专注电子技术学习与研究
TMS320F2812外设例程系列之DefaultIsr
作者:佚名   来源:不详   点击数:…  更新时间:2014年08月17日   【字体:大 中 小】
// TI File $Revision: /main/2 $
// Checkin $Date: April 29, 2005   11:10:44 $
// FILE: DSP281x_DefaultIsr.c
// TITLE: DSP281x Device Default Interrupt Service Routines.
// $TI Release: DSP281x Header Files V1.11 $
// $Release Date: September 26, 2007 $
#include "DSP281x_Device.h"     // DSP281x Headerfile Include File
#include "DSP281x_Examples.h"   // DSP281x Examples Include File
// Note CPU-Timer1 ISR is reserved for TI use.
interrupt void INT13_ISR(void)     // INT13 or CPU-Timer1
  // Insert ISR Code here
  // Next two lines for debug only to halt the processor here
  // Remove after inserting ISR Code
     asm ("      ESTOP0");
     for(;;);
// Note CPU-Timer2 ISR is reserved for TI use.
interrupt void INT14_ISR(void)     // CPU-Timer2
     asm ("      ESTOP0");
     for(;;);
interrupt void DATALOG_ISR(void)   // Datalogging interrupt
   asm ("      ESTOP0");
   for(;;);
interrupt void RTOSINT_ISR(void)   // RTOS interrupt
   asm ("      ESTOP0");
   for(;;);
interrupt void EMUINT_ISR(void)    // Emulation interrupt
   asm ("      ESTOP0");
   for(;;);
interrupt void NMI_ISR(void)       // Non-maskable interrupt
   asm ("      ESTOP0");
   for(;;);
interrupt void ILLEGAL_ISR(void)   // Illegal operation TRAP
  asm("          ESTOP0");
  for(;;);
interrupt void USER1_ISR(void)     // User Defined trap 1
   asm ("      ESTOP0");
   for(;;);
interrupt void USER2_ISR(void)     // User Defined trap 2
   asm ("      ESTOP0");
   for(;;);
interrupt void USER3_ISR(void)     // User Defined trap 3
   asm ("      ESTOP0");
   for(;;);
interrupt void USER4_ISR(void)     // User Defined trap 4
   asm ("      ESTOP0");
   for(;;);
interrupt void USER5_ISR(void)     // User Defined trap 5
   asm ("      ESTOP0");
   for(;;);
interrupt void USER6_ISR(void)     // User Defined trap 6
   asm ("      ESTOP0");
   for(;;);
interrupt void USER7_ISR(void)     // User Defined trap 7
   asm ("      ESTOP0");
   for(;;);
interrupt void USER8_ISR(void)     // User Defined trap 8
   asm ("      ESTOP0");
   for(;;);
interrupt void USER9_ISR(void)     // User Defined trap 9
   asm ("      ESTOP0");
   for(;;);
interrupt void USER10_ISR(void)    // User Defined trap 10
   asm ("      ESTOP0");
   for(;;);
interrupt void USER11_ISR(void)    // User Defined trap 11
   asm ("      ESTOP0");
   for(;;);
interrupt void USER12_ISR(void)     // User Defined trap 12
   asm ("      ESTOP0");
   for(;;);
// PIE Group 1 - MUXed into CPU INT1
// INT1.1
interrupt void PDPINTA_ISR( void )    // EV-A
  // To receive more interrupts from this PIE group, acknowledge this interrupt
  // PieCtrlRegs.PIEACK.all = PIEACK_GROUP1;
   asm ("      ESTOP0");
   for(;;);
// INT1.2
interrupt void  PDPINTB_ISR(void)   // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT1.3 - Reserved
// INT1.4
interrupt void  XINT1_ISR(void)
   asm ("      ESTOP0");
   for(;;);
// INT1.5
interrupt void  XINT2_ISR(void)
   asm ("      ESTOP0");
   for(;;);
// INT1.6
interrupt void  ADCINT_ISR(void)     // ADC
   asm ("      ESTOP0");
   for(;;);
// INT1.7
interrupt void  TINT0_ISR(void)      // CPU-Timer 0
     asm ("      ESTOP0");
     for(;;);
// INT1.8
interrupt void  WAKEINT_ISR(void)    // WD
   asm ("      ESTOP0");
   for(;;);
// PIE Group 2 - MUXed into CPU INT2
// INT2.1
interrupt void CMP1INT_ISR(void)    // EV-A
  // PieCtrlRegs.PIEACK.all = PIEACK_GROUP2;
   asm ("      ESTOP0");
   for(;;);
// INT2.2
interrupt void CMP2INT_ISR(void)    // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT2.3
interrupt void CMP3INT_ISR(void)    // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT2.4
interrupt void T1PINT_ISR(void)    // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT2.5
interrupt void T1CINT_ISR(void)    // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT2.6
interrupt void T1UFINT_ISR(void)   // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT2.7
interrupt void T1OFINT_ISR(void)   // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT2.8 - Reserved
// PIE Group 3 - MUXed into CPU INT3
// INT 3.1
interrupt void T2PINT_ISR(void)     // EV-A
  // PieCtrlRegs.PIEACK.all = PIEACK_GROUP3;
   asm ("      ESTOP0");
   for(;;);
// INT3.2
interrupt void T2CINT_ISR(void)     // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT3.3
interrupt void T2UFINT_ISR(void)    // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT3.4
