专注电子技术学习与研究
51单片机电子时钟C语言程序
作者:huqin   来源:本站原创   点击数:…  更新时间:2014年04月05日   【字体:大 中 小】
51最基础简单易懂的单片机,差不多一个月的时间,断断续续地学习,终于算是学完了,下个目标是飞思卡尔s12x和k60 也就是ARM crotex-M4架构. 51最核心的部分,我觉得是中断的使用,一个项目离不开中断,还有就是串口的理解,还有就是IIC通信。
以 电子时钟 为结尾篇,附上代码。代码有些不怎么完美。但终究是差不多写出来了。结合了IIC通信,中断定时器的使用,键盘使用,还有液晶的显示。
#include <reg52.h>
sbit RS = P2^7;
sbit RW = P2^6;
sbit E = P2^5;
sbit Sda = P2^0;
sbit Scl = P2^1;
sbit keyleft = P1^0;
sbit keyup = P1^1;
sbit keydown = P1^2;
sbit keyright = P1^3;
unsigned char sec=0,min=0,hour=0;
unsigned char Year[20]="   2012.10.1   ";
unsigned char i;
unsigned int times = 0;
unsigned char countleft = 0,countright = 0;
unsigned char busycheck();
static void Start(void)
	Sda = 1;
	Scl = 1;
	Sda = 0;
static void Stop(void)
	Sda = 0;
	Scl = 1;
	Sda = 1;
static unsigned char Respons(void)
	unsigned char OverTime = 0;  //超时
	unsigned char TempFlag = 0;
	OverTime = 0;
    Sda = 1;     //释放数据线
    Scl = 1;
		if(Sda)   //应答信号没来
			if(OverTime++ > 200)
			  TempFlag = 0;   //应答信号长时间没有来,认为无应答
			  break;
		   TempFlag = 1;    ///检测到应答信号
			break;
	Scl = 0;
	return TempFlag;
static void NoRespons(void)  //非应答
    Sda = 1;     //释放数据线
    Scl = 1;
	Scl = 0;
static void WriteByte(unsigned char temp)
	unsigned char i;
	Scl = 0;
	for(i = 0;i < 8;i++)
		Sda = temp & 0x80;
		temp <<= 1;
		Scl = 1;    //scl拉高,准备写数据
		Scl = 0;   //scl拉低,写数据完成
static unsigned char ReadByte(void)
	unsigned char i;
	unsigned char x = 0;
		Scl = 1;
		x <<= 1;
		x |= (unsigned char)Sda;
		Scl = 0;
	return x;
void WriteIIC(unsigned char device,unsigned char parameter,unsigned char temp)
	Start();
	WriteByte(device);
	if(Respons())
		WriteByte(parameter);
		if(Respons())
			WriteByte(temp);
			if(Respons())
				Stop();
				Stop();
			Stop();
		Stop();
unsigned char ReadIIC(unsigned char device,unsigned char parameter)
	unsigned char x;
	Start();
	WriteByte(device);
	if(Respons())
		if(Respons())
			Start();
			WriteByte(device | 0x01);
			if(Respons())
				x = ReadByte();
				NoRespons();
				Stop();
				Stop();
			Stop();
		Stop();
	return x;
void writecmd(unsigned char cmd)
	while(busycheck());
	RS = 0;
	RW = 0;
	E = 1;
	P0 = cmd;
	E = 0;
void writedata(unsigned char dat)
	while(busycheck());
	RS = 1;
	RW = 0;
	E = 1;
	P0 = dat;
	E = 0;
	P0 = 0xff;
	RS = 0;
	RW = 1;
	E = 0;
	E = 1;
	return(P0 & 0x80);
void writedate(unsigned char add,unsigned char date)
	unsigned char shi,ge;
	shi = date/10;
	ge = date%10;
	writecmd(0x80+0x40+add);
	writedata(0x30+shi);
	writedata(0x30+ge);
void Init()
	writecmd(0x38);//显示模式
        writecmd(0x08);//关屏
        writecmd(0x01);//清屏
        writecmd(0x06);//设置光标右移
	writecmd(0x0c);//显示,无标 闪烁
	writecmd(0x80);
	for(i = 0;i < 20;i++)
		writedata(Year[i]);
	writecmd(0x80+0x40+6);
	writedata(':');
	writecmd(0x80+0x40+9);
	writedata(':');
	sec = ReadIIC(0xa0,0);
	min = ReadIIC(0xa0,2);
	hour = ReadIIC(0xa0,4);
	writedate(10,sec);
	writedate(7,min);
	writedate(4,hour);
	TMOD = 0x02;
	TH0 = 6;
	TL0 = 6;
	EA = 1;
	ET0 = 1;
	TR0 = 1;
void delay()
	unsigned char x = 2000;
	while(x--);
void keyscan()
	if(!keyleft)
		delay();
		if(!keyleft)
			TR0 = 0;
			if(countleft == 0)
				countleft++;
				writecmd(0x80+0x40+10);
				writecmd(0x0f);
				if(countleft == 1)
					countleft++;
					writecmd(0x80+0x40+7);
					if(countleft == 2)
					countleft++;
					writecmd(0x80+0x40+4);
						if(countleft == 3)
							TR0 = 1;
							writecmd(0x0c);
							countleft = 0;
	if(!keydown)
		delay();
		if(!keydown)
			if(countleft == 1)
				sec--;
				if(sec == 60)
					sec = 0;
				writedate(10,sec);
				WriteIIC(0xa0,1,sec);
				if(countleft == 2)
					min--;
					if(min == 60)
						min = 0;
					writedate(7,min);
					WriteIIC(0xa0,2,min);
					if(countleft == 2)
						hour--;
						if(hour == 24)
							hour = 0;
						writedate(4,hour);
						WriteIIC(0xa0,3,hour);
	if(!keyright)
		delay();
		if(!keyright)
			if(countleft == 1)
				sec++;
				if(sec == 60)
					sec = 0;
				writedate(10,sec);
				if(countleft == 2)
					min++;
					if(min == 60)
						min = 0;
					writedate(7,min);
					if(countleft == 2)
						hour++;
						if(hour == 24)
							hour = 0;
						writedate(4,hour);
	Init();
		keyscan();
void Time0(void) interrupt 1
	times++;
	if(times == 3686)
			times = 0;
			sec++;
			if(sec == 60)
				sec = 0;
				min++;
				if(min == 60)
					min = 0;
					hour++;
					if(hour == 24)
						hour = 0;
					writedate(4,hour);
				writedate(7,min);
			writedate(10,sec);
【关闭窗口】
相关文章
