专注电子技术学习与研究
S3C6410_SYS_CONTROLL.h文件源码下载
作者:huqin   来源:本站原创   点击数:…  更新时间:2014年04月08日   【字体:大 中 小】
S3C6410_SYS_CONTROLL.h文件的代码给大家共享出来,右键另存保存为文件即下载:
#ifndef _S3C6410_SYS_CONTROLL_H_
#define _S3C6410_SYS_CONTROLL_H_
#define SYS_BASE 0x7E00F000
#define rAPLL_LOCK	(*(volatile unsigned *)(SYS_BASE + 0x000))
#define rMPLL_LOCK	(*(volatile unsigned *)(SYS_BASE + 0x004))
#define rEPLL_LOCK	(*(volatile unsigned *)(SYS_BASE + 0x008))
#define rAPLL_CON	(*(volatile unsigned *)(SYS_BASE + 0x00C))
#define rMPLL_CON	(*(volatile unsigned *)(SYS_BASE + 0x010))
#define rEPLL_CON0	(*(volatile unsigned *)(SYS_BASE + 0x014))
#define rEPLL_CON1	(*(volatile unsigned *)(SYS_BASE + 0x018))
#define rCLK_SRC	(*(volatile unsigned *)(SYS_BASE + 0x01C))
#define rCLK_DIV0	(*(volatile unsigned *)(SYS_BASE + 0x020))
#define rCLK_DIV1	(*(volatile unsigned *)(SYS_BASE + 0x024))
#define rCLK_DIV2	(*(volatile unsigned *)(SYS_BASE + 0x028))
#define rCLK_OUT	(*(volatile unsigned *)(SYS_BASE + 0x02C))
#define rHCLK_GATE	(*(volatile unsigned *)(SYS_BASE + 0x030))
#define rPCLK_GATE	(*(volatile unsigned *)(SYS_BASE + 0x034))
#define rSCLK_GATE	(*(volatile unsigned *)(SYS_BASE + 0x038))
#define rAHB_CON0	(*(volatile unsigned *)(SYS_BASE + 0x100))
#define rAHB_CON1	(*(volatile unsigned *)(SYS_BASE + 0x104))
#define rAHB_CON2	(*(volatile unsigned *)(SYS_BASE + 0x108))
#define rSDMA_SEL	(*(volatile unsigned *)(SYS_BASE + 0x110))
#define rSW_RST	(*(volatile unsigned *)(SYS_BASE + 0x114))
#define rSYS_ID	(*(volatile unsigned const*)(SYS_BASE + 0x118))
#define rMEM_SYS_CFG	(*(volatile unsigned *)(SYS_BASE + 0x120))
#define rQOS_OVERRIDE0	(*(volatile unsigned *)(SYS_BASE + 0x124))
#define rQOS_OVERRIDE1	(*(volatile unsigned *)(SYS_BASE + 0x128))
#define rMEM_CFG_STAT	(*(volatile unsigned const*)(SYS_BASE + 0x12C))
#define rPWR_CFG	(*(volatile unsigned *)(SYS_BASE + 0x804))
#define rEINT_MASK	(*(volatile unsigned *)(SYS_BASE + 0x808))
#define rNORMAL_CFG	(*(volatile unsigned *)(SYS_BASE + 0x810))
#define rSTOP_CFG	(*(volatile unsigned *)(SYS_BASE + 0x814))
#define rSLEEP_CFG	(*(volatile unsigned *)(SYS_BASE + 0x818))
#define rOSC_FREQ	(*(volatile unsigned *)(SYS_BASE + 0x820))
#define rPWR_STABLE	(*(volatile unsigned *)(SYS_BASE + 0x828))
#define rMTC_STABLE	(*(volatile unsigned *)(SYS_BASE + 0x830))
#define rOTHERS	(*(volatile unsigned *)(SYS_BASE + 0x900))
#define rRST_STAT	(*(volatile unsigned const*)(SYS_BASE + 0x904))
#define rWAKEUP_STAT	(*(volatile unsigned *)(SYS_BASE + 0x908))
#define rBLK_PWR_STAT	(*(volatile unsigned const*)(SYS_BASE + 0x90C))
#define rINFORM0	(*(volatile unsigned *)(SYS_BASE + 0xA00))
#define rINFORM1	(*(volatile unsigned *)(SYS_BASE + 0xA04))
#define rINFORM2	(*(volatile unsigned *)(SYS_BASE + 0xA08))
#define rINFORM3	(*(volatile unsigned *)(SYS_BASE + 0xA0C))
//DRAM Control
#define rP0MEMSTAT	(*(volatile unsigned const*)0x7E000000)
#define rP1MEMSTAT	(*(volatile unsigned const*)0x7E001000)
