专注电子技术学习与研究
LCD12864 液晶显示器 模块化程序(51单片机)
作者:佚名   来源:本站原创   点击数:…  更新时间:2014年10月24日   【字体:大 中 小】
lcd12864.h 头文件
#ifndef _LCD12864_H_
#define _LCD12864_H_
extern void lcd12864_busy(); //忙标志函数
extern void led12864_clear();//清屏
extern void lcd12864_init(); //初始化函数
extern void lcd12864_pxy(unsigned char p,unsigned char x,unsigned char y);//数据的显示位置,p=0左半屏,p=1右半屏,p=2两半屏全选,xy为显示的坐标,第四象限,用正值表示。
extern void lcd12864_zifu(unsigned char p,unsigned char x,unsigned char,unsigned char m); //第m个字符的显示位置,与汉字的定义一样,只是xy的坐标的值应小于等于7.
extern void lcd12864_hanzi(unsigned char p,unsigned char x,unsigned char y,unsigned char m); //第m个汉字的显示位置,p=0左半屏,p=1右半屏,p=2两半屏全选,xy为显示的坐标,第四象限,用正值表示,x或y的值都应小于等于3。m为显示的第m个汉字。
#endif
 lcd12864.c 文件
#include<reg51.h>
sbit cs2=P2^0;
sbit cs1=P2^1;
sbit e=P2^2;
sbit rw=P2^3;
sbit rs=P2^4;
uchar code zifu[]=
 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//,0
 0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//。1
 0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
 0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//!2
 0x00,0x00,0x00,0x5F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
uchar code ziku[]=
  //0x80,0x40,0xF0,0x2C,0x43,0x20,0x98,0x0F,0x0A,0xE8,0x08,0x88,0x28,0x1C,0x08,0x00,//"你",
 //0x00,0x00,0x7F,0x00,0x10,0x0C,0x03,0x21,0x40,0x3F,0x00,0x00,0x03,0x1C,0x08,0x00,
 0x80,0x84,0x44,0x44,0x24,0x14,0x04,0xFF,0x04,0x14,0x24,0x24,0x46,0xC4,0x40,0x00,//"李",0 汉字后面的数字表示汉字的代号,方便使用
    0x00,0x08,0x08,0x08,0x09,0x49,0x89,0x7D,0x0D,0x0B,0x09,0x08,0x0C,0x08,0x00,0x00,
 0x10,0x10,0x10,0xFF,0x90,0x50,0xFE,0x92,0x92,0x92,0x92,0x92,0x9A,0xD3,0x82,0x00,//"振",1
    0x02,0x42,0x81,0x7F,0x40,0x30,0x0F,0x00,0xFF,0x40,0x07,0x18,0x28,0x64,0x22,0x00,
  0x80,0x40,0x20,0xF8,0x07,0x48,0x48,0x48,0x48,0xFF,0x48,0x48,0x68,0x4C,0x08,0x00,//"伟",2
    0x00,0x00,0x00,0xFF,0x02,0x02,0x02,0x02,0x02,0xFF,0x02,0x12,0x22,0x1F,0x02,0x00,
 0x00,0x00,0x00,0xC0,0x70,0x20,0x00,0xFF,0x00,0x10,0x20,0xC0,0x80,0x00,0x00,0x00,//小3
 0x04,0x02,0x01,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x01,0x07,0x02,0x00,
 0x00,0x04,0x84,0x44,0x3C,0x44,0x85,0x06,0x04,0xC4,0x3C,0x44,0x84,0x04,0x00,0x00,//卒4
 0x04,0x05,0x04,0x04,0x04,0x04,0x05,0xFE,0x05,0x04,0x04,0x04,0x05,0x04,0x04,0x00,
 0x40,0x41,0xCE,0x04,0x00,0x80,0x40,0xBE,0x82,0x82,0x82,0xBE,0xC0,0x40,0x40,0x00,//设5
 0x00,0x00,0x7F,0x20,0x90,0x80,0x40,0x43,0x2C,0x10,0x10,0x2C,0x43,0xC0,0x40,0x00,
