专注电子技术学习与研究
基于MSP430正弦波方波在12864显示程序
作者:hkxiaoma   来源:互联网   点击数:…  更新时间:2014年07月29日   【字体:大 中 小】
//正弦波+方波显示程序
#include
#include
#define  LCD_RS_High    P2OUT|=BIT2    // LCD_RS  高电平   显示数据         P62
#define  LCD_RS_Low     P2OUT&=~BIT2      // LCD_RS  低电平   指令数据
#define  LCD_RW_High   P2OUT|=BIT1  // LCD_RW  高电平   数据读到DB0_DB7   P64
#define  LCD_RW_Low     P2OUT&=~BIT1// LCD_RW  低电平   DB0_DB7 数据写入IR DR
#define  LCD_EN_High   P2OUT|=BIT0    // LCD_EN  高电平   高有效            P63
#define  LCD_EN_Low     P2OUT&=~BIT0    // LCD_EN  低电平   使能信号
#define LCD_PSB_High   P3OUT&=0xff  //  并口   高电平
#define LCD_PSB_Low    P3OUT&=0xfe;  //  串口   低电平    P30
//P67 悬空
unsigned char  pic1[]=      // 图片代码
  0x50,0x50,0xF0,0x00,0x70,0x50,0xD0,0x02,0xFF,0x42,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  0xA1,0xA1,0xE1,0x00,0xE1,0xA1,0xA1,0x00,0xFF,0x08,0x00,0x00,0x00,0x00,0x00,0x00,
  0x03,0x02,0x02,0x00,0x02,0x02,0x03,0x00,0xFF,0x21,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x1F,0x00,0x17,0x15,0x1D,0x00,0xFF,0x84,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x5C,0x54,0x74,0x00,0xFF,0x10,0x00,0x00,0x00,0x00,0x00,0x00,
  0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFB,0x8A,0xFA,0x02,0x02,0x02,0x02,0x02,
  0x02,0x02,0xFB,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0xEA,0xAB,0xBA,0x02,0x02,
  0x02,0x02,0x02,0x02,0x02,0xAA,0xAB,0xFA,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x3A,
  0x23,0xFA,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0xBA,0xAB,0xEA,0x02,0x02,0x02,0x02,
  0x02,0x02,0x02,0xFA,0xAB,0xEA,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x0A,0x0B,0xFA,
  0x02,0x02,0x02,0x02,0x02,0x02,0x02,0xFA,0xAB,0xFA,0x02,0x02,0x02,0x02,0x02,0x02,
  0x02,0xBA,0xAB,0xFA,0x02,0x02,0x02,0x02,0x02,0x02,0xFA,0x02,0xFB,0x8A,0xFA,0x02,
  0x02,0x02,0x02,0x02,0x02,0xFA,0x03,0x02,0xFA,0x02,0x02,0x02,0x02,0x07,0x02,0x00
void delay_ms(unsigned int timer)
  unsigned int i;
  for(i=0;i<1000;i--)
    for(;timer>0;timer--)
unsigned char lcd_busy()
  unsigned char result;
  P1DIR=0x00;
  LCD_RS_Low;          //  指令数据
  LCD_RW_High;
  LCD_EN_High;
  result = P1IN&0x80;   // 读取数据口数据
  LCD_EN_Low;
  return(result);
void LCD_WCMD(unsigned char cmd)
  while(lcd_busy());
  P1DIR=0xff;          // OUT;
  LCD_RS_Low;          //  指令数据
  LCD_RW_Low;
  //   LCD_EN_Low;
  LCD_EN_High;
  P1OUT = cmd;
  LCD_EN_Low;
void LCD_WDAT(unsigned char dat)
  while(lcd_busy());
  P1DIR=0xff;           // OUT;
  LCD_RS_High;          //  数据
  LCD_RW_Low;
  //   LCD_EN_Low;
  LCD_EN_High;
  P1OUT = dat;
  LCD_EN_Low;
unsigned char ReadByte(void)
  unsigned char byReturnValue ;
  while(lcd_busy());
  P1DIR=0xff;
  P1OUT = 0xff;
  P1DIR=0x00;
  LCD_RS_High; ;
  LCD_RW_High; ;
  LCD_EN_Low ;
  LCD_EN_High ;
  byReturnValue=P1IN ;
  LCD_EN_Low ;
  return byReturnValue ;
void Display(unsigned char X,unsigned char Y,unsigned char *string)
  if (X==0)
  {X=0x80;}
  else if (X==1)
  {X=0x90;}
  else if (X==2)
  {X=0x88;}
  else if (X==3)
  {X=0x98;}
  LCD_WCMD(X+Y);
  while(*string )
  {                         //显示字符
    LCD_WDAT(*string++);
void Display_number(unsigned char X,unsigned char Y,unsigned char number)
  if (X==0)
  {X=0x80;}
  else if (X==1)
  {X=0x90;}
  else if (X==2)
  {X=0x88;}
  else if (X==3)
  {X=0x98;}
  LCD_WCMD(X+Y);
  LCD_WDAT(48+number);