#define rP0MEMCCMD	(*(volatile unsigned *)0x7E000004)
#define rP1MEMCCMD	(*(volatile unsigned *)0x7E001004)
#define rP0DIRECTCMD	(*(volatile unsigned *)0x7E000008)
#define rP1DIRECTCMD	(*(volatile unsigned *)0x7E001008)
#define rP0MEMCFG	(*(volatile unsigned *)0x7E00000C)
#define rP1MEMCFG	(*(volatile unsigned *)0x7E00100C)
#define rP0REFRESH	(*(volatile unsigned *)0x7E000010)
#define rP1REFRESH	(*(volatile unsigned *)0x7E001010)
#define rP0CASLAT	(*(volatile unsigned *)0x7E000014)
#define rP1CASLAT	(*(volatile unsigned *)0x7E001014)
#define rP0T_DQSS	(*(volatile unsigned *)0x7E000018)
#define rP1T_DQSS	(*(volatile unsigned *)0x7E001018)
#define rP0T_MRD	(*(volatile unsigned *)0x7E00001C)
#define rP1T_MRD	(*(volatile unsigned *)0x7E00101C)
#define rP0T_RAS	(*(volatile unsigned *)0x7E000020)
#define rP1T_RAS	(*(volatile unsigned *)0x7E001020)
#define rP0T_RC	(*(volatile unsigned *)0x7E000024)
#define rP1T_RC	(*(volatile unsigned *)0x7E001024)
#define rP0T_RCD	(*(volatile unsigned *)0x7E000028)
#define rP1T_RCD	(*(volatile unsigned *)0x7E001028)
#define rP0T_RFC	(*(volatile unsigned *)0x7E00002C)
#define rP0T_RFC	(*(volatile unsigned *)0x7E00102C)
#define rP0T_RP	(*(volatile unsigned *)0x7E000030)
#define rP1T_RP	(*(volatile unsigned *)0x7E000030)
#define rP0T_RRD	(*(volatile unsigned *)0x7E000034)
#define rP1T_RRD	(*(volatile unsigned *)0x7E001034)
#define rP0T_WR	(*(volatile unsigned *)0x7E000038)
#define rP1T_WR	(*(volatile unsigned *)0x7E001038)
#define rP0T_WTR	(*(volatile unsigned *)0x7E00003C)
#define rP1T_WTR	(*(volatile unsigned *)0x7E00103C)
#define rP0T_XP	(*(volatile unsigned *)0x7E000040)
#define rP1T_XP	(*(volatile unsigned *)0x7E001040)
#define rP0T_XSR	(*(volatile unsigned *)0x7E000044)
#define rP1T_XSR	(*(volatile unsigned *)0x7E001044)
#define rP0T_ESR	(*(volatile unsigned *)0x7E000048)
#define rP1T_ESR	(*(volatile unsigned *)0x7E001048)
#define rP0MEMCFG2	(*(volatile unsigned *)0x7E00004C)
#define rP1MEMCFG2	(*(volatile unsigned *)0x7E00104C)
#define rP0_ID0_CFG	(*(volatile unsigned *)0x7E000100)
#define rP1_ID0_CFG	(*(volatile unsigned *)0x7E001100)
#define rP0_ID1_CFG	(*(volatile unsigned *)0x7E000104)
#define rP1_ID1_CFG	(*(volatile unsigned *)0x7E001104)
#define rP0_ID2_CFG	(*(volatile unsigned *)0x7E000108)
#define rP1_ID2_CFG	(*(volatile unsigned *)0x7E001108)
#define rP0_ID3_CFG	(*(volatile unsigned *)0x7E00010C)
#define rP1_ID3_CFG	(*(volatile unsigned *)0x7E00110C)
#define rP0_ID4_CFG	(*(volatile unsigned *)0x7E000110)
#define rP1_ID4_CFG	(*(volatile unsigned *)0x7E001110)
#define rP0_ID5_CFG	(*(volatile unsigned *)0x7E000114)
#define rP1_ID5_CFG	(*(volatile unsigned *)0x7E001114)
#define rP0_ID6_CFG	(*(volatile unsigned *)0x7E000118)
#define rP1_ID6_CFG	(*(volatile unsigned *)0x7E001118)
#define rP0_ID7_CFG	(*(volatile unsigned *)0x7E00011C)
#define rP1_ID7_CFG	(*(volatile unsigned *)0x7E00111C)
#define rP0_ID8_CFG	(*(volatile unsigned *)0x7E000120)