 0x20,0x21,0x2E,0xE4,0x00,0x00,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x20,0x20,0x00,//计6
 0x00,0x00,0x00,0x7F,0x20,0x10,0x08,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,
 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//,7
 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//。8
 0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//!9
/*void delay(uchar i)   //1ms延时函数
    uchar a,b;
    for(b=i;b>0;b--)
        for(a=110;a>0;a--);
void lcd12864_busy()    //忙标志位函数
 uchar i;
 rw=1;
 rs=0;
  P0=0xff;
  e=1;
  //i=P0;
  e=0;
  i=P0;
  i=i&0x80;
  if(i!=0x80)
  break;
lcd12864_writedat(uchar dat) //写数据函数
 //lcd12864_busy();
 rw=0;
 rs=1;
 e=1;
 P0=dat;
 e=0;
lcd12864_writecom(uchar com)  //写命令函数
 //lcd12864_busy();
 rw=0;
 rs=0;
 e=1;
 P0=com;
 e=0;
void lcd12864_init()   //初始化函数
  lcd12864_writecom(0x3f);//开显示 关显示为0x3e
  lcd12864_writecom(0xb8);//设置页地址为0.第一页。
  lcd12864_writecom(0xc0);//设置显示起始行地址,为第一行显示到液晶屏上
  lcd12864_writecom(0x40);//设置列地址
lcd12864_pxy(uchar p,uchar x,uchar y) //数据的位置,p=0左半屏,p=1右半屏,p=2两半屏全选,xy为显示的坐标,第四象限,用正值表示。
  switch(p)
  case 0:cs1=0;cs2=1;break;
  case 1:cs1=1;cs2=0;break;
  case 2:cs1=0;cs2=0;break;
  lcd12864_writecom(0xb8+y);
  lcd12864_writecom(0x40+x);
lcd12864_zifu(uchar p,uchar x,uchar y,uchar m) //第m个字符的显示位置,与测字的定义一样,只是xy的坐标的值应小于等于7.
 uchar i;
 lcd12864_pxy(p,x*8,y);
 for(i=0;i<8;i++)
  lcd12864_writedat(zifu[i+m*8]);
lcd12864_hanzi(uchar p,uchar x,uchar y,uchar m) //第m个汉字的显示位置,p=0左半屏,p=1右半屏,p=2两半屏全选,xy为显示的坐标,第四象限,用正值表示,x或y的值都应小于等于3。m为显示的第m个汉字。
 uchar i;
 lcd12864_pxy(p,x*16,2*y);
 for(i=0;i<16;i++)
 lcd12864_writedat(ziku[i+m*32]);
 lcd12864_pxy(p,x*16,2*y+1);
 for(i=0;i<16;i++)
 lcd12864_writedat(ziku[i+m*32+16]);
void lcd12864_clear()      //清屏函数
 uint i;
 lcd12864_pxy(2,0,0);      //清左右两屏的第一、二、三、四页
 for(i=0;i<256;i++)
  lcd12864_writedat(0x00);
 lcd12864_pxy(2,0,4);      //清左右两屏的第五、六、七、八页
 for(i=0;i<256;i++)
 main.c 主文件
#include<reg51.h>
#include"lcd12864.h"
 lcd12864_init();
 lcd12864_clear();
 lcd12864_hanzi(0,0,0,0);//李
 lcd12864_hanzi(0,1,0,1);//振
 lcd12864_hanzi(0,2,0,2);//伟
 lcd12864_hanzi(0,3,0,8);// 。
 lcd12864_hanzi(0,0,2,3);//小
 lcd12864_hanzi(0,1,2,4);//卒
 lcd12864_hanzi(0,2,2,5);//设
 lcd12864_hanzi(0,3,2,6);//计
 lcd12864_hanzi(1,0,2,9);//!
 lcd12864_zifu(1,6,6,8); //!的左上部 分开以字符的形式显示
 lcd12864_zifu(1,7,6,9); //!的右上部
 lcd12864_zifu(1,6,7,10);//!的左下部
 lcd12864_zifu(1,7,7,11);//!的右下部
 while(1);
【关闭窗口】
相关文章
