyscan_D();
void keyscan_Q();
//主函数
 init();
  dula = 1;
  P0 = table[22];
  dula = 0;
  P0 = 0xff;
  wela = 1;
  P0 = 0xfb;
  wela = 0;
  keyscan_D();
  keyscan_Q();
  display_h(num_h);
  display_m(num_m);
//定时器0初始化函数
void init()
 TMOD = 0x01;
 TH0 = 0xFC;
 TL0 = 0x67;
 TR0 = 1;
 EA = 1;
 ET0 = 1;
//毫秒位显示子函数
 uchar bai,shi,ge;
 bai = num_h / 100 % 10;
 shi = num_h / 10 % 10;
 ge  = num_h % 10;
 dula = 1;
 P0 = table[bai];
 dula = 0;
 P0 = 0xff;
 wela = 1;
 P0 = 0xf7;
 wela = 0;
 P0 = 0x00;
 delay(1);
    dula = 1;
 P0 = table[shi];
 dula = 0;
 P0 = 0xff;
 wela = 1;
 P0 = 0xef;
 wela = 0;
 P0 = 0x00;
 delay(1);
 dula = 1;
 P0 = table[ge];
 dula = 0;
 P0 = 0xff;
 wela = 1;
 P0 = 0xdf;
 wela = 0;
 P0 = 0x00;
 delay(1);
//秒位显示子函数
 uchar shi_, ge_;
 shi_ = num_m / 10 % 10;
 ge_ = num_m % 10;
 dula = 1;
 P0 = table[shi_];
 dula = 0;
 P0 = 0xff;
 wela = 1;
 P0 = 0xfe;
 wela = 0;
 P0 = 0x00;
 delay(1);
 dula = 1;
 P0 = table[ge_];
 dula = 0;
 P0 = 0xff;
 wela = 1;
 P0 = 0xfd;
 wela = 0;
 P0 = 0x00;
 delay(1);
//延时子函数
 uint i, j;
 for(i = xms; i > 0; i--)
   for(j = 125; j > 0; j--);
//独立按键1检测子函数 ,开启和关闭
void keyscan_D()
 if(key1 == 0)
  delay(10);
  if(key1 == 0)
   TR0 = ~TR0;
   FM = 0;
   while(!key1);
   FM = 1;
//独立按键2检测子函数,清零
void keyscan_Q()
 if(key2 == 0)
  delay(10);
  if(key2 == 0)
   counter = 0;
   num_h = 0;
   num_m = 0;
   FM = 0;
   while(!key2);
   FM = 1;
//定时器0中断子程序
void int_time0() interrupt 1
 TH0 = 0xFC;
 TL0 = 0x67;
 counter++;
 if(counter == 1)
  counter = 0;
  num_h++; //毫秒自增
  if(num_h == 1000)
   num_h = 0;
   num_m++; //秒自增
   if(num_m == 60)
    num_m = 0;
【关闭窗口】
相关文章