void Clock_init()
  unsigned char t;
  BCSCTL1 = RSEL0 + RSEL1 + RSEL2;         // XT2on, max RSEL
  BCSCTL1&=~XT2OFF;                        //打开XT2振荡器
  do
    IFG1 &= ~OFIFG;                       // 清除振荡器失效标志
    for (t = 255; t > 0; t--);            // 延时,等待XT2起振
  while ((IFG1 & OFIFG) != 0);             // 判断XT2是否起振
  BCSCTL2 |= SELS+SELM_2;                  // SMCLK = XT2
void LCD_init()
  LCD_WCMD(0x34);      //扩充指令操作
  LCD_WCMD(0x30);      //基本指令操作
  LCD_WCMD(0x0C);      //显示开,关光标
  LCD_WCMD(0x01);      //清除LCD的显示内容
void ClrScreen()
  LCD_WCMD(0x01);
  delay_ms(15);
void SetGraphicMode()
  LCD_WCMD(0x36);       //选择8bit数据流 图形模式
  delay_ms(20);
void LCD_PutGraphic(unsigned char  *img)
  int i,j;
  //显示上半屏内容设置
  for(i=0;i<32;i++)
    LCD_WCMD(0x80 + i); //SET  垂直地址 VERTICAL ADD
    LCD_WCMD(0x80);     //SET  水平地址 HORIZONTAL ADD
    for(j=0;j<16;j++)
      LCD_WDAT(*img);
      img++;
  //显示下半屏内容设置
  for(i=0;i<32;i++)
    LCD_WCMD(0x88);     //SET 水平地址 HORIZONTAL ADD
    for(j=0;j<16;j++)
      LCD_WDAT(*img);
      img++;
void DrawPoint(unsigned char X,unsigned char Y,unsigned char Color)
  unsigned char Row,Tier,Tier_bit ;
  unsigned char ReadOldH,ReadOldL ;
  LCD_WCMD(0x34);
  LCD_WCMD(0x36);
  Tier=X>>4 ;
  Tier_bit=X&0x0f ;
  if(Y<32)
    Row=Y ;
    Row=Y-32 ;
    Tier+=8 ;
  LCD_WCMD(Row+0x80);
  LCD_WCMD(Tier+0x80);
  ReadByte();
  ReadOldH=ReadByte();
  ReadOldL=ReadByte();
  LCD_WCMD(Row+0x80);
  if(Tier_bit<8)
    switch(Color)
    case 0 :
      ReadOldH&=(~(0x01<<(7-Tier_bit)));
      break ;
    case 1 :
      ReadOldH|=(0x01<<(7-Tier_bit));
      break ;
    case 2 :
      ReadOldH^=(0x01<<(7-Tier_bit));
      break ;
    default :
      break ;
    LCD_WDAT(ReadOldH);
    LCD_WDAT(ReadOldL);
    switch(Color)
    case 0 :
      ReadOldL&=(~(0x01<<(15-Tier_bit)));
      break ;
    case 1 :
      ReadOldL|=(0x01<<(15-Tier_bit));
      break ;
    case 2 :
      ReadOldL^=(0x01<<(15-Tier_bit));
      break ;
    default :
      break ;
    LCD_WDAT(ReadOldH);
    LCD_WDAT(ReadOldL);
  LCD_WCMD(0x30);
//   清整个GDRAM空间
void clrgdram()
  unsigned char x,y ;
  for(y=0;y<64;y++)
    for(x=0;x<16;x++)
      LCD_WCMD(0x34);
      LCD_WCMD(y+0x80);
      //行地址
      LCD_WCMD(x+0x80);
      //列地址
      LCD_WCMD(0x30);
      LCD_WDAT(0x00);
      LCD_WDAT(0x00);
void juxingbo(void)//显示矩形波
  uchar i,j,colour=1,flag=0;
  uchar zhan=12;//为电平'1'的时间长度
  uchar high=25;//高电平的位置
  uchar low=40;//低电平的位置
  for(i=0;i<128;i++)
    if(i%zhan==0)
      for(j=high;j<=low;j++)
        DrawPoint(i,j,colour);
      if(flag==0)
        flag=1;
        flag=0;
      if(flag==0)
        j=high;
        j=low;
    delay_ms(5000);
    delay_ms(5000);
void  main( void )
  //char i;
  //unsigned char x1,y1,colour=1 ;//////////////////////////
  WDTCTL = WDTPW + WDTHOLD;     // Stop watchdog timer to prevent time out reset
  Clock_init();                 // 时钟初始化
  P2DIR|=BIT2+BIT1+BIT0;
  LCD_PSB_High;                // 液晶显示  并口方式
  LCD_init();
  //                              显示字符
  Display(0,1,"西安理工大学");
  Display(1,1,"电子实验小组");
  Display(2,1,"正弦波显示");
  Display(3,0,"2014年07月25日");        // 第四行要显示的内容
    clrgdram();
    ClrScreen();
    juxingbo();                                      //方波显示
    delay_ms(5000);
    //_BIS_SR(LPM0_bits);
【关闭窗口】
相关文章