#define rP1_ID8_CFG	(*(volatile unsigned *)0x7E001120)
#define rP0_ID9_CFG	(*(volatile unsigned *)0x7E000124)
#define rP1_ID9_CFG	(*(volatile unsigned *)0x7E001124)
#define rP0_ID10_CFG	(*(volatile unsigned *)0x7E000128)
#define rP1_ID10_CFG	(*(volatile unsigned *)0x7E001128)
#define rP0_ID11_CFG	(*(volatile unsigned *)0x7E00012C)
#define rP1_ID11_CFG	(*(volatile unsigned *)0x7E00112C)
#define rP0_ID12_CFG	(*(volatile unsigned *)0x7E000130)
#define rP1_ID12_CFG	(*(volatile unsigned *)0x7E001130)
#define rP0_ID13_CFG	(*(volatile unsigned *)0x7E000134)
#define rP1_ID13_CFG	(*(volatile unsigned *)0x7E001134)
#define rP0_ID14_CFG	(*(volatile unsigned *)0x7E000138)
#define rP1_ID14_CFG	(*(volatile unsigned *)0x7E001138)
#define rP0_ID15_CFG	(*(volatile unsigned *)0x7E00013C)
#define rP1_ID15_CFG	(*(volatile unsigned *)0x7E00113C)
#define rP0_CHIP0_CFG	(*(volatile unsigned *)0x7E000200)
#define rP1_CHIP0_CFG	(*(volatile unsigned *)0x7E001200)
#define rP0_CHIP1_CFG	(*(volatile unsigned *)0x7E000204)
#define rP1_CHIP1_CFG	(*(volatile unsigned *)0x7E001204)
#define rP0_USER_START	(*(volatile unsigned *)0x7E000300)
#define rP1_USER_START	(*(volatile unsigned *)0x7E001300)
#define rP0_USER_CFG	(*(volatile unsigned *)0x7E000304)
#define rP1_USER_CFG	(*(volatile unsigned *)0x7E001304)
//SROM
#define rSROM_BW	(*(volatile unsigned *)0x70000000)
#define rSROM_BC0	(*(volatile unsigned *)0x70000004)
#define rSROM_BC1	(*(volatile unsigned *)0x70000008)
#define rSROM_BC2	(*(volatile unsigned *)0x7000000C)
#define rSROM_BC3	(*(volatile unsigned *)0x70000010)
#define rSROM_BC4	(*(volatile unsigned *)0x70000014)
#define rSROM_BC5	(*(volatile unsigned *)0x70000018)
//ONENAND	BANK0
#define rMEM_CFG0	(*(volatile unsigned *)0x70100000)
#define rBURST_LEN0	(*(volatile unsigned *)0x70100010)
#define rMEM_RESET0	(*(volatile unsigned *)0x70100020)
#define rINT_ERR_STAT0	(*(volatile unsigned *)0x70100030)
#define rINT_ERR_MASK0	(*(volatile unsigned *)0x70100040)
#define rINT_ERR_ACK0	(*(volatile unsigned *)0x70100050)
#define rECC_ERR_STAT0	(*(volatile unsigned *)0x70100060)
#define rMANUFACT_ID0	(*(volatile unsigned const*)0x70100070)
#define rDEVICE_ID0	(*(volatile unsigned const*)0x70100080)
#define rDATA_BUF_SIZE0	(*(volatile unsigned const*)0x70100090)
#define rBOOT_BUF_SIZE0	(*(volatile unsigned const*)0x701000A0)
#define rBUF_AMOUNT0	(*(volatile unsigned const*)0x701000B0)
#define rTECH0	(*(volatile unsigned const*)0x701000C0)
#define rFBA_WIDTH0	(*(volatile unsigned*)0x701000D0)
#define rFPA_WIDTH0	(*(volatile unsigned*)0x701000E0)
#define rFSA_WIDTH0	(*(volatile unsigned*)0x701000F0)
#define rREVISION0	(*(volatile unsigned const*)0x70100100)
#define rDATARAM00	(*(volatile unsigned*)0x70100110)
#define rDATARAM10	(*(volatile unsigned*)0x70100120)
#define rSYNC_MODE0	(*(volatile unsigned const*)0x70100130)
#define rTRANS_SPARE0	(*(volatile unsigned*)0x70100140)
#define rLOCK_BIT0	(*(volatile unsigned*)0x70100150)
