专注电子技术学习与研究
基于51单片机AD0809八路AD采样12864显示
作者:hkxiaoma   来源:互联网   点击数:…  更新时间:2014年07月29日   【字体:大 中 小】
#include<reg52.h>
#include
//****端口定义*************************
sbit lcdrst=P3^3;
sbit lcdrs=P3^2;
sbit lcdrw=P3^1;
sbit lcde=P3^0;
sbit ST=P2^7;      //A/D启动转换信号
sbit OE=P2^5;      //数据输出允许信号
sbit EOC=P2^6;     //A/D转换结束信号
sbit CLK=P2^4;     //时钟脉冲
sbit ADDA=P2^0;
sbit ADDB=P2^1;
sbit ADDC=P2^2;
//****显示缓存定义*********************
uint  tabSambuffer[8]={0,0,0,0,0,0,0,0};
long  tempvalue=0;   //采集回来数据第一次处理
uint  value_V=0;
uchar diapbuffer[4]={0,10,0,0};
uchar code tab_zix[]={"0123456789.:"};
uchar code dis1[]={" CH0:    CH1:    "};
uchar code dis2[]={" CH2:    CH3:    "};
uchar code dis3[]={" CH4:    CH5:    "};
uchar code dis4[]={" CH6:    CH7:    "};
uchar  code dia11[]={">C"};    //当前数据跟新
uchar  code dia00[]={" C"};
uchar xh,cnt;
void longdelay(uchar t)
   uint j;
   for(;t>0;t--)
     {for(j=1000;j>0;j--);}
void shortdelay(uchar i)
  for(;i>0;i--);
//****读状态函数*************************
uchar readstatus(void)
   uchar i;
   P1=0xff;
   lcdrw=1;
   lcdrs=0;
   lcde=0;
   shortdelay(10);
   lcde=1;
   shortdelay(20);
   i=P1;
   shortdelay(40);
   lcde=0;
   return(i);
//****写命令函数*************************
void lcdwriteinstruc(uchar instruction)
   while((readstatus()&0x80)!=0x00);
   P1=0;
   lcdrw=0;
   lcdrs=0;
   lcde=0;
   P1=instruction;
   shortdelay(100);
   lcde=1;
   shortdelay(100);
   lcde=0;
//****初始化LCD*************************
void initlcd(void)
   longdelay(40);
   lcdrst=0;
   longdelay(1);
   lcdrst=1;
   longdelay(1);   //复位LCD
   lcdwriteinstruc(0x30);
   longdelay(1);
   longdelay(1);
   lcdwriteinstruc(0x0c);  //显示开  游标关 游标位置反白
   longdelay(1);
   lcdwriteinstruc(0x01);
   longdelay(1);
   lcdwriteinstruc(0x06);  //增量方式 不移位
   longdelay(1);
//****写一个字节函数*************************
void writeonebyte(uchar dat)
   P1=0;
   lcdrw=0;
   lcdrs=1;
   lcde=0;
   P1=dat;
   shortdelay(100);
   lcde=1;
   shortdelay(100);
   lcde=0;
//****显示地址解析*************************
void disponeword(uchar x,uchar y)
  uchar dispaddr;
  switch(x)
    case 0: dispaddr=0x80;break;
 case 1: dispaddr=0x90;break;
    case 2: dispaddr=0x88;break;
 case 3: dispaddr=0x98;break;
 default:break;
  dispaddr=dispaddr+y;
  lcdwriteinstruc(dispaddr);
void Clear()
        disponeword(0,0);
      for(xh=0;xh<2;xh++)
        writeonebyte(dia00[xh]);
     shortdelay(1);
         disponeword(1,0);
      for(xh=0;xh<2;xh++)
     shortdelay(1);
        disponeword(2,0);
      for(xh=0;xh<2;xh++)
     shortdelay(1);
         disponeword(3,0);
      for(xh=0;xh<2;xh++)
     shortdelay(1);
 initlcd();
//***********初始页面显示画面*************************************
   disponeword(0,0);
   for(xh=0;xh<17;xh++)
     writeonebyte(dis1[xh]);
  shortdelay(1);
   disponeword(1,0);
     writeonebyte(dis2[xh]);
  shortdelay(1);
   disponeword(2,0);
     writeonebyte(dis3[xh]);
  shortdelay(1);
   disponeword(3,0);
     writeonebyte(dis4[xh]);
  shortdelay(1);
   }//***********初始页面显示画面***完*****************************
    TMOD=0X01;       //定时器中断0
  CLK=0;        //脉冲信号初始值为0
  TH0=(65536-2)/256;     //定时时间高八位初值
  TL0=(65536-2)%6;     //定时时间低八位初值
  EA=1;        //开CPU中断
  ET0=1;        //开T/C0中断
  TR0=1;
      Clear();     //清除当前行指示
    for(cnt=0;cnt<8;cnt++)
     P2&=0xf0;
   P2|=cnt;       //设置采集通道
      ST=0;     //使采集信号为低
   shortdelay(2);
   ST=1;     //开始数据转换
   shortdelay(2);
   ST=0;     //停止数据转换
   longdelay(10);    //长延时
   //while(!EOC);   //等待数据转换完毕
   OE=1;     //允许数据输出信号
   shortdelay(1);
   tabSambuffer[cnt]=P0; //读取数据
   shortdelay(1);
   OE=0;     //一次数据采集完成
   tempvalue=tabSambuffer[cnt];
   tempvalue=tempvalue*341/256;
   value_V=(uint)tempvalue;
   diapbuffer[0]=11;
   diapbuffer[1]=value_V/100;
   diapbuffer[2]=10;   //小数点     code tab_zix[]
   diapbuffer[3]=value_V0/10;
   switch(cnt)
   case 0x00:disponeword(0,2); break;
   case 0x01:disponeword(0,6); break;
   case 0x02:disponeword(1,2); break;
   case 0x03:disponeword(1,6); break;
   case 0x04:disponeword(2,2); break;
   case 0x05:disponeword(2,6); break;
   case 0x06:disponeword(3,2); break;
   case 0x07:disponeword(3,6); break;
     for(xh=0;xh<4;xh++)   //每次更新数据
       writeonebyte(tab_zix[diapbuffer[xh]]);
    shortdelay(1);
     if((cnt==0)|(cnt==1))//更新数据后指示当前行
        disponeword(0,0);
      for(xh=0;xh<2;xh++)
        writeonebyte(dia11[xh]);
     shortdelay(1);
     if((cnt==2)|(cnt==3))//更新数据后指示当前行
         disponeword(1,0);
      for(xh=0;xh<2;xh++)
     shortdelay(1);
     if((cnt==4)|(cnt==5))//更新数据后指示当前行
        disponeword(2,0);
      for(xh=0;xh<2;xh++)
     shortdelay(1);
     if((cnt==6)|(cnt==7))//更新数据后指示当前行
         disponeword(3,0);
      for(xh=0;xh<2;xh++)
     shortdelay(1);
//***********产生AD采样脉冲*******************************************
void timer0( ) interrupt 1    //定时器0工作方式1
  TH0=(65536-2)/256;     //重装计数初值
  TL0=(65536-2)%6;     //重装计数初值
  CLK=!CLK;         //取?
【关闭窗口】
相关文章