interrupt void T2OFINT_ISR(void)    // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT3.5
interrupt void CAPINT1_ISR(void)    // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT3.6
interrupt void CAPINT2_ISR(void)    // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT3.7
interrupt void CAPINT3_ISR(void)    // EV-A
   asm ("      ESTOP0");
   for(;;);
// INT3.8 - Reserved
// PIE Group 4 - MUXed into CPU INT4
// INT 4.1
interrupt void CMP4INT_ISR(void)    // EV-B
  // PieCtrlRegs.PIEACK.all = PIEACK_GROUP4;
   asm ("      ESTOP0");
   for(;;);
// INT4.2
interrupt void CMP5INT_ISR(void)    // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT4.3
interrupt void CMP6INT_ISR(void)    // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT4.4
interrupt void T3PINT_ISR(void)     // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT4.5
interrupt void T3CINT_ISR(void)     // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT4.6
interrupt void T3UFINT_ISR(void)    // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT4.7
interrupt void T3OFINT_ISR(void)    // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT4.8 -- Reserved
// PIE Group 5 - MUXed into CPU INT5
// INT 5.1
interrupt void T4PINT_ISR(void)    // EV-B
  // PieCtrlRegs.PIEACK.all = PIEACK_GROUP5;
   asm ("      ESTOP0");
   for(;;);
// INT5.2
interrupt void T4CINT_ISR(void)    // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT5.3
interrupt void T4UFINT_ISR(void)   // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT5.4
interrupt void T4OFINT_ISR(void)   // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT5.5
interrupt void CAPINT4_ISR(void)   // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT5.6
interrupt void CAPINT5_ISR(void)   // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT5.7
interrupt void CAPINT6_ISR(void)   // EV-B
   asm ("      ESTOP0");
   for(;;);
// INT5.8 - Reserved
// PIE Group 6 - MUXed into CPU INT6
// INT6.1
interrupt void SPIRXINTA_ISR(void)    // SPI-A
  // PieCtrlRegs.PIEACK.all = PIEACK_GROUP6;
   asm ("      ESTOP0");
   for(;;);
// INT6.2
interrupt void SPITXINTA_ISR(void)     // SPI-A
   asm ("      ESTOP0");
   for(;;);
// INT6.3 - Reserved
// INT6.4 - Reserved
// INT6.5
interrupt void MRINTA_ISR(void)     // McBSP-A
   asm ("      ESTOP0");
   for(;;);
// INT6.6
interrupt void MXINTA_ISR(void)     // McBSP-A
   asm ("      ESTOP0");
   for(;;);
// INT6.7 - Reserved
// INT6.8 - Reserved
// PIE Group 7 - MUXed into CPU INT7
// INT7.1 - Reserved
// INT7.2 - Reserved
// INT7.3 - Reserved
// INT7.4 - Reserved
// INT7.5 - Reserved
// INT7.6 - Reserved
// INT7.7 - Reserved
// INT7.8 - Reserved
// PIE Group 8 - MUXed into CPU INT8
// INT8.1 - Reserved
// INT8.2 - Reserved
// INT8.3 - Reserved
// INT8.4 - Reserved
// INT8.5 - Reserved
// INT8.6 - Reserved
// INT8.7 - Reserved
// INT8.8 - Reserved
// PIE Group 9 - MUXed into CPU INT9
// INT9.1
interrupt void SCIRXINTA_ISR(void)     // SCI-A
  // PieCtrlRegs.PIEACK.all = PIEACK_GROUP9;
   asm ("      ESTOP0");
   for(;;);
// INT9.2
interrupt void SCITXINTA_ISR(void)     // SCI-A
   asm ("      ESTOP0");
   for(;;);
// INT9.3
interrupt void SCIRXINTB_ISR(void)     // SCI-B
   asm ("      ESTOP0");
   for(;;);
// INT9.4
interrupt void SCITXINTB_ISR(void)     // SCI-B
   asm ("      ESTOP0");
   for(;;);
// INT9.5
interrupt void ECAN0INTA_ISR(void)  // eCAN-A
   asm ("      ESTOP0");
   for(;;);
// INT9.6
interrupt void ECAN1INTA_ISR(void)  // eCAN-A
   asm ("      ESTOP0");
   for(;;);
// PIE Group 10 - MUXed into CPU INT10
// INT10.1 - Reserved
// INT10.2 - Reserved
// INT10.3 - Reserved
// INT10.4 - Reserved
// INT10.5 - Reserved
// INT10.6 - Reserved
// INT10.7 - Reserved
// INT10.8 - Reserved
// PIE Group 11 - MUXed into CPU INT11
// INT11.1 - Reserved
// INT11.2 - Reserved
// INT11.3 - Reserved
// INT11.4 - Reserved
// INT11.5 - Reserved
// INT11.6 - Reserved
// INT11.7 - Reserved
// INT11.8 - Reserved
// PIE Group 12 - MUXed into CPU INT12
// INT12.1 - Reserved
// INT12.2 - Reserved
// INT12.3 - Reserved
// INT12.4 - Reserved
// INT12.5 - Reserved
// INT12.6 - Reserved
// INT12.7 - Reserved
// INT12.8 - Reserved
// Catch All Default ISRs:
interrupt void EMPTY_ISR(void)  // Empty ISR - only does a return.
interrupt void PIE_RESERVED(void)  // Reserved space.  For test.
  asm ("      ESTOP0");
  for(;;);
interrupt void rsvd_ISR(void)      // For test
  asm ("      ESTOP0");
  for(;;);
// No more.
【关闭窗口】