#define rDBS_DFS_WIDTH0	(*(volatile unsigned*)0x70100160)
#define rPAGE_CNT0	(*(volatile unsigned const*)0x70100170)
#define rERR_PAGE_ADDR0	(*(volatile unsigned const*)0x70100180)
#define rBURST_RD_LAT0	(*(volatile unsigned const*)0x70100190)
#define rINT_PIN_ENABLE0	(*(volatile unsigned*)0x701001A0)
#define rINT_MON_CYC0	(*(volatile unsigned*)0x701001B0)
#define rACC_CLOCK0	(*(volatile unsigned*)0x701001C0)
#define rSLOW_RD_PATH0	(*(volatile unsigned*)0x701001D0)
#define rERR_BLK_ADDR0	(*(volatile unsigned const*)0x701001E0)
#define rFLASH_VER_ID0	(*(volatile unsigned const*)0x701001F0)
//ONENAND	BANK1
#define rMEM_CFG1	(*(volatile unsigned *)0x70180000)
#define rBURST_LEN1	(*(volatile unsigned *)0x70180010)
#define rMEM_RESET1	(*(volatile unsigned *)0x70180020)
#define rINT_ERR_STAT1	(*(volatile unsigned *)0x70180030)
#define rINT_ERR_MASK1	(*(volatile unsigned *)0x70180040)
#define rINT_ERR_ACK1	(*(volatile unsigned *)0x70180050)
#define rECC_ERR_STAT1	(*(volatile unsigned *)0x70180060)
#define rMANUFACT_ID1	(*(volatile unsigned const*)0x70180070)
#define rDEVICE_ID1	(*(volatile unsigned const*)0x70180080)
#define rDATA_BUF_SIZE1	(*(volatile unsigned const*)0x70180090)
#define rBOOT_BUF_SIZE1	(*(volatile unsigned const*)0x701800A0)
#define rBUF_AMOUNT1	(*(volatile unsigned const*)0x701800B0)
#define rTECH1	(*(volatile unsigned const*)0x701800C0)
#define rFBA_WIDTH1	(*(volatile unsigned*)0x701800D0)
#define rFPA_WIDTH1	(*(volatile unsigned*)0x701800E0)
#define rFSA_WIDTH1	(*(volatile unsigned*)0x701800F0)
#define rREVISION1	(*(volatile unsigned const*)0x70180100)
#define rDATARAM01	(*(volatile unsigned*)0x70180110)
#define rDATARAM11	(*(volatile unsigned*)0x70180120)
#define rSYNC_MODE1	(*(volatile unsigned const*)0x70180130)
#define rTRANS_SPARE1	(*(volatile unsigned*)0x70180140)
#define rLOCK_BIT1	(*(volatile unsigned*)0x70180150)
#define rDBS_DFS_WIDTH1	(*(volatile unsigned*)0x70180160)
#define rPAGE_CNT1	(*(volatile unsigned const*)0x70180170)
#define rERR_PAGE_ADDR1	(*(volatile unsigned const*)0x70180180)
#define rBURST_RD_LAT1	(*(volatile unsigned const*)0x70180190)
#define rINT_PIN_ENABLE1	(*(volatile unsigned*)0x701801A0)
#define rINT_MON_CYC1	(*(volatile unsigned*)0x701801B0)
#define rACC_CLOCK1	(*(volatile unsigned*)0x701801C0)
#define rSLOW_RD_PATH1	(*(volatile unsigned*)0x701801D0)
#define rERR_BLK_ADDR1	(*(volatile unsigned const*)0x701801E0)
#define rFLASH_VER_ID1	(*(volatile unsigned const*)0x701801F0)
//NAND FLASH
#define rNFCONF	(*(volatile unsigned*)0x70200000)
#define rNFCONT	(*(volatile unsigned*)0x70200004)
#define rNFCMMD	(*(volatile unsigned*)0x70200008)
#define rNFADDR	(*(volatile unsigned*)0x7020000C)
#define rNFDATA	(*(volatile unsigned*)0x70200010)
#define rNFMECCD0	(*(volatile unsigned*)0x70200014)
#define rNFMECCD1	(*(volatile unsigned*)0x70200018)
#define rNFSECCD	(*(volatile unsigned*)0x7020001C)
#define rNFSBLK	(*(volatile unsigned*)0x70200020)
#define rNFEBLK	(*(volatile unsigned*)0x70200024)
#define rNFSTAT	(*(volatile unsigned*)0x70200028)
#define rNFECCERR0	(*(volatile unsigned const*)0x7020002C)
#define rNFECCERR1	(*(volatile unsigned const*)0x70200030)
#define rNFMECC0	(*(volatile unsigned const*)0x70200034)
#define rNFMECC1	(*(volatile unsigned const*)0x70200038)
#define rNFSECC	(*(volatile unsigned const*)0x7020003C)
#define rNFMLCBITPT	(*(volatile unsigned const*)0x70200040)
#define rNF8ECCERR0	(*(volatile unsigned const*)0x70200044)
#define rNF8ECCERR1	(*(volatile unsigned const*)0x70200048)
#define rNF8ECCERR2	(*(volatile unsigned const*)0x7020004C)
#define rNFM8ECC0	(*(volatile unsigned const*)0x70200050)
#define rNFM8ECC1	(*(volatile unsigned const*)0x70200054)
#define rNFM8ECC2	(*(volatile unsigned const*)0x70200058)
#define rNFM8ECC3	(*(volatile unsigned const*)0x7020005C)
#define rNFMLC8BITPT0	(*(volatile unsigned const*)0x70200060)
#define rNFMLC8BITPT1	(*(volatile unsigned const*)0x70200064)
//CFCON
#define SFR_BASE 0x703018
#define rMUX_REG	(*(volatile unsigned*)SFR_BASE00)
#define rPCCARD_CNF&STATUS	(*(volatile unsigned*)SFR_BASE20)
#define rPCCARD_INTMSK&SRC	(*(volatile unsigned*)SFR_BASE24)
#define rPCCARD_ATTR	(*(volatile unsigned*)SFR_BASE28)
#define rPCCARD_I/O	(*(volatile unsigned*)SFR_BASE2C)
#define rPCCARD_COMM	(*(volatile unsigned*)SFR_BASE30)
#define ATA_BASE 0x703019
#define rATA_CONTROL	(*(volatile unsigned*)ATA_BASE00)
#define rATA_STATUS	(*(volatile unsigned*)ATA_BASE04)
#define rATA_COMMAND	(*(volatile unsigned*)ATA_BASE08)
#define rATA_SWRST	(*(volatile unsigned*)ATA_BASE0C)
#define rATA_IRQ	(*(volatile unsigned*)ATA_BASE10)
#define rATA_IRQ_MASK	(*(volatile unsigned*)ATA_BASE14)
#define rATA_CFG	(*(volatile unsigned*)ATA_BASE18)
#define rATA_PIO_TIME	(*(volatile unsigned*)ATA_BASE2C)
#define rATA_UDMA_TIME	(*(volatile unsigned*)ATA_BASE30)
#define rATA_XFR_NUM	(*(volatile unsigned*)ATA_BASE34)
#define rATA_XFR_CNT	(*(volatile unsigned*)ATA_BASE38)
#define rATA_TBUF_START	(*(volatile unsigned*)ATA_BASE3C)
#define rATA_TBUF_SIZE	(*(volatile unsigned*)ATA_BASE40)
#define rATA_SBUF_START	(*(volatile unsigned*)ATA_BASE44)
#define rATA_SBUF_SIZE	(*(volatile unsigned*)ATA_BASE48)
#define rATA_CADR_TBUF	(*(volatile unsigned*)ATA_BASE4C)
#define rATA_CADR_SBUF	(*(volatile unsigned*)ATA_BASE50)
#define rATA_PIO_DTR	(*(volatile unsigned*)ATA_BASE54)
#define rATA_PIO_FED	(*(volatile unsigned*)ATA_BASE58)
#define rATA_PIO_SCR	(*(volatile unsigned*)ATA_BASE5C)
#define rATA_PIO_LLR	(*(volatile unsigned*)ATA_BASE60)
#define rATA_PIO_LMR	(*(volatile unsigned*)ATA_BASE64)
#define rATA_PIO_LHR	(*(volatile unsigned*)ATA_BASE68)
#define rATA_PIO_DVR	(*(volatile unsigned*)ATA_BASE6C)
#define rATA_PIO_CSD	(*(volatile unsigned*)ATA_BASE70)
#define rATA_PIO_DAD	(*(volatile unsigned*)ATA_BASE74)
#define rATA_PIO_RDATA	(*(volatile unsigned*)ATA_BASE7C)
#define rATA_FIFO_STATUS	(*(volatile unsigned*)ATA_BASE94)
#endif
【关闭窗口】
相关文章
